Question about Casio Parts Cash Register PC Desktop
CAIO CE-3410 Hi I have turned off the power to our till during a bar refurbishment, i now only get a key pad alarm no matter what button i press and cannot re-set the till. any ideas ?
  • 737 Answers
It sounds like you have neglected to have the battery changed on time, and now you have probably lost everything from the machine. It will need to go to a programmer to have everything programmed back in as it will usually need system programming as well as all the user data replaced. Find a dealer in your area.
Posted on Nov 06, 2008
I forgot my admin password for my Dell C1765nfw Color MFP web interface. I changed it from the admin default, but do not remember the pwd. How do I reset it
You could try performing a hard reset. Keep in mind that this will reset ALL settings. Admin password should then be back at the default, which is admin.
Clear NVRAM from Tech Mode
  • Turn off the printer.
  • Turn on the power while holding down Left arrow,Right arrow, and Menu buttons.
  • Release these keys when "CE Mode" and "Password" is displayed.
  • Press Up arrow key twice and press the checkmark.
  • "CE Mode", "Printer" and "FAX/Scanner" are displayed. (Entered the CE Diag. mode.)
  • Press the checkmark key to select "Printer".
  • Press Down button to "Installation Set" and press the checkmark key to select.
  • Press Down button to "Clear All NVM".
  • Press the checkmark key twice to execute the test.
  • Power cycle the printer to return to the regular operating mode.
May 23, 2017 | Dell Computers & Internet
When I want to print it says error 6C10 switch off switch on. Doesn't work!
that indicates full waste ink pads/absorbers. to reset the counter try this:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
any way if the absorber/pad is full, it have to be cleaned!
Sep 20, 2011 | Canon PIXMA iP4600 Color InkJet Photo...
Bottom right button is light, not EI. top left is adj button left is mode top right is st/stp. I can't set time and date and can't turn off my alarm
El stands for
To set the time
  1. Press and hold [ Adj button ] till the digits on screen starts blink.
  2. Now Press [ Mode Button ] repetitively to cycle through Hour -> minute -> Seconds
  3. Press [ ST/STP button ] to adjust the value. Each press will increase the value.
  4. Press [ Adj Button ] again to save the changes
To set the alarm
  1. Press [ MODE Button] till it displays Alarm Time.
  2. Repeat steps 1 to step 4 as described in 'To set the time'
  3. Different watches have different procedures to active the alarm. Common method is pressing a button briefly.
    Since model of watch is not specified, Try pressing [Adj Button] or [ST/STP Button].
Mar 18, 2011 | Watches
How to reset waste pad for Canon IP4500
First, replace the waste pad with a new one....
1. With the printer turned off, press and hold down the resume/cancel button, then press and hold the power button. Do not release the buttons. the power led should come on green...
2. Release the resume cancel button, bur keep holding down the power button....
3. Press the resume/cancel button twice (Still holding down the power button) The Alarm and Power LEDs should alternate with each press...
4. Now release both buttons.
5. When the Power led is green, press the resume/cancel button 4 times only. The Alarm and power Leds will alternate, green, orange,green orange, green...
6. Now press the power button. The paper lifting plate should raise.
7.Reboot the device. That should do it...
Good luck
Dec 20, 2009 | Canon Pixma iP4500 InkJet Printer
This ino might help: Cleaning ERRORS: ______________________________
1.- Turn the Mode lock to OFF
2.- Press down the RECEIPT FEED button
3.- Turn the key to PROGRAM
4.- Lift up RECEIPT FEED button (FFFFFFFFFF)
appears on the display panel
5.- Press SUBTOTAL (wait for receipt to issue)
6.- Turn Mode Switch back to REG and use as Normal.
Also another bit goes like this:
RESET: _______________________________________
1.- Insert the OW key and turn to OFF
2.- Hold down the JOURNAL FEED button and turn the key to PROGRAM mode
3.- Release the JOURNAL FEED button. The display should shows "00000000".
4.- Turn the key to OFF
5.- Turn to REG1. The display shows "INIT" and "0.00"
6.- Press the number 10801 and then press SUBTOTAL. Initialisation is completed when the printer stops operation. The display shows: "_ 0.00"
Hope this helps in restting to factory settings................................sodeep
May 12, 2009 | Casio Parts Cash Register PC Desktop
Casio ce-3700 e01
Hi. You have turned the key before you finished what you were doing in another mode. A flag clear will jump you back to reg mode. Try this:
Turn power off at wall.
Turn key to program mode.
Hold RECEIPT FEED button down.
Turn power on at wall and let go of RECEIPT FEED after 5 seconds.
You should see 'FFFFFFF' on display
Turn key back to reg mode and try it.
Sep 11, 2008 | Casio Parts Cash Register PC Desktop
Casio till make ce 3410 Error
Hi. we don't have this model. it is very old now. But, it is probably similar to some of ours, so I'll give you the usual info, and it will probably work.
The first thing to do is turn the key to each mode, and press your CASH key. If the drawer opens, then that was your problem.
If it doesn't, then try a flag clear:
Turn the power off at the wall.
Hold the RECEIPT FEED button down while turning the power back on at the wall.
Wait 5 seconds.
You should see 'FFFFFFFFF' on the display.
It should print out.
Turn the key back to Reg mode.
If you still have trouble, just let me know.
Jul 16, 2008 | Casio Parts Cash Register PC Desktop
Trouble with changing the size of letter
Press the select button so light would go off than press 2 buttons marked menu than press print,this will print out the menu settings .When done press the group button till rear group prints than press item till page lenght prints,now press the set button till the desired page length is reached,than press exit button to save setting and exit from menu.Power off the printer then power back on should be ok .Hope this helps.
Feb 04, 2008 | OKI Pacemark 3410 Matrix Printer
Cant control toshiba tv model ce19t11
it is one of these code you will have to try them all till you get the right one they are 059    060    019    014    052    075
1 turn on tv to be prog
2 on remote hold down set
3 whilst holding set button press and release power button
4 release set button
5 press tv button on controll
6 using key pad key in code
7 press enter button
8point remote at telly
9 press power button c if it works
if not work start again but use next code keep going till you get it to work try this site as well http;//
Oct 26, 2007 | Sony RM-V302 Remote Control
Wont come on
try pressing one of the number keys instead of the power button on the remote
Sep 06, 2007 | Beko 324250WN 28" TV
Casio Parts Cash Register PC Desktop Logo
107 people viewed this question
Top Casio Retail Supplies Experts
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
