Question about HP Pavilion dv4000 Notebook
HP ze 4900
Daft question:- How do I enable the wi-fi. Idon't see any switch or symbol. Thank You.
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    have checked the HP wireless assistant on ur laptop?there should be a switch or something in the side
    Genius:
  • HP Master
  • 1,250 Answers
Check on the device manager , if the driver for wifi are installed or not , if installed then , press the Fn key alongwith the Key that marked wifi mark on your laptop
Posted on Nov 06, 2008
No wireless working
enable it from the bios ,,, enable it pressing the wi-fi key ,,, replace the wireless card or switch the antenna cables connected to the wi-fi card ...
it would be much better if specified a model ,,,
Mar 06, 2012 | HP Pavilion 1137NR Notebook
How do you get the wi-fi on the ds
To set up a Wi-Fi connection on your DS Lite you have to use a Wi-Fi enable DS game. Wi-Fi enable DS games have a Wi-Fi symbol on the front of the box it came in. Simply play the game and you should see options to set up a Wi-Fi connection.
Apr 21, 2011 | Nintendo DS Lite Console
I have a HP 110 1115SA netbook. It's telling me to switch the wireless button on but I have no idea where it is. Can you help at all? Thank you, Mary
its the wi fi button which is present at the top the symbol is "i" press this button u will be switching on the wireless button
Oct 10, 2010 | HP Computers & Internet
Where is the logo of wi-fi in hp probook 4410s........ how to enable or disable it........
On some HP laptops there is a smooth illuminated strip that you think is just lights but it's actually touch sensitive. there could be a WiFi symbol there which you should touch to turn it on.
On others it's a fn key over the F12 key.
May 21, 2010 | Computers & Internet
How do I enable wifi ? I'm new to computers so don't undertsand them very well. I have a Samsung NC10 & want to enable WIFI - but how do I do it?
1. First look for the Wi-Fi (Wireless) Switch on the Laptop (it may be on the front or sides of your laptop) [Its symbol will be like a 'Tower' or 'Antenna').
2. Turn it to ON position (a red or blue light will blink).
3. Now, switch ON your Wi-Fi router modem provided by your network operator (also check the connecting wires between router and phone jack).
4. System will automatically detect the network.
5. If not seach your Wi-F- network through :
Start -> Connet To ->Search/Refresh (a list of services will come).
if it helps tell me...tc! :)
Jan 03, 2010 | Samsung NC10-14GW Notebook
Can not detect wireless network on wifi enabled
Make sure on laptop wi fi switch is turn on.
Uninstall wi fi network adapter driver then reinstall.
Right click on my network places and click on property then right click on wi fi adapter and enable it and click on view available wi fi networks .
If you still not detect signal of router then You hav to reset router.
For thjat press RESET button for 10 seconds it is in back panel of router.Then it defaults.
then connect router to computer with ethernet cable then you can access it with below link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page.
Then set WAN settings as your isp.
GO to wireless settings and enable it .
If you want to secure enable WEP security and add wep code.
Enable DHCP.
Then save and restart router then check.
Let me know if you need further assistance.
Thanks.
Oct 28, 2009 | HP Compaq nx9020 Notebook
I dont know how to turn my wi-fi on on this labtop
look around ur laptop, there should be a button key or a switch 2 turn it on. if look on the bottom right on ur taskbar, there might be an icon for ur connections e.g. bluetooth, wlan, wi-fi etc. see if u can switch it on from there. if u still can't do it take ur laptop 2 a pc world center and they might be able to help u. i hope dis helped =)
Aug 26, 2009 | Everex StepNote NC1502 Notebook
I have an HP Pavillion DV4000. My built in wireless is not working. The light at the top of the keyboard does not come on. How do I get it to work?
you can see the wi-fi switch...you turn on and it will work if you install already the wireless driver...its only the problem with the switch combination between wireless..there some option also for enabling the wi-fi...you can press FN key + wi-fi botton.
Jan 28, 2009 | HP 14.1 Refurbished Thinkpad, 1.13GHz...
CTX Optoma EzPro 580
Hi, Optoma USA recommend that you set the PC resolution to SVGA (800 x 600) or XGA (1024 x 768). Your HP Pavilion ze 4900 default resolution is S = SXGA (1400 × 1050) or X = XGA (1024 × 768). I would assume that your cable(s) are properly mated/attached from the laptop to the projector. If on pressing TV Now! One-Touch button with a TV icon at the top of your keyboard to switch the display to the TV-Out mode, there is no picture projected, you can try to manually lower the screen resolution of your PC. Try lowering it to the 800 X 600 setting in your Display Properties. Also, you may want to check if the Dual Display Mode is enabled/activated. You can try different resolution setting as long as the projector can handle it. Hopes this works and give you an idea. Should you need more assistance, pls post/comment. Good luck and kind regards.
Aug 11, 2007 | CTX Optoma EzPro 580 Multimedia Projector
HP iPAQ 3715 - screen problems
Return it as faulty. WiFi should not impact your screens ability to stay on.
Sep 08, 2005 | HP iPAQ RX3715 Pocket PC
HP Pavilion dv4000 Notebook Logo
112 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
