Are replacement of front wheel sensors plug and play or does dealer need to set ecu? where doe metal filings on sensor come from after accident? thanks d
I don't think the dealer needs to get involved, if you are just replacing the wheel sensors. Follow the repair procedure, and if it says to disconnect the battery first, then do so. It is plausible that an accident could scrape metal filings from the rotors or wheels and throw them around the sensors, I would think. Well, good luck.
SOURCE: VW Passat 1.6l 2000 (UK) Electrical failure
fuses are usually in the glove box or under the drivers dash or under the drivers side hood either physically inspect every fuse by pulling them one by one or the aid of a test light and a good ground to the test light
no definite solution but appreciate the try. need definiative answer not good luck as dealer repair is $170 + computer hook-up to ecu with me supplying aftwermarket part.s
