Question about Toshiba Satellite Pro M15-S405 Notebook
Help i turned my computer on and there is no start menu, no icons...only my backdrop. Help?
  • SIMONE DARRINGTON May 11, 2010
    Are you using Windows XP or Vista?
  • DEKR
    DEKR May 11, 2010
    you mean you can see the toolbar but no icons
How to connect it to a wireless network do i need a wifi adapter for it or what??
Hello danieljkeena,
"There are (4) four different ways to connect to the Internet.
in the (right "start menu" pane), select the Control Panel 'shortcut'.
Once the next window open; scroll to find,
click on it to open. Next, select to open the "Internet Options."
paul7of9_22.jpg To setup the Internet Connection:
Click on the "Connections" block, click the ("Setup") button,
paul7of9_23.jpg and follow all the instruction carefully.
2) From the "Start Menu" in the (right) menu!
If you have the "Connect To: Icon?
Click on the icon to open; "this will start the setup and connection process."
3) Click on the "Start" button, select to open "All Programs."
Next,scroll to find: the Product's name; example (Toshiba).
Cick to open. "If there is a ConfigFree icon present"
paul7of9_24.jpg Option is available?"
select to open, and click on the Connectivity Doctor.
paul7of9_25.jpg Follow the instructions!
4) From the "Start Menu," click on the "All Programs.
Scoll to find "Accessories," and open.
If you have the [Windows Mobility Center]?
,paul7of9_26.jpg Open the program.
There will be a {Wireless Network} "Turn- on / Turn-off Switch!
paul7of9_27.jpg Important "Always! Click Apply, Ok,
Restart the computer after making changes to the computer."
"If you nedd help with anything else?
Write a 'comment'; I'll be here to assist you!"
"Best Regards"
Jul 30, 2011 | HP Pavilion ze4101 (F4902H) PC Notebook
While attempting to connect to a lan connection, the computer automatically defaults to the work offline selection. Therefore, I am never able to connect to the internet. I tried turning off the work...
Hello brian _I_kilm, there are (4) four different ways to connect to the Internet.
In the (right "start menu" pane), select the Control Panel shortcut.
Once the next window open; scroll to find,paul7of9_21.jpg Network and Internet,
click on it to open. Next, select to open the "Internet Options." paul7of9_22.jpg
To setup the Internet Connection: Click on the "Connections" block, click the ("Setup") button,paul7of9_23.jpg and follow all the instruction carefully.
2) From the "Start Menu" in the (right) pane, if you have the "Connect To: Icon, click on the icon to open; "this will start the setup and connection process."
3) Click on the "Start" button, select to open "All Programs," next scroll to find: the Product's name; example (Toshiba), click to open. "If there is a ConfigFree icon present? paul7of9_24.jpg Option is available?"
Select to open, and click on the Connectivity Doctor,paul7of9_25.jpg follow all instructions thereafter.
4) From the "Start Menu," click on the "All Programs" scroll to find: Accessories.
Select to open and check to see if you have the paul7of9_26.jpg [Windows Mobility Center]?
Open the program. There will be a Wireless Network {Turn-on / Off} Switch. paul7of9_27.jpg
  • Important "Always! Click Apply, Ok, and Restart the computer after making changes to the computer."
Did this solution help? If so; "helpful Rating Feedback is appreciated, thanks paul7of9.
Feb 15, 2011 | Toshiba Satellite P105-S6197 Laptop
How do I turn my wireless capability on?
  • Hello david_pat113, there are (4) four different ways to connect to the Internet. 1) To start, click on the "Start" button, paul7of9_20.jpg in the (right "start menu" pane), select the Control Panel 'shortcut' once the next window open; scroll to find, Network and Internet,paul7of9_21.jpg click on it to open. Next, select to open the "Internet Options." paul7of9_22.jpg To setup the Internet Connection: Click on the "Connections" block, click the ("Setup") button,paul7of9_23.jpg and follow all the instruction carefully. 2) From the "Start Menu" in the (right) pane, if you have the "Connect To: Icon, click on the icon to open; "this will start the setup and connection process." 3) Click on the "Start" button, select to open "All Programs," next scroll to find: the Product's name; example (Toshiba), click to open. "If there is a ConfigFree icon present" paul7of9_24.jpg Option is available?" select to open, and click on the Connectivity Doctor,paul7of9_25.jpg follow all instructions thereafter. (4) From the "Start Menu," click on the "All Programs" scroll to find: Accessories, select to open: if you have the [Windows Mobility Center],paul7of9_26.jpg open the program; there will be a Wireless Network 'Turn-on and Off Switch"paul7of9_27.jpg Important "Always! Click Apply, Ok, and Restart the computer after making changes to the computer." "Did this solution help?" If so, "helpful Rating Feedback appreciated, thanks paul7of9."
