Question about Microsoft Xbox 360 Console
Xbox 360 Rom to pc
I have a Xbox 360. with 3 Red Light Rings in it. The replacement period has been lapsed so i bought a new one. its working fine. So can i use my old xbox360's DVD rom and connect to my pc. if yes can any one tell me how can i connect it to my pc...
  • 94 Answers
No u cant the dvd rom for the 360 is coded for that board only ....and i have a way to fix the three rings of death
Posted on Nov 06, 2008
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
My 360 has 3 rings the rings are red and it wont turn on
The three red lights mean that your XBOX360 is experiencing hardware failure. This is caused by overheating of your XBOX. Contact Microsoft and have them fix the problem. They have given free extended warranty for three red light problems. If you have bought your xbox360 within 3 years, you're in luck.. They will fix your console for free...
Mar 13, 2010 | Microsoft Xbox 360 White Console
My Xbox 360 Gets 3 Red Lights Of Death and Then Works Fine
You can fix the 3 lights of death by replacing the x-clamps and the crappy thermal paste. Here is a kit to fix it and it comes with the guide too.
http://cgi.ebay.com/XBOX-360-Repair-Kit-3-Red-Light-Fix-3-rrod-COMPLETE_W0QQitemZ380123627056QQcmdZViewItemQQptZVideo_Games_Accessories?hash=item5881223e30&_trksid=p4634.c0.m14.l1262&_trkparms=|293%3A1|294%3A30
Jul 11, 2009 | Microsoft Xbox 360 Elite Console
IGOT 3 RINGS OF DETH
Three red lights on the ring of light is an indication of a hardware failure
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Check the light on the power supply ( The big brick that goes to your wall )
If the light is green that means the power supply is OK
If the light is Red that means the power supply needs to be replaced
3. If above steps doesn't work, you need to contact xbox customer support to get your xbox repaired
and shipping and handling will be covered.
Apr 14, 2009 | Microsoft Xbox 360 Console
Xbox 360 RRD
my son had 3 rings and we bought another power supply cable. it worked he can play all day now. hope that helps. good luck!
Nov 06, 2008 | Microsoft Xbox 360 Console
Xbox controller will not sync with console
Disconnect the power cord from the 360 for a couple of minutes.
Plug it back in and turn it on. Power turn on a different controller than the one that isn't working and sync it with the 360.
Now turn on the original controller that wouldn't sync, and use the sync buttons on the 360 and controller. It should sync up and go to player 2 slot.
Everything should be good now, that's how I fixed mine.
Apr 23, 2008 | Microsoft Xbox 360 Console
Xbox360 1 Red light, sometimes 2
there are two things that those light mean.
-the best solution is to VACCUM the dust out of the xbox before you get other problems. The collecting dust is making ur xbox overheat. So keep it clean before you get the 3 or 4 rings of death!
-also, take off that cooling system because the 360 works best without cooling fan.
-Finally, make sure your A/V cables are securely plugged in.
Mar 23, 2008 | Microsoft Xbox 360 Console
3 red rings flashing on xbox 360
hey man, i dont own a 360, but i know that red rings are know as the red rings of death on a 360
Mar 17, 2008 | Nintendo Game Boy Advance Console
3 red rings of light and disc tray not opening
sendit back to microsoft they will send u a new one
Oct 31, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
734 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
