Question about Cameras
Focusing ring looseness on 50/1.2 M-Hexanon
Sorry, this is not a digital camera but an interchangeable lens for a Konica Hexar RF 35 mm film rangefinder camera. The focusing ring has about a 1/10 mm play or looseness but the optical unit within the focusing mount appears properly tight with no play. There are no external screws that can be tightened and removing the bayonet flange from the back of the lens reveals no obvious means of adjustment.
  • alweyedoc Nov 06, 2008
    Sorry, your telling me something I already know. Konica is out of the camera business and there are no authorized service centers for this item that I know of.
    Brigadier General:
  • Cameras Master
  • 3,614 Answers
Did you see any rubber gasket on the ring.. this could be the one turn out to be loosen,
did you dropped or any kind of incident happened on the lens.
Posted on Nov 06, 2008
  • micromaster
    micromaster Nov 06, 2008
    yah it seems that it was mechanical problem. it was advisable that you seek on a authorized serviced to to avoid further damages.
Film release button is stuck
Hi,try putting a bit more tension on the film using the winding crank & it may enable the button to depress,regards,dave
Apr 16, 2014 | Vivitar Konica Autoreflex T W/hexanon F1.8...
Can i use tamron 90-300 mm af macro on my minolta 404 si dynax ?
Tamron makes lenses with a variety of lens mounts. If the lens has a Minolta mount then yes, you may use it with your camera.
Sep 21, 2013 | Konica Minolta Minolta Dynax 404 Si 35 Mm...
HEXAR RF - I WAS CHECKING THE SHUTTER SPEEDS AND THEN THE SHUTTER STOPPED WORKING AND THE NUMBER 11 NOW SHOWS UP AND BLINKS IN THE FILM COUNT INDICATOR
The Hexar RF is a very expensive film camera with an electronic shutter. Make sure the battery and contacts are clean. Remove the batteries and see if that resets the camera. If not, it is time for professional repair. This camera takes high quality Hexar lenses in a KM mount. This is not an old camera, so repair should be easy.
Oct 23, 2010 | Konica Hexar RF 35mm Rangefinder Camera
I'm having a problem with my Konica Hexar RF. Today I was shooting , the camera was working fine, then '10' appeared on the top screen. Now it wont work at all. I just see '10' even with new batteries.
It seems a common error with this film camera. There are parts, but they are replacing the entire shutter at times from the research I have found. That can be an expensive repair against the cost of a different camera. Rangefinder used to be extreamly reliable, it seems this model had production problems.
Aug 09, 2010 | Konica Hexar RF 35mm Rangefinder Camera
I'm not really familiar with camera lens i'm just going to write what is written on the lens KODAK RETINAR Aspheric lens 35-105 mm (Equiv) af 3 x optical zoom please tell me how to repair the lens
sounds like the lens on a Kodak point & shoot digital or older film camera- if it is either it isn't worth your effort (unless you want a new hobby)- Sorry, but you should find another camera on eBay
Apr 26, 2010 | Cameras
I have a Maxxum 7000i 35mm camera and in the display there is the word Help flashing what does this mean This happend after i tried a differnt lens, the lens opened than closed The lens that i tried was a...
Konica lenses do not fit Minolta cameras. I think you messed something up.
Minolta MC and MD lenses worked on the older manual focus Minolta bodies. They will also work on the Phoenix and Seagull clones of the old Minolta bodies.
The Konica lens should only ever be mounted on a Konica camera.
Your 7000i is now a Minolta paperweight. You need to send your 7000i for repair or replace it.
You could also look on Ebay for another Maxxum body to use your lenses designed for the Minolta A mount. As a rule, camera lenses are not interchangeable. You can use any Maxxum lens on any Maxxum body as a rule, but Minolta changed their flash shoe after the original 7000 series. Flashes that work with your 7000i will work with any subsequent Maxxum.
lightspiritphotography.com
Oct 25, 2009 | Minolta Maxxum 7000 35mm SLR Camera
WHICH LENS WILL GIVE THE SAME RESULT OF 50 MM LENS IN FILM MODEL
To figure the equivalent coverage comparable to a film camera, multiply the number of mm by 1.5. Example: a 50mm lens will be like a 75mm lens on a digital camera.
Sep 08, 2009 | Nikon DSLR D90 Digital Camera
Aperture ring
Yeah sorry, that's what i meant, Nikon.
Try to clean lens contacts on the camera with alcohol.
Mar 25, 2009 | Nikon D200 Body Only Digital Camera
EEE error on my Konica Hexar AF
If you are using Windows xp , download the UVC driver update from http://www.microsoft.com/downloads/deta … laylang=en.
If that is not enough follow the threads below about EEE and USB drivers.
EeeUser ASUS Eee PC Forum
EeeUser ASUS Eee PC Forum / Camera drivers
Nov 25, 2008 | Konica Hexar Silver 35mm Point and Shoot...
Focal length equivalents
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}I believe it is equivalent to a 35 to 210mm lens on a 35mmcamera. If you are considering a Nikon such as the D60, D80, D90, etc.,the standard lens sold with the camera is 18-135mm. This is not the sameas an 18-135mm on a 35mm film camera. The equivalent 35mm film cameralens would be 27-202mm (you multiply by 1.5), about the same as what youhave now. If I were planning to do wildlife photography, I would buy a usedNikkor ED 70-300mm AF lens on E-bay. You should be able to get one for$200 or less (the new price is $550+). This lens is designed for a 35mmfilm camera and is the equivalent of a 105-450mm when used on a Nikon digital cameras. Additionally, it is compadable with the automatic features of the Nikon digital camera bodies. This would give you an excellent portrait lens at 105mm and extra long reachfor wildlife. The fast shutter speed and stabilization circuit on thedigital camera should make it usable in daylight without a tripod. I havethis lens on a Nikon film camera and it is a superior lens. At a 1/1000second or faster shutter speed, I get sharp hand held photos.
Nov 17, 2008 | Fuji Cameras
Cameras Logo
157 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
