Question about Belling BIM60 Microwave Oven
Belling Microwave Problem
My folks microwave Belling MGC850SS has stopped working - its switching on or heating up. I've tried changing the fuse on the plug and that has not fixed the problem. Any suggestions? Is this common and do these machines carry internal fuses?
  • Belling Master
  • 9,156 Answers
Apparently this one has a mechanical timer. That lack of electronic controls does lessen the complexity. I don't know about the specific regulations concerning British / EU microwaves, but I'm sure there's a fuse inside. In most cases, just replacing a blown fuse will not be the cure, unless one finds the reason it blew. What made it fail (if it did) is the real question. Loose fuse holder allowed excess heat? Shorted component or wiring? Or, is there a failure in the mechanical timer that's causing an open circuit connection? That can certainly happen. Also, a door switch may have failed. This is most commonly caused by opening the door while it's cooking, instead of turning the oven off first. I would suggest you contact Belling service: http://www.belling.co.uk//CMPage.aspx?pageid=130&subsectionid=85§ion=ContactBelling Good luck.
Posted on Oct 11, 2006
Microwave has stopped heating, yet grill and convection oven still work.
A model number would have helped, but I can give you a generic answer.
It may be a bad door switch or mount.
(Anybody in the home opening the door while it's cooking?)
See our help file on door switches here.
Mar 01, 2013 | Microwave Ovens
I have a NNSD297 Panasonic over the range microwave oven. First the unit had power, clock , timer, fan was working; except after hit the start button, maybe 2 secs looked like working then stops operating....
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
Feb 11, 2013 | Panasonic Microwave Ovens
Panasonic invertor slimline combi
The main fuse in the microwave oven has blown, usually caused by one or two defective door switches.
Mar 30, 2012 | Panasonic Microwave Ovens
Hi i put a plate in which has a gold rim on it, Only for a few seconds ,has this blown the fuse inside the microwave? I have changed the plug fuse but no joy, The microwave is only about 1 year old
WORKING ON MICROWAVE OVENS IS DANGEROUS!!
That said, since you've already changed the fuse it's likely the magnetron has shot itself in the eye and died. If you want to press on and troubleshoot, here's an excellent troubleshooting guide:
http://www.repairfaq.org/sam/micfaq.htm
Again, be sure to discharge any capacitors.
Mar 03, 2011 | Belling STW25 900 Watts Microwave Oven
Power to back of oven going in and out of the oven but nothing happening not even the clock is coming on. please help.
Hi
Thanks for using FixYa. When microwave oven doesn't work at all, it means interior fuse inside the microwave has blown (usually a part inside the microwave makes this fuse blow). Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well. If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. It can also be due to a stuck or faulty door switch which might have blown the interior microwave fuse.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 13, 2010 | Belling Microwave Ovens
Changing the interior lightbulb of Maytag #MMV5207BCW over the range microwave? How the #$!% do you get the cover off to change the bulb?
I have a belling combi microwave, the covection oven works well but the microwave oven has stopped heating the food up and also the defrost isn't working ? Any tips or does it need repairing and wat are the costs?
Nov 24, 2009 | Maytag Appliances Over-the-Range Microwave...
Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
Sep 04, 2009 | Microwave Ovens
Cut out during heating
Possible causes include a blown fuse or high voltage diode. A bad magnetron or power transformer are also possible. I recommend taking the oven to a repair facility, or scrapping it & getting a new one. Do not attempt to repair this yourself, as microwave ovens have voltages present inside which are INSTANTLY LETHAL, & there are no user servicable parts inside.
Jul 16, 2007 | Belling BIM60 Microwave Oven
BELLING M395 TCCS COMBINATION MICROWAVE OVEN
If the fan and light are on when it's running, but the oven is not heating, it may be a bad door switch. We have important safety information and a help file to test and replace door switches and you can find it by searching on Yahoo.com (not Google) for microwave circuit repair It may also be a bad connection at the magnetron or another problem, but please look over this information first then let us know what you find out.
Nov 30, 2006 | Belling BIM60 Microwave Oven
Belling BIM60 Microwave Oven Logo
441 people viewed this question
Top Belling Microwave Ovens Experts
William Miller
William Miller
ray gallant
Terry
Terry
Are you a Belling Microwave Oven Expert? Answer questions, earn points and help others