Jan 31, 2011 | Computers & Internet
I can not use the internet on my toshiba lap top how do i fix this?
  • There are (4) four different ways to connect to the Internet. 1) To start, click on the “Start” button, in the (right “start menu”pane), select the Control Panel icon once the next window open; scroll to find, Network and Internet, click on it to open. Next, select to open the “Internet Options.” To setup the Internet Connection: Click on the “Connections” block, click the (“Setup”) button, and follow all the instruction carefully. 2) From the “Start Menu” in the (right) pane, if you have the Connect To: Icon, click on the icon to open; this will start the setup and connection process.” (3) Click on the “Start” button, select to open “All Programs,” next scroll to find the Product’s name example (Toshiba), click to open. “If there is a ConfigFree icon present” Option is available?” Select to open, and click on the Connectivity Doctor, Follow all instructions thereafter. (4) From the “Start Menu,” click on the “All Programs” scroll to find Accessories, select to open: if you have the Windows Mobility Center, open the program, there will be a Wireless Network ‘Turn-on and Off Switch Important Restart the computer after making changes to the computer.” “Did this solution help?” If so, “Ratings appreciated, thanks paul7of9.”
Feb 21, 2010 | Toshiba Computers & Internet
What will i do when i'm having problems connecting to internet through the wireless network
  • There are (4) four different ways to connect to the Internet. 1) To start, click on the “Start” button, in the (right “start menu” pane), select the Control Panel icon once the next window open; scroll to find, Network and Internet, click on it to open. Next, select to open the “Internet Options.” To setup the Internet Connection: Click on the “Connections” block, click the (“Setup”) button, and follow all the instruction carefully. 2) From the “Start Menu” in the (right) pane, if you have the “Connect To: Icon, click on the icon to open; this will start the setup and connection process.” 3) Click on the “Start” button, select to open “All Programs,” next scroll to find: the Product’s name; example (Toshiba), click to open. “If there is a ConfigFree icon present” Option is available?” select to open, and click on the Connectivity Doctor, follow all instructions thereafter. (4) From the “Start Menu,” click on the “All Programs” scroll to find: Accessories, select to open: if you have the Windows Mobility Center, open the program; there will be a Wireless Network ‘Turn-on and Off SwitchImportant “Always! Click Apply, Ok, and Restart the computer after making changes to the computer.” “ Did this solution help?” If so, “helpful Rating Feedback appreciated, thanks paul7of9.”
Feb 19, 2010 | Toshiba Satellite A25-S207 Notebook
How do I change the backdrop on my palm tx??
There isn't much you can change on your palm tx for a backdrop. When you are on the page with all the icons use your stylus and tap on "Preferences" From there tap on "color theme"
That will allow you to choose a color theme for all your pages but as far as a backdrop goes you won't be able to set anything on it as far as I know. Best wishes.
Sep 17, 2009 | Palm TX Handheld
Can't get past black screen and mouse
Power off your computer, then power on hitting F12, del or whichever key it states to go into setup. From the setup menu, select change boot order or boot menu. Set the CD ROM to the first boot device. Save changes. Restart. Your computer should boot to cd starting the installation.
Feb 06, 2009 | Dell Inspiron 1501 Notebook
Start menu toolbar does not appear on desktop
check this out maybe it can help..
in the desktop..put the cursor and right click-properties-select desktop-customize desktop-check the desktop icons you want..and click ok...just try maybe this is only you want..
Jan 04, 2009 | Toshiba Satellite A75-S213 Notebook
Taskbar and Desktop icons flash/flicker on and off and don't allow her to open the Start menu or click any of the icons
restart computer and keep tappig F8 when
select safe mode from advance menu
*select win xp os
*get into safe mode and check
if u dont have any issue
then click on start->run->msconfig
click on selective startup
uncheck load startup items
click applay
click close
reboot and chack
if same problem
reboot computerr in safe mode
create new user acount
Feb 18, 2008 | Lenovo 3000 C200 Notebook
Bad Image
use xp cd boot in repair it or redo format fresh copy on
Jan 25, 2008 | Acer Aspire 3680 Laptop
Toshiba Satellite Pro M15-S405 Notebook Logo
51 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
