My computer doesn't recognize lg dvd/cd rom - Computers & Internet
  • zappa69_247 Nov 07, 2008
    Thanks djbates, the drive only works on boot up. Went to the LG site & they sent me a firmware update, when I try to run it comes up with CD-ROM drive model doesn't match. I'll contact them again & see what gives. Thanks for your time. Cheers, Nick.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
Assuming the drive comes on and spins up, attempt reinstalling the drivers for your specific model and operating system from http://www.lge.com/products/category/list/computer%20products_optical%20storage.jhtml
There are also some firmware updates on the site which may resolve the problem if you changed operating systems.
Posted on Nov 06, 2008
Hi! I have a webcam easyCam Pro HO98669 Ver.1 and my computer doesn't recognise the cd with the driver. What can I do?
Ok it isn't unusual for a CD ROM or DVD ROM to not recognize a CD or DVD insert to it..Ok try this clean the lenses of your ROM using a CD or DVD cleaner disc if you have also try to wept your cd software with a clean dry soft cloth or cotton..If this will not work perhaps you need a new installation cd for your webcam.
Jul 10, 2011 | GE EasyCam Pro Webcam
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Will not recognize cd's but plays and records dvd fine
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device also scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
May 15, 2011 | LG (GDR-8162BI) (GDR8162BI) Internal DVD...
Computer CD-RW
here is your problem - im a expert in cd roms ... put the computer back like you had it
2 download this small file i wrote
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
open the file run it and reboot the computer BINGO it works - this file reset you upper and lower filters in the registry now the cd rom works - let me know
Dec 30, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
MY LG GC-H23N READS CD BUT NOT READS DVD
THEN U NEED A DECODER OR INSTALL A DVD RW..U HAVE ONLY A CD-ROM THERE 4 IT ONLY RECOGNIZES CD'S U CAN C IF YOUR SYSTEM IS ELIGIBLE 4 A DVD PROGRAM BY GOING TO WINDOWS SUPPORT FOR MEDIA OR JUST CLICK ON YOUR MEDIA PLAYER N HIT UPGRADE IF U HAVE MEDIA PLAYER 10 OR LOWER..
Oct 25, 2009 | LG (GCC-H23NB) CD-RW/DVD-ROM Combo Drive
Internal samsung cd-rom sn-124 doesnt recognize cd's/wont work
replace it. samsung cd rom even its dvd writer have lots of problems. sometime they dont want to open unless you leave a cd in it. sometime it doesnt read cd. better change it. get a Sony, LG, Pioneer DVD writer.
Aug 20, 2009 | Computers & Internet
LG DVD-ROM 8160B
If I understand this correctly, you erased a cd of data and want it restored?
If this is true, then I am sorry to tell you that you will not be able to get that cd data back.
Dec 17, 2008 | LG DRD-8160BB (GDR8161BBGDR8162BB) Burner
Cant instal as have no installaltion cd
for all i know cd/dvd rom are automatically detected by windows, so there's no way it wont be recognize by the windows unless you are using win95.
May 15, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
LG recordable no longer recognized by pc
Go to Start/Control Panel/System/ Hardware /Device Manager/DVD/CD Rom Drives
double click on the Icon and click on the driver tab
click then on the update driver.
This will refresh the system.
But of course it may the the device itself that has failed
Only a replacement will cure that.
Dec 28, 2007 | Computers & Internet
The computer read the driver but it doesnt open
It sounds like Vista has recognized the device as a CD-ROM drive, but NOT as a DVD-ROM drive, and the disk you have inserted is a DVD.
Try getting an updated driver and possibly a new firmware from http://www.lge.com/support/software.jsp
If my advice was helpful please vote for me!
Nov 16, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
Computers & Internet Logo
David Payne
David Payne
