Question about Watches
Rolex watch stops only when I wear it
Hi I've had a Rolex Oyster Perpetual Datejust watch for approx 5 years and it has always worked beautifully. However I sent it for service earlier this year and since then it has not kept time. I have sent it back, it's been tested and even worn by a friend for a period of time and keeps time perfectly. If it is wound and I leave it overnight it keeps time; however when I put it on it immediately loses time. I am active, I am doing nothing different in my day-to-day activity than in the past 5 years so can't work out why its accuracy has changed. I have been very busy/stressed in my work in the last few months (maybe dumb question) but could this have 'altered' my kinetic energy????
I hope you can help. Thanks.
  • palangmead Dec 16, 2008
    I have the same problem with two different Chinese mechanical watches, a ladies and a gents. The watches keep perfect time (+/- 30sec per day) while not being worn (regardless of position) but stop periodically as soon as they are worn, even when fully wound manually.
    What Gives?
    Novelist:
  • 100 Answers
Kristy,
Stress won't affect your watch's timekeeping ability, but position will. When you lay the watch down at night, in which position is it? Also, during the day, is your arm in a static position for long periods of time? A Rolex chronometer (like the Datejust) should run approx. 36 hours after being fully wound -- without any movement. If the watch stops dead, then there is a problem with the movement and/or rotor. If it losses time, I'd bet on a static position problem. Let me know the answers to those questions and I'll try to help you get to the bottom of the problem.
Posted on Nov 17, 2008
Ive wound watch about 40 times it runs for about 3 minutes then stops again
I have the same watch 20 years old. I cannot wind this watch.
it is self winding , which is generated by arm or wrist movement.
i purchased a box for times I won't be wearing. Will rotate watch 5 minutes every hour ( belt driven- only use that other winders say gear my experience is belt drive more reliable)
if you have to wind this watch I would question if it is real Rolex.
Aug 30, 2015 | Rolex Datejust Watches
My three-year old (real) Rolex Oyster Perpetual Lady Date Just started losing time after just six months. It would stop and start intemittently and lose a few minutes every hour. Winding did no good. I...
It seems to me that the company servicing your timepiece (Rolex or otherwise) must have missed something or did not properly service your timepiece.
You are correct that your watch should not require service every ten months. After servicing, your Rolex, like most all automatics, should run properly for 3-5 years depending on environmental conditions. Our Rolex service offers a one year warranty, and if any issues present within that time, the service is free.
I would recommend using a company that has a full time Certified Master Horologist on staff to service your timepiece that offers a warranty on their work. Thanks for the rating, and we are happy to help you and service your Rolex.
http://www.watchandpen.com/id76.html
Expert watch repair for Rolex Breitling Tag Heuer Movado
Oct 22, 2013 | Rolex Oyster Perpetual Lady Datejust...
I usually shake my Rolex (Datejust Oyster Perpetual) because it slides to one side, but when I shake it, the second hand sometimes stops. Once I shake it again, it begins to tick again. I have tried...
What's the question? From you description of the troubles you are having I suspect that your watch may on the outside look like a Rolex, but it certainly does not behave like one. I have never had such erratic behavior even with my much cheaper, but authentic Casios.
Sep 26, 2013 | Rolex Watches
My wife's Rolex Oyster Perpetual watch is running very slow. It was cleaned approx 7 years ago and seemed to run properly. I phoned the NY service center which quoted a $600 basic cleaning fee which seems...
Hi , I am sorry to say that a rolex requires servicing on a regular basis . Every 3 - 5 years would be advised . If you consider that your watch is a delicate machine that may be working 24 hours a day for years then its not unreasonable that it needs servicing. Over time the fine oils dry and degrade , they need replacing , and parts can become damaged .
As to cost , this is a skilled job . To service a rolex in the correct way requires not only skill ,but the correct tooling and equipment . Also the materials used must be genuine rolex , this is costly . Your accredited service centre will then provide a 2 year guarantee .
All in all the price of $600.00 reflects the labour of a skilled man and his investment in gaining rolex status .
There will be cheaper alternatives but beware as they will probably not be rolex trained and wont be using original materials .
Aug 01, 2013 | Rolex Oyster Perpetual Day-Date Watch...
My wife's oyster perpetual is running exceptionally slow. It was cleaned and seemed to be running fine for the past 8 years. I've phoned Rolex service in New York with a $600 price for basic cleaning. This...
Hi Bob,
Unfortunately, Rolex automatics, like all mechanical watches, must be serviced every 3-5 years. This is because the oils in the movement dry and congeal on the bottom of the wheels (gears) and dust and debris in combination work like sandpaper to cause wear on the parts.
Think of it like a fine automobile, one would never neglect the oil change in their new Mercedes because the engine could be damaged. In this case it is the movement that can have excessive wear. Also, the mainspring at this point may need to be replaced, which is the power source of your movement. We service Rolex and all other high grade watches, and always beat the price of the Rolex service center, their time frame, and can provide discontinued parts where they cannot.
We are happy to service your timepiece at a much better price than that offered. Feel free to contact us through email or phone.
If the watch is not worn for a day, is it normal for it to stop or slow down? Vintage SS mens datejust, oyster perpetual.
mcdevito75 here, Yes it is normal, especially if your Rolex is an automatic watch. The motion of your Wrist / Hand keeps your watch wound thru the Counter balance on the movement, as the counter balance turns it winds the mainspring little by little, thus keeping your watch wound. Once you take off your watch, if long enough the mainspring simply un-winds and slows and will eventually stop your watch completely. You can keep your Rolex wound even when you take it off by means of a watch winder, a small machine that will keep your watch in motion, or by hand, by rocking the watch back and firth in your hand for about 30 seconds, say before you gpo to bed at night, this way there is always some wind to your watch.
Aug 15, 2010 | Rolex Datejust SS
Rolex oyster perpetual datejust time/date setting instructions
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
Dec 12, 2008 | Rolex Datejust SS
Watches Logo
816 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
