Question about HP Color LaserJet 2600n Printer
Grainy printing down left side
My page looks very grainy down one side
i ahve checked cartridge levels and they are at 70%
But each page looks like this grainy white strip in the colours...
Thanks for any input!
kyalami@iinet.net.au
  • 24 Answers
Toner cartridges have the shortest life in the laser printer. So for every image quality issue try replacing that color that you see the defects in.
Posted on Nov 06, 2008
Why are my labels coming out grainy while printing?
check your ink status.You may be needing more ink. Follow the instructions when putting new ink in and do a test page.That might help
Apr 03, 2016 | Kodak Office Equipment & Supplies
HP 425N PRINTER NOT PRINTING CLEARLY
Sounds like a bad toner cartridge or a bad fuser. Try a different cartridge and also try running a cleaning page.
Sep 20, 2014 | HP LaserJet 4250n Printer
Grainy prints
If the print head is not located in the cartridge then you need to clean the print head as there can be stuck nozzles or debris attached to it that cause a messy print.
Jan 11, 2013 | Ricoh Corp Aficio GX7000 GelSprinter Print...
I have a HP 7590 printer and it sometimes skips line or some of the lines are faded when printing black .
Perform the following steps to reduce or eliminate faded or grainy lines:
  1. Print at a higher quality setting.
  2. Verify that the paper you are printing on will lay flat. Paper that is not laying flat can cause banding when the paper transitions over the rollers or cause the print cartridges to scrape across the surface of the page. Check the top sheet of paper by removing it from the all-in-one and placing it on a flat surface. If the paper does not lie flat, bend it in the opposite direction to straighten it. Figure 3: Faded or grainy bands in print caused by paper that is not flatc00178858.gif 1 - Faded or grainy bands due to roller transition with paper that is not flat. 2 - Faded or grainy bands due to print cartridge scrape on paper that is not flat
Jan 06, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
Printed images are grainy? especially the skins. any solution
This could be caused by a couple of things. The first one is the toner cartridge. A defective or low toner cartridge can cause light "grainy" looking copies. If you have a spare toner cartridge try that first. The second possibility is dirty scanner optics. The scanner bar that lights up under the glass and moves back and forth has 3 mirrors on it. When they get dirty is causes your scanned image (before it gets copied) to appear light and patchy looking. The glass must be removed by removing the 4 screws on the left hand side. Then the scanner can be pulled out and the 3 mirrors cleaned. If you have the machine hooked up to a computer to be able to print then these mirrors will NOT affect PC prints. If PC prints are grainy then that would point to the toner. The dirty mirrors will only effect the copies.
Good Luck and Thank You for using Fixya.
We are having a contest this month that is based on positive testimonials. If my solution is helpful please leave a short testimonial for me.
Thanks!
Oct 06, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
What image resolution should i be using for regular 4x6 prints i have a 10.1 megapixel camera, but my pics still look grainy
Your pictures should not be looking grainy. Are they printed grainy but look clear on your screen. If so then it's just your printer. Try forcing the flash in the highest resolution. If you video's are grainy too then there is possibly something wrong with your camera. Make sure your lens is really clean. Worst case your CCD sensor inside your camera could be bad. Hope not!
Sep 20, 2010 | Casio EX-Z1050 Digital Camera
Poor print quality
if cartridge and drum did not solved this problem, this meant that problem lies with mirror or tracking system and repair that bits is usually beyond home user.
firstly try to check and clean all rollers and traction system, work from tray catcher up, follow paper trail and check for stuck hair, bit of paper or any other debries, clean all rollers. then follow paper procedure below:
as this is easy, create a page of white and black about 10mm lines and then print full page on 120g watercolour paper (this is bit grainy paper which will work as "scrub" of the system), this will remove if any, debris from transfer drum in most cases.
if these solution do not work, if you game, remove back, mark all wires where they go, then remove motherboard panel, mark mirror position, clean it up and this will solve the greyness problem, or kill the printer totally...
Jul 20, 2010 | Brother HL 5250DN Laser Printer
The printer will only print in black and is very grainy.
first of all check what is the ink level in the cartridge >> disconnect the power cable from the printer and try to turn onn the printer and after that reconnect the poer cable and turn onn the printer >> try to print if the same thing happens >> take out the cartridge and clean the copper contacts in the cartridge and reinstall the cartridges >> it will print an allignment page and check in the page whether all the colours are there and are they solid if they are not solid >> directly disconnect the power cable from the computer >> try with a new set of cartridges and if the same issue persists it is the problem with the printer call hp they should replace the printer if it is in warranty and if the issue is resolved call hp they will replace the ink cartridges ........... thank you
Oct 13, 2009 | HP Photosmart C6280 Printer
Photos being printed are grainy and not sharp
Hello sir; I believe you need to clean up your printer the method as follow;
power on the machine, open the cover,when cartridge move to the center UNPLUG the power cord, then you can manually push cartridge all the way to the opposite side of the cartridge seat, now you can clean up cartridge seat by Q-tip with water, sometime you'll find a ink stick sitting in the cell, remove it.
Jan 02, 2009 | HP PSC 1610 All-In-One InkJet Printer
Grainy and pixelated print
Check to see if you have Grey scale or Black and white
Jul 15, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
HP Color LaserJet 2600n Printer Logo
113 people viewed this question
Ben Johnson
