Question about Mitsubishi VS-50605 50" Rear Projection Television
VS-50605 (mitsubishi) You can hear a highvoltage chirp (clicking sound)over and over and over and over.. you can see the crt tubes flicker. Like its trying to turn on... May be the sound of relays firing... Any suggestions on what components to try changing? I metered out the 2 Horizontal transistors and they seem to be ok. I think I'm going to try to change out the Vertical IC.. and go from there. Any and all help and suggestions would be greatly appreciated Meltrex
  • Benny Mathis Oct 11, 2006
    I cannot find IC401, is it possible you meant IC501???? I found the c920 cap.. Thanks in advance
    President:
  • 3,130 Answers
Yes sir change IC 401 and dont forget to change C 920 also. This is a very common problem with this set. If you do not change the capacitor, the IC will fail again in a few weeks or days. PS Dont forget to rate this.
Posted on Oct 11, 2006
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Tv problem
bias on green is too high or current is too high^^^turn bias down on focus block^^^--curved lines(not retrace lines) convergance IC`s going or resistor(s) out of range^^^replace them^^^
Sep 10, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitusbishi vs 5041
Good Day, rob;
More than likely you have CRT coolant (fuild) on the board(s). Check this by removing the TV's speaker grill, the small panel and look for the fluid using a bright light. It's not always easy to see, if fluid is found remove it with acetone and use heavy plastic and drape loosely over the board in the front. Always remove POWER from TV BEFORE ATTEMPTING ANY SERVICE. Good Luck, big IRISH.
Aug 17, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS 5041 rear projection
if it has been four years since the set has worked you are going to ned all three CRT's I'm afraid, the tubes will go soft just from sitting and not being used. also I bet there are a ton of bad capacitors in this Tv set now also.
Jun 16, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 - Colors separated
You have a convergence problem and need to reset
Nov 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS50705
send the board in to ptscorp.com
Oct 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi
Practice visual acuity technique!Examine signal pcb for evidence of CRT coolant leak.Usually circuit board can be cleaned,then replace leaky CRT--at least one w/bad seal.
Sep 28, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Vs-50605 Mitsubishi
Infrared pcb is located inside mirror cavity mounted to CRT support frame.Follow lead to signal PCB--is it plugged in,to the correct location??----Then suspect bad infrared detector PCB.Or,possible bad signal PCB.
May 27, 2007 | Mitsubishi VS-50605 50" Rear Projection...
VS-50605 (mitsubishi) techman please read
Possible IC301, NOT possible IC501. Consult schematic diagram.
Oct 12, 2006 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
57 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
