Question about Gateway 4530GZ Notebook
Power problem My gateway laptop will not power up when i connect the power jack to it it just blinks the systems will not power up the power led just blinks continlously
    Guru:
  • 257 Answers
With this sysptoms u see the Processors of your system is faulty and that make your system when power on to flicker or to blink alone and switch off then you will have to replace the processor or if the processor is good then the processor Fan is faulty and it will need a replacement . bye ok
Rate this solution
You are always welcome.
Posted on Nov 06, 2008
I have a gateway mx6421 and my problem is, not charging the battery. everything works fine and the only problem is that they charge, I think the problem is the jack but not if it brings some fuse or d
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Apr 08, 2013 | Gateway MX6421 Notebook
NO POWER AND NO DISPLAY
try without battary......
otherways... disconnect power jack and battary and all other cable connected to computer and press and hold power butten for 38 sec then try to power on
Nov 25, 2012 | Compaq Presario C700 Series Laptop...
My gateway nv79c54u laptop ac plug doesnt charge just blinks orange
Sep 12, 2012 | Acer Gateway NV79C54u 17.3-Inch Laptop...
My toshiba satellite l35 wont turn on,,,the light blinks then shuts off ,,,thats all it does
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 17, 2011 | Computers & Internet
I have a toughbook cf-19 and the charging lite keeps blinking red
You have a DC connector problem:
Jan 29, 2011 | Panasonic Computers & Internet
I have a acer extena 4420-5239 that the dc jack inside has come loosa and will not make a connection to power up. Can that be fixed or is it connected to to board
Yes it can be soldered back onto the system board.
Dec 19, 2010 | Acer Extensa EX5620-4025 (LXE970X025) PC...
I have ac adapter plugged into the wall, and into the computer, the charge pack light is green, the battery is in the computer and the computer won't turn on at all
You probably have a bad or loose DC jack on the laptop:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
http://www.insidemylaptop.com/laptop-dc-power-jack-repair-techniques/
Nov 30, 2010 | Gateway SL1450-30145063 Notebook
No power. All power cords checked and tight. With
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Jan 06, 2010 | Gateway MP6954 Notebook
Blue led power light blinks even after shutdown
What operating system are you using? When the power led continues to slowly blink, that means that the laptop is in standby mode and not fully shut down. In Vista, if you hit the power button on the laptop or the power button under the start button, it is configured to go to standby and not shut down. Make sure to hit the arrow all the way to the right and select shutdown from the list of dropdown options.
Aug 28, 2009 | Gateway Computers & Internet
Gateway 4530GZ Notebook Logo
101 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
