Question about Panasonic PT-56HX41 56" Rear Projection Television
TV comes on then goes off.
I tried to turn on my set with no luck. I unplugged the tv and it came on but only long enough to get sound and then turns off again. Unplugging the set allows me to repeat the problem but has not corrected it, any suggestions.
    Sergeant:
  • 337 Answers
The unit is sensing a problem and thats why it turns itself off,if you are familiar with tv service you can check the output transistor for a short ,this is a good place to start,this will involve checking the component with a meter if is bad it will have to be replaced with the same type,if the transistor is changed and it fails again the set might also need the output transformer(flyback)all this checking has to be done with set unplug,if you are not too familiar with tv's be safe and call for assistance from a servicer this is the high voltage area and is dangerous.
Posted on Oct 11, 2006
  • Omar Urrutia
    Omar Urrutia Oct 11, 2006
    The rating response is important for the person helping you
What should I do in order to get the sound to turn back on my Vizio VX20L TV?
Have you tried the user manual? There may be a setting in the menu indicating whether to use internal speakers or some other device run through say, a cable or HDMI output, or turn off sound for those using a cable input to the TV from say, a cable box, but the sound goes to a separate sound system.
Also check that there is sound coming INTO the unit from your cable box if you have one and use RCA cables. If using HDMI input, there may be a menu item as well, to control whether to use input or not, as some people will have the cable box send the sound to a sound system instead of the TV.
Oct 26, 2014 | Vizio VX20L 20 in. LCD TV
Sony FD Trinitron WEGA
Here's my suggestion , unhook all the external components to the TV and leave the TV unplugged for more than a few minutes (a day/overnight). The next day plug the TV into the wall outlet (not the powerstrip) without anything hooked up to it, and turn it on. See if it comes on. Sometimes unplugging for a few minutes/hours is not long enough for it to reset itself.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
On/off problems with my LG 37LC7D TV. It is hooked up to Direct TV
You need to contact a local TV repair service, UNLESS you have the tools and the repair manual to repair it yourself, it will take diagnostic work to determine what is the cause, one thing is for sure you have a defective circuit board.
Jul 16, 2017 | LG 37LC7D 37 in. LCD HDTV
I have a Sony Bravia 45" Flat Screen, it turns on but there is no sound.
Tries tv and cable or satalite boxes unplug,replug it back like about an hour later.Than tries goes into the tv Menu go into Audio Setting and do a resetting back to the factory setting.Follow these steps,should help ur tv sound to come back.
May 30, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a 42" Prima
Hi Howard,
It sounds to me the Power Supply Board is bad. You will need to get the numbers off the original board by taking the back off the set ( After unplugging the set of course) and the you can contact a board company ( Encompass Parts Distribution ) or any other company that you might find on the internet with your google search engine and order the board. Good luck with this problem.
Ed " Original Radio Man"
Nov 20, 2010 | Televison & Video
Tv comes on just the sound about three seconds later tv shuts off
I have the same issue with mine and have a solution that sometimes works. I had a repair guy come to check it out and he powered off the TV so that the red light was no longer blinking, then he unplugged the TV for about 30 seconds or so and then plugged it back in. He then turned on the TV and it worked. He said it would cost about $400 to fix the issue (some circuit or something). I have since expeerienced the on/off problem (due to power outage) and now I cannot get the TV to work. But at least give this solution a try and please post to let me know if it worked or not. Good luck!
Dec 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
Wont turn off, goes to magic focus
enter your menu set up and turn off auto focus and see what happens then,also check your other settings while your there.
Sep 09, 2007 | Hitachi 51F500 51" Rear Projection...
TV makes a repeated cricket sound and won't turn on.
It means that the TV set has a short in it somewhere. The sound you hear is the power supply trying to start up and shutting down. Most likely the Horizontal output transistor shorted because of a bd high voltge flyback transformer went bad. Common problem for these types of sets. Good Luck
Mar 25, 2007 | Memorex MT2271 27" TV
The unit is going in to shutdown. Sounds like you have a short in the high voltage section.
Feb 18, 2007 | Panasonic PT-53WX52 53" Rear Projection...
Panasonic PT-56HX41 56" Rear Projection Television Logo
60 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
