Question about Dryers
Ive got a hotpoint electric dryer that intermitantly blows hot air..in other words sometimes it wroks while other times dosent blow that much needed hot air to dry clothes..ive tried different things like cleaning (thoroughly) the lint from both the machine and the air ducts..and now here we are again...interestingly when i put in just a few clothes like less than 5 items then the dryer work more consistantly...so whats up with that?
  • 135 Answers
Sounds like the drum is not turning under heavy load.this is a common problem with dryers but usually easily remedied if a competent diyer. first check the theory by putting in big load and see if drum turns. if not then replacing capacator should cure it.
Posted on Nov 06, 2008
Hotpoint dryer model DLL2650BFLWH not heating
If this is an electric dryer, your heating coil has broken and is no longer conducting current and heating.
Oct 27, 2012 | Hotpoint TDL15 Electric Dryer
Hi there. Our dryer turns on and blows air, but the air isn't hot. We are thinking we need new heat coils. Where would be buy new ones? Can we reinstall them ourselves? Thanks for any help! Angela
hi,as far i know every time running the dryer it is hot even the blower coz of the heater, and the blower if running is to remove the heat inside the machine.the common problem of the dryer is if no hot iar come out in blower exhaust,or check your filter in dryer i think this one is to much block of some cotton due to running for long time,just clean it every time after using for the long last of unit.
i hope i can help you.thanks
Dec 28, 2010 | Hotpoint Ariston A45V Electric Dryer
I have a hotpoint gas dryer that blows cold air not hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 08, 2010 | Hotpoint Dryers
Dryer runs and drys cloths but dosent cool down and stop
when was the last time you cleaned out the dryer?unplug the dryer,remove the bottom panel,take out the lint filter and remove the duct that it slides into.clean the duct out,vac out the inside of dryer,if you have a shop vac you can put it on blow and blow the lint forwards so you don't ha ve to remove the drum.put that back together and remove the vent line from the back of dryer,if it's a long run blow it out with a leaf blower,also make sure the outside vent is clear before you blow out the vent line,if the dryer can't move the air around it will run hot.
Jun 26, 2010 | Kenmore Elite HE4 Electric Dryer
Help! hotpoint aquarius condenser dryer
More than likely thermostat or heater.
Located at rear of dryer behind removeable panel, you will need a meter to test them.
Jan 28, 2010 | Hotpoint Aquarius WF000 Front Load Washer
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
Hotpoint dryer wont get hot
This condition is normally cause by a faulty thermostat...
Sep 22, 2009 | Hotpoint NWXR473EV Dryer
My hotpoint aquarouis ctd00 tumble dryer is heating but no air is blowing through. also there is no water collecting in the water tray
Check all filters and air vents at front and rear of m/c, to make sure they are all clear., do not overload, make sure you have selected right heat setting, and the correct drying time.
It is not usual to feel air blowing out of dryer, because it is a condenser dryer.
Plz rate my solution.
Thanks.
Dec 27, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint tdc62p changed thermostats as blowing out cold air,
Make sure that all filters are properly cleaned, and that the air inlet and outlet vents are clear. Make sure water container is empty.
The best way to clean the filter at the bottom is to run cold water through it, this will clear out all the lint.. Make sure you have the correct stats ( there are many for the hotpoint range) and that you have them in the correct position on the heater back plate.
Plz rate this solution.
thanks.
Dec 16, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint NVL333EY Electric dryer blows thermal fuse
I had the same thing happen, I replaced the thermal cutoff and made sure no lint build up. It lasted a week then blew again. I then replaced it again and got to thinking why it would blow. I then took apart the exaust inside the dryer running fron the drum to the motor and right before the motor was a build up of lint ane particals that was almost like compressed sawdust which was blocking half of the line. I cleaned this out and it seemed to work much better.
Jan 04, 2008 | Hotpoint NVL333EY Electric Dryer
Dryers Logo
59 people viewed this question
Top Dryers Experts
