Question about Car Audio & Video
On a car speaker is the small blade that connects the wires to it pos. or neg.? Thanks
    Sergeant:
  • 306 Answers
The large blade is the + or positive terminal but so long as the left and right speaker are wired the same way it doesn't matter as it is the phase that matters -it's an AC signal so there really isn't a positive or negative voltage. If the speakers are not wired the same then they are out of phase which results in cancelling out frequencies like losing the bass and sounding 'tinny'. ~Steve Medley
Posted on Nov 06, 2008
My right speaker isn't working...
If you hook what is now the left speaker does it work on the right hand channel? If not the cable to it is defective or the connections or the Amplifier is defective.
May 03, 2014 | Harman Kardon Audio Players & Recorders
How to install spr-17s
The six 1/2 speakers are your woofers,connect the positive and negative wires from the speaker to the 2 connections labeled on the crossover as W(woofer)+ pos and W(woofer) -- neg,hook the tweeters to the crossover connections labeled T(tweeter)+ pos and T(tweeter) -- neg,then hookup the 2 remaining connections labeled Amp to your amplifier,amp must be 2 or 4 channel stereo capable and give out enough power to properly drive the speakers so they achieve optimal performance.
Mar 05, 2011 | Alpine SPR-17S Car Speaker
I got an autotek bts 7150 which is the positive and negetive speaker wires?
for stereo
speaker #1 (white = pos ,green = neg.)
speaker #2 (yellow =pos. ,blue = neg.)
for mono
white = pos., blue = neg.
Feb 22, 2011 | Autotek Car Audio & Video
Does anyone haven a wiring diagram for a quad 4ohm voice coil subwoofer?
Basic wiring dictates that with a speaker with 4 voice coils all at 4 ohms each is meant to be wired in parallel. This will put the load at a 1 ohm total load on the amplifier. Wiring in parallel is positive out from amp to pos. to pos. to pos. to pos.. And neg. out from amp to neg., to neg., to neg., to neg..
Apr 09, 2010 | Eclipse SW9182Pro Car Speaker
How do wire my 15'' to 1ohm
If each voice coil is rated at 2-ohm, then wire it in "parallel". This will make a 1-ohm total load.
amp pos. out to coil 1 pos. to coil 2 pos.
amp neg. out to coil 1 neg. to coil 2 neg.
If the they are dual 4-ohm, the rating would be 2-ohm in parallel.
Mar 16, 2010 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
Car stereo wire diagram for 88 toyota tercel
1988 toyota tercel sedan as follows
pink = (+) pos. for left front speaker
violet = (-) neg for left front speaker
light green = (+) pos. for right front speaker
blue = (-) neg for right front speaker
blue/yellow = (+) pos at all times (power)
grey = (+) pos. only in the accessory or run position
brown = (-) neg gound
red = (+) pos. right rear speaker
black = (+) pos. left rear speaker
white = (-) neg right rear speaker
yellow = (-) neg left rear speaker
verified at 2 resources . fixya
Dec 26, 2008 | 1988 Toyota MR2
Speaker wire not colour coded
You can gently tap a nine-volt battery to the side of the wire pair that will be connect to the amplifier. When you've got the loudspeaker connected in proper phase, the speaker will push out, instead of pulling in.
Nov 26, 2008 | Audio Players & Recorders
Connect positve and negative speaker wires
The slim terminal is the negative and the fat terminal is positive.
please rate, thanks
Sep 16, 2008 | Pioneer TS-A6857 Coaxial Car Speaker
I bought a 500/1 jl audio amp and also a w7 10 sub
if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
if your need more help give me your email and ill send you a pic of how to do it...
Aug 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
Car Audio & Video Logo
176 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
