Question about Aprilaire 600 Humidifier
Changed filter for Aprilaire 600, but water doesnt flow now, how correct?
My husband is disabled so I am trying to do things myself., now, we are both seniors. I changed the filter (water panel). but the water wont flow, I think I did everything right.
the only thing I couldnt do was "turn the water off" (how do you do this? no instructions in booklet). and "turn the water on".
the water was flowing before I changed the water panel, but now it isnt, Any suggestions?
thanks, Nancy in OHIO
ps I followed everything the booklet says to do, except 'water off" and water on. Dont know what else to do. Dont want to spend a fortune having repair man come to house, when it could be simple solution
    Problem Solver:
  • 15 Answers
YOU SHOULD HAVE BETWEEN .250 TO.375 INCH WATER LINE ENTERING YOU'R HUMIDIFIER .THIS WILL TERMINATE AT A FLOAT VALVE.THIS IS MUCH LIKE THE VALVE IN YOU'R TOLIET.TRY PUSHING THE ARM DOWN,THIS SHOULD LET WATER INTO THE HUMIDIFIER,AS PULLING UP SHOULD SHUT IT OFF.IF THIS DOE'S NOT WORK THEN THERE (SHOULD BE A VALVE BETWEEN THE HUMIDIFIER & THE SOURCE)MOST LIKLY LOCATED NEAR YOU'R HOT WATER HEATER.MAKE SURE THIS VALVE IS ON!!! IF I'M RIGHT YOU MAY HAVE JAMED THE FLOAT IN THE OFF POSITION WHILE REPLACING THE FILTER HOPE THIS WAS SOME HELP>
Posted on Nov 06, 2008
Coating from water panel pad clogging furnace filter
I know of no answer to this except to remove the coating manually to prevent it clogging you filter.
Jun 22, 2017 | Aprilaire 600 Humidifier
Should water be continualing running through the drain tube?
Water will flow over the filter pad as long as the unit is calling for humidity. once the unit is satisfied the solenoid valve should stop the water flow. if the water continues to flow with out call then solenoid valve has failed open. hope this helps.suppling an owners manual in case you need one.
http://www.aprilaire.com/themes/aa/en/manuals/AA-Humidifier-Owners.pdf
Dec 21, 2010 | Aprilaire 600 Humidifier
Aprilaire 600 humidity level too low
The max the aprilaire can put out is 45% Rh. Your humidifier may wired up to run only when the heat is on. In some cases this is not enough time to maintain your humidity level your seeking. To correct this, the hum. has to hooked up the hot side of the water supply. And the humidifier has to be hooked up when the fan runs and leave the fan run constantly
Jan 12, 2009 | Aprilaire 600 Humidifier
The water flow valve doesn't seem to be letting water through to
http://www.aprilaire.com/themes/aa/en/manuals/600a.pdf Read page thirteen and there is a inlet water filter that may be cloggeed. Let me know if you need anything else.
Jan 11, 2009 | Aprilaire 600 Humidifier
Aprilaire 600: water only runs in "Emergency" Heat mode
When your unit is on normal the outside unit works and the inside only the fan runs. your heat pump does not remove any humidity when it operates so the installation cotractor did not wire it to operate then. you can change the wiring on the humidifier to operate all the time by wiring it to the fan (g) terminal then it should work just turn it all the way to the lowest humidity when you are in cooling mode.
Jan 07, 2009 | Aprilaire 600 Humidifier
Orifice clogs to Aprilaire 600
http://www.aprilaire.com/themes/aa/en/manuals/600a.pdf look at page thirteen in this manual there is allready a inline filter on the unit. hope this helps
Jan 06, 2009 | Aprilaire 600 Humidifier
Solenoid on Aprilaire 600
solenoid valves dont just burn up just like that you have a recurring restriction due to bad water.Check the saddle valve at the water heater first then check for postive water flow at inlet to the solenoid valve,if you have water flow the valve is clogged with sediment.
Dec 13, 2008 | Aprilaire 600 Humidifier
Aprilaire 600 bypass water flow rate
The water is only dispensing over the evaporator pad while the furnace is in the heating mode. When the furnace finishes cycling the humidifier will also stop.
Mar 04, 2008 | Aprilaire 600 Humidifier
Aprilaire 600 - change water panel light stays on
Turn the control knob to the test/reset position untill the change water panel light blinks to reset the change panel timer. Make shure the furnace is running calling for heat.Turn control knob to prior setting after resetting timer. Hope this helps.
Feb 16, 2008 | Aprilaire 600 Humidifier
Aprilaire 600 Humidifier Logo
141 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
