Question about Dryers
Creda advanced t601cw leaking from back - Dryers
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
This could be a pipe of or the condenser is blocked but this might be helpful as well thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
You-Tube video "ymXmpyVkxIE" placeholder (do not delete)
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
Posted on Jan 10, 2010
Creda T601CW 6Kg Advance Condenser Dryer The belt
Creda I don't know from. Sorry
Nov 20, 2011 | Dryers
Creda W220VW front loading washing machine leaking from bottom of casing. Hoses seem OK, coluld filter need cleaning? If so, how do I access?
Check water flow rate into soap drawer , if very fast water can overflow and run down back of fascia panel and out underneith
Nov 01, 2009 | Creda W120VW Front Load Washer
I have had my Creda 1000 Supaspeed- Economy Plus for about ten years. Just one week ago the program panel stopped advancing at the end of first rinse with all the water still in it. I turned it off and...
Crea8tivefeng,
I wish I could be of some help but the same thing just happened to me! I have also had this washing combo for almost ten years. I haven't yet tried looking at it as it just broke. I can be handy but I have never looked at a washing machine before. With out looking at it I wonder if it could be a belt not letting the spin cycle work. Maybe the dial is broken? If you have found a solution to the problem I would love to hear back from you.
Derek
Oct 07, 2009 | Creda W100FW Front Load Washer
CREDA TCR2 TUMBLE DRYER
put it in the bin
Sep 12, 2008 | Dryers
Creda tumble dryer repair
with great difficulty - these belts are so tight!there is a special tool for doing it but there are other ways
one way i have used is to make a spanish windlass from belt to bottom of machine. when belt is level with motor spindle, push belt on and release spanish windlass. could also try levering belt on with a screwdriver
another method is to get a short piece of tubing that will fit over motor spindle. put belt over tube, lever down and slip belt on. this is the best way
Jul 20, 2008 | Dryers
Creda t601cw condenser dryer
hi sounds like your belt has snapped or drum has snapped from the shaft regards jason
Jun 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Dial keeps turning and clicking
sue worth having inlet valve checked also have heater checked at same time ! is the machine draining ok !! if not there could be blockage in drain system or faulty pump good luck- regards bob btw
Feb 26, 2008 | Creda IWD12 Front Load Washer / Dryer
Creda machine won't agitate with clothes in it
Your load is prob to heavy for the older washer. it just doesnt have the power to handle it no more. time to replace it, sorry.
Jul 30, 2007 | Creda W120VW Front Load Washer
Dryers Logo
264 people viewed this question
Top Dryers Experts
