Question about Lexmark JetPrinter X1185 All-In-One InkJet
Error e079 0000 - Lexmark JetPrinter X1185 All-In-One InkJet
  • 962 Answers
E0790000 means that roller (engagement) is not detected, try aligning the roller. if you have the owners manuel or CD Rom. it should show you how to align it.
Posted on Nov 06, 2008
CANON CLC 1100 ERROR CODE E079 CAN YUO HELP ME?
Have you tried to reset? maybe you can reset first meanwhile I will be looking for further solution
Feb 18, 2008 | Canon CLC 1120 Color Copier
Need a error list for a Canon IR 600 imagerunner
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Aug 07, 2013 | Canon imageRUNNER 600 Printer
E000079-0001
The E079 error code indicates the home position of the outside heating roller (engagement) home position sensor does not get detected. The outside heating roller (engagement) home position sensor does not go off.
The detail code 0001 indicates the home position sensor does not go on within 5 seconds after the start of the home position search.
The error code does not reset after the machine's power is turned off and on again.
Check the position of the outside heating roller home position sensor's (PS22) flag. The flag can easily be moved out of position or broken during transport.
Note: the parts manual refers to the outside heating roller home position sensor as PS66 rather than PS22. (See figure 810 page 2-156)
Apr 28, 2012 | Canon imageRUNNER C5800 Copier
E079
The transfer drum cleaner HP
sensor (PS59) is faulty.
• The transfer locking driver PCB is
faulty.
• The DC driver PCB is faulty.
• The CPU PCB is faulty.
0000 The transfer drum cleaner HP
sensor does not go '1' when
the transfer drum cleaner
locking motor has been kept
on for a specific period of
time.
0001 The transfer drum cleaner HP
sensor does not go '0' when
time.
Jun 20, 2010 | Canon CLC 1120 Color Copier
Canon ir 3530
E490 wrong DF type
E531 stapling error
E535 swing error
E577 paddle error
E584 shutter error
E590 punching error
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
E079 code
all the 70 codes have to do with the transfer sheet unit ... either the sensors in it or the lift mechanisms motors etc unless your a tech this is probably over your head
Dec 10, 2008 | Canon CLC 1150 Color Copier
Error E079 Am using in canon 1180 Printer
E079 is the transfer lift clutch unit int the rear of the copier. You have to remove the unit and look for a broken cam & or pin that goes in the cam and clean both sensors and flags in that unit and make sure it is sping freely. The unit ingages the transfer cleaning unit. Good Luck.
Nov 06, 2008 | Canon CLC 1120 Color Copier
ERROR E079 0000
E079 basically means that the home position of the outside heating roller (engagement) is not detected, i think changing the position of the roller or getting it aligned should fix this problem. :)
Nov 06, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Canon error E079
E079 = tranfer drum cleaner does not engage or return to home position (ps9) first check the sensor ps9 and check the moter that operates the cam that engages the TRANSFER DRUM CLEANER. if you nead to know more please get back to me i am in the uk 00447764303923
Thank You
Lexmark JetPrinter X1185 All-In-One InkJet Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
