Question about Emerson SpongeBob SquarePants TV
No picture with DVD input
Spongebob TV worked fine previously with DVD in AV/IN. I hooked cable up to the tv and my AV/In stopped working! I disconnected cable, switched back to AIR recpetion and still not working. Any ideas? Help my kid is freaking out!!
  • 3 more comments
  • Dallas Lee Oct 11, 2006
    I am using the original remote control. Any other ideas Techman? Thanks. Scriptster
    Ok, will try tonight when i get home. Thanks!
  • cmcgrady Nov 26, 2007
    No input from the DVD player. Works fine with cable hook-up. I have the original remote, have used that..unplugged TV and DVD many times...took the thing apart and back together again (out of mere frustration). Screen remains blue with no volume when on DVD mode. I have used this combo a total of 3 times in a whole year........it worked well before.
  • bigwheels2 Jan 02, 2008
    no picture except the spngebob figures, worked fine at first,second time it has the blue screen and "ir" blinking on the dvd player, they are both spongebob
  • jrocddd Jan 06, 2008
    i have the same problem i bought a spongebob tv for daughter and a spogebob dvd player but no remote came with the tv..so there is no tv video option in the front of the tv... how can i get it to play dvds???
    President:
  • 3,130 Answers
Your going to need the original remote to switch back to AV input in the menu. It should explain in the owners manual how this is done. If you do not have that or cannot find the manual go to a search engine and look up emersom dowmloads it will show up as http://www.emersonusa.ca I think PS dont forget to rate this.
Posted on Oct 11, 2006
  • Larry  Dillon
    Larry Dillon Oct 11, 2006
    Nope the link is wrong. Just search for it and you will find it.
When watching tv, a blue box which covers about less than half of the bottom half of the screen pops up about 2 minutes into watching and will never go away. Only goes away if you press volume up/down, but comes back after 5-10 seconds later.
Posted on Mar 06, 2008
    Sergeant:
  • 337 Answers
Unplug the unit9TV and DVD) from the wall for 10 minutos,The microprocessor will reset when you plug it back in,try it again. Hope it works
  • Omar Urrutia
    Omar Urrutia Oct 11, 2006
    The rating response is important to the people helping you
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
How do you hook up dvd/vcr to play on this tv
This television has front and back rca jacks. Those are the yellow red and white holes. You would get an rca cable and connect it between this television and the dvd player. Then you would have to change av inputs on the television's remote to access the DVD player's signal.
Nov 19, 2010 | Emerson SpongeBob SquarePants TV
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
I can't find the dvd input for my hitachi tv
DVD has AV out pins at rear, hook AV cable between DVD player out and TV AV input (yellow-red-white RCA pins) and select that AV input in TV by remote that you hooked DVD.
That will switch TV to that input and TV will show you DVD player picture.
Sep 20, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
"No Sync Signal" on both component inputs
Component ports can and do fail. You can get a replacement board from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 14, 2017 | Hitachi 50V720 Television
57H82-no picture from DVD input
How does line out from the DVD player do? I would suspect a bad preamp/buffer on the TV...accordianman
Mar 17, 2008 | Toshiba 57H82 57" Rear Projection...
Av mode?
well if you change the channel to the highest it goes some TV can be changed to a/v mode
or the lowerest number under 2 sometime a/v might be there
remote stop working due to batteries or drop remote, might have to be replaced either abtteries or whole remote.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Mar 03, 2008 | Emerson SpongeBob SquarePants TV
Spongebob tv
You can only have one item plugged in to the ave jack at one time. Seems silly for a tv with two sets of av ins, but i ran in to the same problem and this works. Just unplug the dvd player or the game console.
Dec 02, 2007 | Emerson SpongeBob SquarePants TV
Power Outage - now DVD will not play through AV
I am having the same issue with mine. I even set everythign back to factory defaults and it still wil not work. Isn't there any tech support palced to find help? See post by Scriptster. Thanks
Jul 21, 2006 | Emerson SpongeBob SquarePants TV
Emerson SpongeBob SquarePants TV Logo
209 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
