Question about SanDisk Sansa m230 MP3 Player
Unable to delete files and recover unused space
Hi, unfortunately I have acquired a new Sandisk m320 (512MB), I copied some files there, played them, deleted some, added others and it ended up in a very weird state. After deleting all the files, there is no way to copy more that 300 MB of data in there because the disk is full. Apparently there are some files which are not visible but use the remaining 200 MB. If the device had a reset button to delete all the files and left it as it was in the factory I would be able to fully utilize it. I have used any file browser under windows and unix with no success. I have not formatted the device because I'm afraid it will die after. These devices are unreliable, undocumented and lack of good technical support. If only I had known .... Any idea ?
  • 4 Answers
This actually sounds a lot like the problem pointed out in 'can't delete songs on sansa m230', and I'll bet it's got the same solution (you can read my full explanation there, but I'll just give the gist of it here). The Sansa has two USB settings, 'Auto Detect' and 'MSC'; for some reason songs put on it through MSC aren't visible from the computer if it connects later using 'Auto Detect', and vice-versa. As such, try switching the USB setting from one to the other and see if that helps. If it doesn't then I don't know, but my guess is that it will. ^_^;
Posted on Oct 30, 2006
SOURCE:
SanDisk 2GB MicroSD Memory Card recovering data software
Since I was facing the problem when I connected my memory card to the system and accidentally deleted my photos in memory card and came across the recovery software to recover data from memory card and here is download link
Nov 27, 2012 | SanDisk 2GB microSD Memory Card
I'm unable to find some important data stored in my Sandisk micro cruzer. I'm not sure if I accidently deleted it or if it is corrupted. Please suggest if there is a way to recover the files.
If the pen drive is working, the data is there and can be recovered. I think it could be due to virus activity. Some virus make the contents of the drive hidden, thats why user can't see the files and the space available for use is less than the capacity.
It is suggested that go to FOLDER OPTIONS - and select SHOW HIDDEN FILES. It may show the hidden files. Otherwise, you can use any data recovery program to recover the data. Please not that you should not sav/write any data to avoid overwriting the existing data.
Hope this helps!
CreativeTECH
Feb 14, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Sandisk c200 / unable to recover unused space
try a hard drive recovery program,like partition magic or hirens repair disk,some flash drives need to be formated in fat16.not fat32,or ntfs,your computer cant do that,but the right software can,good luck hope this helps
Sep 14, 2009 | SanDisk Sansa c200 MP3 Player
My maxtor external hard drive has done a scheguled Plan b backup but files that I removed from my master hard drive to free up space because I had them saved on my external hard drive are now missing from...
When a file is delete, it's still there on the drive, just as before; all that happens is that the file table marks it as free space and changes its name so it's no longer visible. There are a number of "undelete" utilities available, including several good ones, like asoftech data recovery that helped me before:
http://www.asoftech.com/adr/
Nov 24, 2008 | Computers & Internet
Recovering files
hi! if take backup of your phone in system,you can recover the files! otherwise you can unable to get the files.
it must be deleted.
thanking you!
Jun 17, 2008 | Nokia 6233 Cellular Phone
Problem with My SanDisk Sansa m230
try formatting your device then try to put mp3 files on it. check if it works. on your my computer right click you mp3 device ( it is usually a removable storage) then select format.
Feb 21, 2008 | SanDisk Sansa m230 MP3 Player
LaCie silverscreen Utilities CD-ROM
The OS is hidden in memory, you can clear all files off the machine and it will still work.
The only requirements are the 4 folders:
Firmware
Movies
Music
Pictures
That's it!
New firmware can be found at www.lacie.com
Dec 24, 2007 | LaCie Silverscreen 80GB USB 2.0 - Portable...
Help me fix my Sansa c140
i had exactly the same problem and than i wrote the guys on www.sandisk.com they had my device replaced.
May 15, 2007 | SanDisk Sansa c140 MP3 Player
"formatting problem"
I had a similar problem, I could upload songs, but they wouldn't play and I couldn't delete them. turned out it was cause I didn't have WMP10 installed on my PC, had an older version. the user manual states it only works with WMP10, and after I installed it (just search for windows media player 10 on the microsoft website) I was able to use the synch function in WMP10 and all the songs are playable (I'm listening to an album as I type :D)
Dec 04, 2006 | SanDisk Sansa c150 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
168 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
