TFT monitor went dead
While playing a game monitor went black with blue lines and wouldnt power off, after pulling power cord and repluging it, wouldnt power on...
  • Anonymous Mar 30, 2014
    lines in dark areas when game playing
  • 33 Answers
Hi
How old is your TFT Monitor?
It looks like the Monitor has got some problem.
First, make sure the cables are connected correctly.
Try Changing the connecting cable (between monitor and pc) with another one.
Try using another monitor with your pc & using same cables.
If the problem persits, pls try your monitor on another Computer.
This is all what you can do, if the problem wasn't solved, then maybe the problem is in the monitor that you need to take it to a specialit to repair it for you.
I hope my steps were helpful.
Posted on Nov 06, 2008
Tft
check the power cord, set to the monitor correctly, if still dead, open the monitor, check the power supply module, find some capacitor inside it, if became puffed or leaked change with new one.
Jul 17, 2013 | Samsung SyncMaster 931B 19" LCD Monitor
Viewsonic 27 inch vx2835
No idea to be honest i think just junk it ,unlike old fashioned valve operated TVs this modern equipment is junk once it stops working
Jul 05, 2013 | ViewSonic Computers & Internet
HP Pavilion F1503 only displays a split second?
well, its a 2003 LDC 13 years old ,
its bad
the monitor itself of the power pack to it is bad.
you can test it on any PC< or laptop made
if its dead on all , then its dead.
what more needs saying,
older LCD monitors had old CCFL, lamps. that love to fail
newer are LED back lights that last for ever. it seems
so up grade?
seems your back light is dead
ever do the flash light trick
shine it at the dead screen see good data
yes, then the CCFL is DEAD< (or its power supply ,deep inside)
fixed may but would never do a 2003, not now.
lots of used good LED for sale,
Mar 09, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
Resolution problem with AOC TFT 185W80PF
Monitors don't need drivers to function. Either you need to configure it or it's dead.
Mar 16, 2010 | AOC 19" LCD HDTV Monitor
I just bought a used Mitsubishi-NEC V71LCD monitor. After connecting the power cord, and the video cord, I powered the monitor up. It had a video display for about two seconds, and then went black. I reset...
dhowie, Monitor will need work done to internal "switch-mode-power-supply"/"CCFL inverter supply board. possible bad electrolytic filter capacitors or thermally intermittant component soldering on printed citcuit board. Your CCFL back-lit LCD display no different than any other brand in it's basic design and operation. Spend an hour in my fixya profile reading about black screen and blank n black screen stuff. Then you will know what you will do or not do to solve V71LCD problem. Follow the links to other sites for more info here on fixya and elsewhere. I will check for response from you at this same posting later.
12fixlouie
Mar 11, 2010 | Dell E152FPb 15" TFT LCD Flat Panel...
Monitor went to black. checked and changed all
Check our web site at: www.ccl-la.com/badcaps.htm We have a free repair guide for that model Dell monitor.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Nov 03, 2009 | Dell E173FPb 17" TFT LCD Monitor
Gateway 19inch wide screen, lcd monitor stopped working randomly.
It could be a faulty power cord. Try plugging it in and moving the cord around in the areas where it takes the most movement. Do the same with the data cable to see if you get a response there. If your cables are fine, the problem is most likely hardware in the monitor - in that case you're better off replacing the monitor.
May 06, 2009 | Gateway 19" Widescreen Flat Panel TFT LCD...
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dead or ?
I need the power cord. Would you sell that to me?
Aug 15, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
EMachines E19T5W Flat Panel Monitor - keeps blinking red, green, blue white lines
On the monitor below the screen has these fine pink and green lines blinking across the screen all the time on my laptop. Can you tell me how to fix it or solve this problem?
Aug 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
