FixYa.com
Tags:
Sansui VRDVD4000 DVD Player / VCR Combo
Video no audio
posted by jorrits on Oct 11, 2006
The dvd works fine, we get both audio and video, but when put in a vhs tape we only get audio no picture.The problem started after the kids had messed around hooking up a video game player, after they unhooked it this problem was there. We have unplugged everything and started over , but cannot figure out why this is happening.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 13, 2008
Not Rated (0)
BobYa
Rank:Guru Guru
Rating: 85%, 31 votes
It may be a hook up problem as this unit has seperate jacks for dvd player. Try using the the out jacks labeled dvd/vcr (or vcr/dvd) on back of unit.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Oct 11, 2006
Not Rated (0)
techman
Rank:Guru Guru
Rating: 87%, 6661 votes
If the DVD works with a picture and sound then it is not a hook up problem.. Its the VCR tape heads need cleaning so follow the insert im attaching here.
CLEANING THE VIDEO HEADS - in the event of a head clog, the first thing professionals try to accomplish on a cleaning job is to restore the picture. Cleaning the video heads is the most critical part of the process. Use extreme caution. Never use cotton swabs. Cotton tends to grab, get caught or leave fibers in the heads. It can also break them. Using chamois sticks is by far the safest method.
Soak a chamois stick with head cleaning fluid and place it directly on a video head with light pressure. For beginners, the safest method involves holding the chamois stick stationary in one hand and rotating the drum clockwise with the other. You want all scrubbing action to be in a horizontal direction. Never use any vertical motion; it's very risky for head tip breakage. When finished, allow a minute or two for the heads to dry and your ready to try it out.
Pop in a tape and press PLAY. Confirm the picture is now clear. If not, you might want to repeat the above process once again. Ninety eight percent of the time, cleaning the video heads solves this symptom. Most of the remaining two percent is caused by a defective video head somewhere on the upper drum. Hope this helps
Ps Dont forget to rate this.
Can you Help with these DVD Players problems?
DVD Players
DVD will not load
DVD will not load Answer This...
DVD Players
i cant record films using
i cant record films using my... Answer This...
I need a remote control for...
I need a remote control Answer This...
movie stopping many times
There are some movies that will... Answer This...
vcr eating tapes
Does anyone have a solution for... Answer This...
Repair Service
Find DVD Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
