Question about Toshiba Computers & Internet
I need to set up my wireless function - Toshiba Computers & Internet
    Problem Solver:
  • 15 Answers
Posted on Nov 06, 2008
How can I enable radio function on my N300 wifi adapter
TO turn on the radio, go to Advanced menu and click Wireless Settings. The Enable Wireless Router Radio box must be checked to enable wireless function on the router. If you have a newer router and it has a Genie UI, click on the ADVANCED tab > Advanced Setup > Wireless Settings. Hope it helps.
Oct 26, 2014 | Computers & Internet
Connect a wireless printer to a compaq presario 2200
Even though it is a wireless connection sometimes you need to connect it to the printer to set up the wireless function. then follow the instructions for setting up the printer.
Mar 21, 2012 | HP Compaq Presario 2200 Notebook
Can I set up this wireless router if I have a cable connection and not DSL?
You can use the wireless functionality of it as a wireless bridge into your network - just disable the DHCP and NAT functions in the unit first.
Aug 08, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
I have sony vaio S. but the wirelees is not working no wireless host shown. how can i fix it?
Selecting the wireless function Follow the steps below to select the wireless function to be activated when you set the WIRELESS switch on your computer to on. Double-click (wireless switch icon) on the Notification area at the bottom right of the desktop.The Wireless Device Switch dialog box appears. Hints The appearance of the wireless switch icon changes depending on the selected wireless function. Point to the wireless switch icon to display the selected wireless function. Alternatively, you can right-click the wireless switch icon and select "show Wireless Device Switch settings" to display the Wireless Device Switch dialog box. Select the desired wireless function from "Wireless LAN" or "Bluetooth Device". Notes 5 GHz Wireless LAN is available on certain models only. You must select at least one wireless function to perform wireless communications. The 2.4 GHz and 5 GHz Wireless LAN functions employ different frequency bandwidths, thus are not compatible with each other. Checking the check box for both "Enable 2.4 GHz Wireless LAN" and "Enable Bluetooth Device" may cause poor communication performance or a connection loss due to electromagnetic interference. Click OK. The message "Setting up the wireless devices. Process may take several minutes. Please wait." appears first, then the Wireless Device Switch dialog box is closed, and finally the dialog box that describes what to do with the icon on the Notification area appears. Note While the message "Setting up the Wireless Devices. Process may take several minutes. Please wait." is displayed, do not: place your computer into power saving mode. turn off Windows or log off from the current user. turn on and off the WIRELESS switch. Confirm the settings and click OK. The dialog box about the icon on the Notification area closes. Hint If you check the "Don't show this dialog in the future" check box, the dialog box will not appear next time you close the Wireless Device Switch dialog. To analyze the network condition You can analyze the network condition if you select either or both of the wireless functions under "Wireless LAN" in step 2 above. Click the "Diagnose" button to start Windows Network Diagnostics. When the network analysis is complete, the result is displayed. If any problems are found, follow the on-screen instructions. Hint Windows Network Diagnostics is the function to identify problems the network has and present solutions to them.
Mar 01, 2011 | Sony Computers & Internet
My xbox 360 says im connected to xbox live checked network setings and it says xb ox live is up and running...however when i try to play need for speed says xbox live not working functionally?...
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Computers & Internet
I wanne play my music via bleutooth but i dont find how i need to do dhat
Bluetooth technology makes possible sound transmittion to devices without the wired connections from the device out puting the sound out put gagdget. The bluetooth technology would only perform with devices that have that functionality. For example, once the device acquired on retail has indication of being developed to handle blue tooth technology also known as wireless connectivity, simply use the device settings to enable bluetooth functions. keep in mind that, blue tooth technology workswith only blue tooth gadgets. for example, a blue tooth phone requires a bluetooth ear piecees before functionanlity can be assumed with the settings. Once decided that each devices wanting to perform a blue tooth connectivity are designed for that function, use the settings function either on the menu area to set the wireless connectivity like also known. Remember, wireless cannot access another device that does not provide signals. in other words, once each devices setting are enabled, a signal should appear maybe blue light indicating blue tooth signal has been detected.The functions of thead set requires attempting to listen to any sound during the set up process. The entire process of setting bluetoothh should not be tasking.
checks to perform 1. make sure each device is designed to handle wireless signal recognistion also known as blue tooth technology 2. the devices may need to be set to allow access from the particular devices, a function that was design so that not all signals could be received by your heard piece. In the sitaution of which absence could be noice generation interfering the receiver and possibly preventign setthings
Dec 04, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
How do I turn off my wifi on my dell e1705...I using hardwire connection ethernet do I need to do any set-up?
From the Dell support site:
You can turn your computer's wireless networking function on and off by pressing the key combination. If the wireless networking function is turned on, press to disable it. If the wireless networking function is turned off, press to enable it.
Sep 08, 2010 | Computers & Internet
Can't get internet wireless
Log in to your router ( ) and go to the Wireless settings. Check your parameters, security modes, passwords. Using this info, try again to get to your wireless signal (your wireless on the laptop) should show up and let you log in. If the wireless function is not found, you need to install drivers for it onto the new hard drive. This ought to take care of the problem!
Nov 11, 2009 | Computers & Internet
Cannot enable wireless function
Enable the wireless fuctionality of the router under the WAN settings using a computer that is wired to the router. You will always get disconnected if you're using a wireless computer to set it up.
If you're already doing it then you may consider upgrading the firmware of the router. the firmware of your router can be downloaded from the manufacturer's support website.
you may consider using a different browser. e.g. mozilla firefox.
Oct 05, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Airport settings in Mac leopard
Make sure your ADSL router has wireless capability or wireless function. Verify that from your Internet Provider. If your ADSL router doesn't have wireless function, you need to buy a separate wireless router then cascade it to your ADSL router, from there your airport must be working fine.
Sep 09, 2008 | NetGear DG834G Router
Computers & Internet Logo
21 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
