Question about Fisher and Paykel GWL11 Top Load Washer
Commences fill but not rotating, then stops and beaps with green led 5th from right blinking
I need a service manual of washing machine manufactured by Fisher&Paykel before 1999.
model name : GW501 or MW051 - we can't work out the sequence to commence Fault Diagnotics?
  • 502 Answers
Manualfox.com has the service manual.
Posted on May 22, 2011
  • 72 Answers
Change the electronics board
could use second hand boARD
the problem is caused by the electronic circuit electronics not balancing properly
Posted on Sep 25, 2010
Led lights power and centrifugation problem
Hello Pedro, I am happy to assist you!
Often when a washer is blinking, it is because it needs to be reset to resume normal operations. Let's try reprogramming your washer by either flipping the household circuit breaker to the off position or unplugging it. It is necessary to wait approximately ten minutes and then turn your washer on. If resetting the power does not correct the issue, your washer could be experiencing a communication error with the control board or could have a wiring failure. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Nov 09, 2013 | Frigidaire Affinity ATF7000E Front Load...
How do i get codes for a whirlpool cabrio wtw5500xw0 washer with no display?
Error codes for WTW5550XW whirlpool cabrio
It would appear that no one read your original post, I believe you asked: HOW DO IT GET THE ERROR CODE. I have the same machine and had the same problem. The method is descibed in the service manual available at servicemanuals.net for about $17. It also has a decent wiring diagram and how to generally do anything the local service guy could do well worth the money for a download you can have in your hands in minutes.
Back to your question.1) turn the washer off (the power button) all the indicator lights should be off.
(now think of your old gym locker combination lock, cause it will be a little like this)
2a) rotate the center selector knob CCW (counter clockwise a few clicks), this seems to get the machines attention
2b) immediately rotate 1 click CW clockwise
2c) immediately rotate 1 click CW (again)
2d) immediately rotate 1 click CW (again)
2e) immediately rotate 1 click CCW
2f) immediately rotate 1 click CW (again)
visually it would look like this <---,->,->,->,<-,->
now just the led's below the indicator should be blinking off and on on about 1 second intervals
you may need to try a few times to get the timing just right, you aren't spining through the clicks, just about enough time to say "left-left-left-right one,right-two,right three,left one, right one
with all the led's in a row blinking you are ready to go into code mode.
(sensing soak wash rinse spin done) (mine doesn't have soak BTW)
3) rotate the selector knob a few clicks until only the "done" led is lit
4) press start
5) the led's should blink again
which leds blink tells you alternately the fault# and error# when the "sensing" led is blinking, the other leds are indicating the fault number, when it is not on, the indicate the error# the fault# is the type of problem, and the error# indicates where the problem was detected.
6) a partial listing using the fault #, I will indicate the led as follows: Sensing/Wash/Rinse/Spin/Done
S/W/R/S/D this would be all these leds lit
s/w/r/s/d this would be all these leds off
the F# codes to the right is what you would see if you had the numeric display on the console (not all models)
Here goes:
Over suds condition: S/w/r/s/d F0
High water temp rinse cycle: S/w/r/s/d F0
Off balance load: S/w/r/s/d F0
Main control fault: S/w/r/s/D F1
Motor control fault: S/w/r/s/D F1
Stuck key: S/w/r/S/d F2
Mismatch of main control UI: S/w/r/S/d F2
Pressure sensor fault: S/w/r/S/D F3
Inlet water temp fault: S/w/r/S/D F3
Lid switch fault: S/w/R/s/D F5
Lid lock fault: S/w/R/s/D F5
Lid unlock fault: S/w/R/s/D F5
Lid not opened between cycles: S/w/R/s/D F5
Basket speed sensor fault: S/w/R/S/D F7
Shifter fault: S/w/R/S/D F7
Motor fault: S/w/R/S/D F7
Motor unable to reach target rpm:S/w/R/S/D F7
No fill long fill: S/W/r/s/d F8
Overflow: S/W/r/s/d F8
Hot cold reversed: S/W/r/s/d F8
Long drain: S/W/r/s/D F9
yes several of these had identical blinking light combinations, but it is good start.
Apr 21, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My Fisher and Paykel GW709AU starts to fill for 2 seconds and stops. This repeats several times then it stops completely and the alarm sounds. The LEDs that come on are the 3rd and 5th green lights fr
40. (00101000) Bowl Dis-engage Fault
While carrying out a bowl check, the Motor Control Module has found that the bowl is not
engaged even though the pressure sensor indicates that the bowl is empty. The Motor
Control Module continues to check for 2 minutes, after which time it displays this fault. The
first two areas to check are the clutch and the pressure tube. If these two appear correct,
then the fault could be in the pressure sensor in the Motor Control Module.
Primary Source: Mechanical.
Action: 1) Check that there are no clothes or other foreign objects preventing
the clutch from re-engaging. Excessive suds can stop the bowl
rotating.
2) If the machine is empty of water, carry out a clutch disassembly
procedure and check the spline drive.
