Question about Motorola Mobility MA560 Cordless Phone
Motorola MA560 Cordless Phone Problem
Handset not working. Cant be page and no dial tone
  • Anonymous Dec 06, 2008
    The "charging" light keeps flashing over and over so I thought it needs new batteries. After replacing the batteries, the "charging" light still kept flashing and when I turn on the handset, it just dies on me. The answering machine still works though.
My motorola Model K704B is saying "no line in what can I do to fix it
The "No Line" message means that the base of the cordless phone either doesn't have power, the line is damaged or that the handset/base are not communicating properly. To diagnose the problem, first check that the base AC cord is connected to a good outlet. You may want to unplug the cord from both the phone and the wall outlet and then plug it in again. (I've seen a case where someone turned off a surge protector and forgot to turn it back on; without power, the cordless phone won't work.)
To check if the problem is the phone line, I like to use an old corded telephone. Plug the backup phone in and check for a dial tone. If there is no dial tone, try a new RJ-11 cord. If there is still no dial tone, try the test phone at another jack. If you can, find the box where your telephone line service comes in. Open the box and look to see if there is an RJ-11 jack. If that jack is present, try using the test phone and listen for the dial tone. If there is no dial tone at the service box, contact your phone company. They should fix this problem for free. (It's possible that rodents have damaged the phone line outside of your home.) If the box doesn't have an RJ-11 jack, you'll need the phone company to test the service and repair it if needed.
If there is a dial tone at the service jack, then you have an inside problem. If there was no dial tone at only the first jack, you can check the jack itself. Unscrew the face plate and look at the back of the unit. There are two types of connections. If you have the screw terminals, look for a disconnected wire. Strip a new section of wire and secure it under the correct screw on the face plate. See for the wiring pattern. If the jack uses a keystone, you'll need a punch-down tool that is available in many hardware stores in the electrical wiring section. Do not strip the conductor; just push it down into the correct slot of the keystone. If the problem is not at the jack, you'll need to check all of the wiring from the service box for damage. Your telephone company will do this for a fee.
If the test phone had a dial tone at all of the telephone jacks, then the problem is with the cordless handset and the base. One of the two units is not communicating correctly (transmit/receive). If your cordless phone is still under warranty, contact Motorola. If only one handset can be used with the base, replace the phone. If your cordless phone can pair multiple handsets with the base and only one handset is giving the "no line" message, replace the handset.
I hope this helps.
Feb 05, 2016 | Motorola Cell Phones
Why can;t I hear anything on outgoing calls
Cordless/Corded Phones, Digital Photo Frames 1-888-331-3383 Mon-Fri 7:00AM-7:00PM CST
Contact our team for assistance.
Motorola Support
Sep 14, 2014 | Motorola IT6-2 DECT 6.0 2-Handset Digital...
I have uniden dxa1850 series phone. It was working fine, but now I can't get a dial tone. I tried the basic fix of unplugging and removing but it still does not work
Check that you have power (eg. Led indicator is on) to your Base station.
If you have power to the base station and you still do not have a dial tone, plug in a non-cordless handset to the phone socket and see if you have a dial tone on yor non-cordless handset, then you have a faulty base station.
Hope it helps and good luck! let me know how you go!
Dec 12, 2010 | Uniden Cordless Phone
My telstra 8100 cordless phone keeps showing the word searchingnow i cant do anything with the phone.hope someone can help. Cheers
Place the telstra 8100 handset in the charger. Call any number while the handset is in the charger and it should dial out - you can hear the dial tone now. Take the handset out of the charger and you should be able to call normally.
cheers Matt
May 16, 2010 | Cell Phones
No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Sep 25, 2008 | Uniden 2.4 GHz Cordless Phone System
Cant get one of the phone to get dial tone says unavalibel
All you have to do is put the phone that does not get a dial tone on the MAIN CHARGING BASE for 20 seconds! it will then sync up!
Jul 17, 2008 | GE 25931 Trio Cordless Phone
Problems with handsets
Are they cordless phones?If they are they get there dial tone from the base.If there is a blinking red light on the hand sets they lost communication with the base.Check your user manual to see if you need to program them to the base.
Jun 09, 2008 | Panasonic KX-TG1033S Cordless Phone
Handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
Nov 17, 2007 | Xact Communication XG2200 Cordless Phone
Motorola MD451 phone "Out of Range?"
Go To Menu, and Then Press Register, On The Base Than Place The Page Button On The Base.
Jun 06, 2007 | Motorola Mobility MD451 Cordless Phone
Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
Jan 14, 2007 | Xact Communication XG2200 Cordless Phone
Motorola Mobility MA560 Cordless Phone Logo
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Level 1 Expert
Eric Sutherland
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
