Question about ASUS M2NPV-VM Motherboard
Cable select troubles
Hi!
My config is two HDD & two optical devices
Originaly all where configurated with cable select, and worked fine
For some reasons I tried to put a third HDD in place of the optical connected on the black connector, but this HDD was configurated slave.
Computer refused to boot : no system disk.
finaly I came back to the original config, but now my computer refuse to boot , same error message!
I have to disconnect the optical disk to be able to boot
What can I do?
Thank you
  • behappydw Nov 06, 2008
    Thank you for this quick answer, unfortunately, I aldready did that but it didn't solve the problem!
    Hi everybody,
    I just switched the optical devices IDE connectors, it worked!
    May this be helpfull for someone..
    Thank you all
  • 31 Answers
Go to bios and select hdd first boot device
Posted on Nov 06, 2008
How to delete console port and telnet passwords through BootROM?
1. Connect a PC to the device with a serial cable and log in to the device through the console port.
2. Restart the device. When the message "Press Ctrl+B to break auto startup ..." is displayed, press Ctrl+B and enter the password to display the BootROM main menu.
3. Select choice 4 to enter the Startup Select menu.
4. Select choice 1 to view the system configuration.
In V200R001C01SPC300 and later versions, you can use the following method to view the configuration file. In Huawei V200R001C01SPC300, the menu choice is Startup Information. In Startup Information and later versions, the menu choice is Display Startup.
Startup Select
1. Display Startup
2. Set Boot File
3. Set Config File
4. Startupfile Check Manage
0. return
Enter your choice (0-4):1
************** Current Stratup info ****************
Valid Flag State : Vaild
Boot File Name : sd1:/software.cc
Config File Name : sd1:/vrpcfg.cfg
Licence File Name :
Patch State : Deactivate
Patch File Name :
Voice File Name :
In V200R001C01SPC200 and earlier versions, the configuration file cannot be viewed. The system often uses the file vrpcfg.zip or iascfg.zip.
5. Rename the configuration file.
6. Restart RouterA.
7. Stop Auto-Config.
8. Change the renamed configuration file to executable file. Select one file format.
9. Restore the configuration.
Aug 19, 2015 | Computers & Internet
Lock the laser on a MC9590
Hi!
You could install "DataWedge", there you can configure the functionality of the laser.
By "lock" I hope you mean "Always on" in which case you can configure that:
1. Install DataWedge on the device (If not done so already)
2. Open DataWedge on the device (Control Panel)
3. Select "Advanced Config"
4. Profiles
5. Profile 0
6. Input
7. Scanner
8. Select your scan engine, in my case "Blok buster"
9. Reader Params
10. Aim Type
11. Select "Continuous Read".
12. Exit
Let me know if you have any troubles!
Cheers.
Callum
Sep 24, 2014 | Motorola MC9500-K Handheld Mobile Computer
American megatrends bios
hi,
try this,unplug all the cables form motherboard then plug it again one by one,then when is loading the bios screen select "load default settings" then is everithing in connected properly you should see the cd/dvd rom and the hdd,if not check on the official site if the motherboard supports all the devices that you connected.
Aug 20, 2014 | Computers & Internet
Hai sir iam using in intel d945gcnl desktop is propleam (a bootable device has not been detected)wihch propleam in intel board
Do you have multiple hard drives in your system. In the BIOS select the first boot device and select the 2nd HDD as first boot device.
to get into the bios press del and then use cursor keys to highlight boot tab and then select first boot device as HDD. Use the hard drive boot priority menu to select appropriate HDD as first device to boot.This option is only valid if you have two or more hdd's else your OS is corrupt and you will have to reinstall windows. Even check if all the cables to your HDD are tight, you will have to open up the system , if the system was moved around the cables might have become loose and just have to pushed in well.
Mar 03, 2011 | Intel D945GCNL Motherboard
Hi. I write from spain. I have the blu-ray LG
Have you tried the another optical cable? They don't tolerate dirty connections or small-radius bends in their routing. THAT (and the expense of optical cables) is why I always choose coaxial connections when possible.
Mar 02, 2011 | Yamaha RX-V363 Receiver
Asus P5KPL SE & Sata, Bios "Not Detected Problem"..
The Asus bios won't show SATA devices.
However if you are using Windows XP with Service Pack 2 (or newer operating system then the devices should be detected. If this is not happening then enter the bios -- Storage Configuration -- Configuration Enhanced and set the IDE devices to compatible. This allows all drives to be "seen" and you should then be able to load an OS.
Jan 22, 2010 | ASUS Computers & Internet
POSITION OF SLAVE/MASTER JUMPER on rear of unit Toshiba-Samsung SH-M522 Combo
You'll find jumper instructions in the user manual which is available on Samsungs website (http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP08&prd_mdl_cd=SH-M522C%2FBEBN&prd_mdl_name=SH-M522C&prd_ia_sub_class_cd=P ). However, most drives have jumper setting key on the drive label. The choices are usually master or slave or cable select.
Oct 25, 2009 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Only apple display on the screen.
Assuming you're running Tiger or Lepard, this will tell you what's wrong. If it's an older OS/hardware config, I won't be able to help much.
Boot into manual drive selection. I think the command is holding the apple key and C key while powering on. Check with your resaler, as they probably have a Mac Tech that works there and will know the command for sure.
If this doesn't work, you're logic board has gone bad. If it does work, but doesn't show your HDD but does show the optical drive, then your HDD has gone bad. If it doesn't show the optical drive either, your IDE controller has gone bad. If it does show your HDD, then your software is corrupt, and will need to be reinstalled.
Apr 29, 2009 | Computers & Internet
No sound from digital out on PS3 using optical cable
Does the end of the optical cable glow red when hooked up to your PS3 while the PS 3 is powered on? Look at it without the cable plugged into the STR-D845.
Jan 06, 2008 | Sony Playstation 3 (PS3) Console
Hard Disk and Booting issue
go into your BIOS and on the bottom of your screen there should be a (last good config) of (fail-safe config) value for one or=f the F1 to F12 buttons. also. are you running a 4gb hdd??? or is that a typo? anyhow, XP REQUIRES 2GB at all times free if your hdd is running at less that that (cause its full) your boot up could be messed around. finally make sure that the little plug on your hdd is across the Master or cable select pins not the slave as this can cause probs too. good luck.
Sep 22, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
ASUS M2NPV-VM Motherboard Logo
46 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