3) Next check that the pressure tube has not come off and that it is
not kinked.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Jan 26, 2012 | Fisher and Paykel Washing Machines
Hi I have a Fisher & Paykel MW612 top load washing machine. It will start to fill normally on warm wash then the hot stops coming in and the cold fills intermittantly then the whole ting stops and...
Gary - LEDS 00110010 as you have not mentioned the last LED which will be red if on is 00110011
Ok - your code is 50 indictes a faulty hot water valve - question - have connected the hoses correctly - as per your descriptions - it should always be cold 1st then hot water- cold - then hot etc until it fills.
Pays to check this as the fault code is totally opposite to what your saying..
May 01, 2011 | Fisher and Paykel GWL11 Top Load Washer
I have a Maytag Neptune TL (FAV6800AWQ , Serial # 10178127EC) that starts and stops after the wash cycle begins. It fills up fine but starts and stops/pauses and the time doesn’t lapse. On a normal load...
You have a Series 10 machine 1st two digits of your s/n.
Seems like you have the Service Manual or troubleshooting guide.....can't get that from Servicematters any more I feel you have some drive system binding.
I helped a owner on another forum similar problem. Google this "Neptune TL Spinning Issue Will Not Proceed". Did a lot of up front testing in the end he ended up replaceing the Outer Tub Bearings, the Clutch Pulley.
Start by opening the washer lid and see if you can rotate the wash basket with one finger in the CCW Spin direction. There should be only slight resistance to rotate the wash basket CCW. During the 1st water fill of the wash basket the Control Board will spin the wash Basket slow rpm you can enter Service Mode and observe the rpm on the LED console.
Next start a Quick Spin test and note the highest RPM range the machine will spin up to. Looking for Outer Tub Bearing resistance.
I would suggest another DIY forum to work thru this issue if you are going to DIY. This forum is hit and miss we posting pics and e-mail notification for support......Rich
Oct 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a whirlpool awm 8121 6th sense front loader. when i select the cycle, usually rapid, and press the start button the machine commences to fill with water. when it comes time for the actual washing...
If your machine is reasonably old, perhaps take a look at the bushes of the motor . Before that, take the manual and run the test cycles by following the instructions; it might provide you with answers
Oct 14, 2017 | Whirlpool AWM8123 Front Load Washer
Washing machine fills and washes properly then when emptying machine stops then starts does not rinse properly no problems when filling only emptying does not do full cycle beaps constantly with 3 lights...
Hi just read your posting.Now when the machine is beeping the lights that are lit will be in a row of 8 lights,Starting from the left to right which lights are lit when the machine is beeping,Is it the 1st and 5th or the 3rd and 7th ---etc---?Please reply with the additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 08, 2010 | Fisher and Paykel Washing Machines
Maytag Neptune TL starts, fills with water a few sec then clicks loudly a few times and then stops, a few sec later it repeats this, then stops for good. Tried unplugging and restarting, but same thing...
Any error codes?
Do you want to troubleshoot? If so here is the Service Manual.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
I would start by removing the front cover of the machine follow all safety warnings in the Service Manual.
Follow the first few steps in my Clutch Fix post to remove the front cover.
Then let me know if during the water fill cycle the machine rotates the wash basket CCW in a slow spin during the water fill cycle before the machine stops and we will go from there. Give me all the detail you see with the front cover off I need to know if the wash basket is rotating CCW during the washer fill cycle.
You can lift the washer top up a slight amount to observe the slow CCW spin of the wash basket. I’m checking that the outer tub bearings are not seized……Rich
To pump out the excess tub water with this process;
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
This process is documented in the Service Manual. I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Jun 26, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Excellence smart drive fills up with water and then doesn't wash
Hi just read your posting. Now when the machine stops does it sound a beeping sound and a series of lights light up? If it does starting from left to right I need to know what light have come on in the row of 8 lights.Is it the 1st and 5th or 3rd and 7th etc.Please reply 4 further help.
Jun 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a Maytag Neptune FAV6800AWQ Serial Number
Fireman,
Excellent info wish all post would start off like this. The first two digits of the s/n are your series number a Series 16 machine I’m an owner no expert and will try to help.
I assume you have the Service Manual but just in case.
“”I can grab the drive belt and effortlessly move it back and forth-pulley spins and motor spins--Should it move like this?””
There should be slight resistance.
With the front cover off and be careful of the rotating drive belt can you start a Spin Only cycle?
Do you see the Motor rotate the Clutch Pulley assembly CCW? If so the wash basket should spin CCW just raise the washer top and verify the CCW/Spin rotation.
If that works again with the front cover off start a Quick Wash cycle min Soil/Spin settings and observe as the washer. As it fills the wash basket will be rotating CCW don’t raise the washer top to high or you will spray water around.
After the water fill the washer will start to Wash/Agitate. The Motor will rotate the Clutch Pulley CW and the Tumblers will rotate. Do you see this action.
You can go into Service Mode with this procedure and dump the wash water if the cycle fails with this procedure.
Thank you again for the Model number and Serial number…. other readers this is how you post an issue.
Waiting for your feedback………Rich
Apr 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
154 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
