Question about Mitsubishi CS-40507 40" TV
Picture faded to black, came back, faded again and had stayed black.
I've had this TV for ten years with no problems what so ever. A few months ago I noticed that the picture was blurry when I first turned on the set. It would clear up after being on for a few minutes. Then the picture began to overshadow black with a red haze. No adjustments would correct the redness. Then while watching a movie, the picture began to dim and slowly faded to black. The sound was still playing so I knew the movie was still on. After a few minutes, the picture slowly came back. It never got all the way back to normal brightness before it started to fade again to black. And it's been black ever since. I don't know where to begin. Any ideas? Is this TV worth fixing? Or should I turn it into a boat anchor? Any assistance would be greatly appreciated.
  • John DeJong Oct 11, 2006
    Any ball park estimate of what the the cost to have the set checked out for 'loose connections' should run?
  • John DeJong Oct 12, 2006
    Thanks so much for the information. I lef the TV on all day today (forgot to turn it off) and noticed that the picture came back again, gradually and stayed for about 5 minutes, then slowly faded to black again. It cycled like that 3 or 4 times over a 6 hour period(that I saw) so I figure it shouldn't be that outrageous to fix. But what do I know, I'm certainly no expert.
    Sergeant:
  • 337 Answers
It seems your set has a loose conection in the high voltage circuits,in fact by now it should have many loose conections in different areas like the power supply and the horizontal deflection circuits,if you are familiar with tv service you can use the information as the first step to take,some of the loose conections are hard to see even for the trained technician but the one giving you this problem should not be hard to see,if you are not too familiar with tv service be safe and call for assistance from a servicer a least for an estimate.
Posted on Oct 11, 2006
  • Omar Urrutia
    Omar Urrutia Oct 11, 2006
    The rating response is important for the person helping you
  • Omar Urrutia
    It depends were you are but it should not be expensive.You need to consider there will be a trip charge and then an estimate charge.
A tv picture that is freezing than immediately fades to black?
Check to make sure that off the air broadcast (not cable) is having same symptoms. A good chance main board is the problem. If it is less than 12 months old, contact Samsung for warranty service.
Oct 19, 2015 | Samsung UN60EH6003F 60" LED TV 1920x1080,...
Samsung startup problem
serial number on 6.17.8.1
Sep 21, 2013 | Televison & Video
I have what I think is a Hitachi 55 inch ultravision rear projection TV that is 12 years old. I think the model is 55UX58B. The color goes out and it becomes black and white. It comes back after a few...
When the tv is it totally black and white and the tv picture are good and clear wright?when the tv colors are fade in and out are clear up and when the tv picture it is in colors it is look good normal picture wright?Tv have no shadows of any kinds of colors when picture are good in colors wright?Yes,take ur hand make fist or take a wooden hamer bangs all around the tv bazel frame if the tv colors come back or tv stay in colors it is have good picture in colors.Tv it is still good just have components parts are cold soldering or CRT colors guns R,G,B just require resoldering works only.
Aug 22, 2011 | Hitachi 50UX57B 50" Rear Projection...
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Sony TV won't turn on
Unfortunately it's 10 years old. I can't recommend fixing it because something else may go wrong in a month or two and then you would be looking for a new one. It's too bad though because the problem is most likely not the picture tube or it could even be a loose connection but you'd still need a repair person. THEN AGAIN....
I just found this remark elsewhere on this forum from volts.
Don't beat it with a bat LOL, the problem your having is a simple solution, however this would be best left to a qualified tech to do, the Screen Voltage needs to be tweaked up just a tick, I've worked on alot of these sony's and 9 times out of ten thats what it is.
Sep 24, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have sound but no picture?
i setup a remote code on the remote so the tv goes on /off and the volume but no picture on screen how when i put the dvd player i can see the movie but noy regular tv please help
May 08, 2008 | RCA D52130 52" Rear Projection Television
SONY KP-57HW40
you are experiencing one or more of three things
1.the crt itself is damaged
2. the vertical ic on blue crt board is bad
3. the focus block is bad
if you hire a sony authorized technician they should be well aware of this problem.
Oct 22, 2007 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
335 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
