Question about Sony Cyber-shot DSC-W30 Digital Camera
C:13:01 Format error
Getting Error "C:13:01 Format Error" on LCD display when inserted Memory Stick PRO Duo card.Internal memory(32MB) is working fine.When I took this to Sony service centre, I was told that this problem cannot be fixed, need to replace the entire circuit board which will be costing almost a new camera.Please help to resolve this issue. I am also having same problem with my camera.
It is displaying format error when it is connected to desktop.I can see pic in camera but i cannnot see in system.
can u provide help?
  • pcsece411 Nov 06, 2008
    can u provide help?
  • jamesing Nov 08, 2008
    samr
  • 21 Answers
Don't worry.i got the solve this problem.because all this happened due to the old files on memory card which corrupted automatically.so you need to format the memory card.then insert the memory card on digital camera.your camera will work finely.
Posted on Jan 15, 2011
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
Says error on formatting memory card.
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Try to remove and re-insert the Memory Stick media several times.
Make sure that the inserted Memory Stick media is compatible with the camera. DSCW310 Camera is compatible with the Memory Stick Pro Duo upto 32 GB.
You may also try formatting the Memory Stick media to resolve the issue. Format the Memory Stick media using the FORMAT option in the camera menu.
Formatting will erase all stored data, images, movies, etc., from the Memory Stick media. FORMAT option is available in the Memory Card Tool Menu of the Camera which is in the Settings Menu. Please back up the data by inserting the Memory Stick in the Computer Memory Card slot.
This may also happen if the terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
This should resolve the issue. If the error continues to display, the media may need to be replaced or the camera may require service.
Jan 23, 2011 | Sony Cybershot DSCW310 Digital Camera
I have format error on my cybershot camera. I need to access photoc on camera
The Camera may display the FORMAT Error if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the Camera. The maximum supported capacity and media used is Memory Stick Pro Duo with 1 or 2 GB.
If you've already captured the images in the Camera and the error message displays, then try to open different images captured in the Camera and check if the message appears for all the images.
If this happens with all the images, then remove and reinsert the MS (Memory Stick) in the Camera and check if it works. You may also try cleaning the MS terminals and also check if the Internal Memory of the Camera displays the error. If the issue persists, then insert the MS in the Computer slot and transfer all the images to the Computer. If the images appear normally in the Computer, then Format the media in the Camera. To Format the Memory Stick, select the Format option in the Memory Stick Tool Menu of the Camera. (Menu-->Setup-->Memory Stick Tool-->Format)
Formatting the MS will delete all the files saved.
Formatting the MS should resolve the issue.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
13:01 error
The C:13:01 error code indicates the issue with the Media used in the Camera.
This may be due to the:
Format Error of the Internal Memory.
Un-formatted Memory Stick Duo.
Broken Memory Stick Duo.
Memory Stick Duo type error.
When the Camera cannot Read or Write the data in the Memory Stick Duo.
This can be resolved by Formatting the Internal Memory and Memory Stick Duo.
If not resolved, try inserting a new Memory Stick Duo which is supported.
Try power resetting, remove and reinsert the Memory Stick etc.
This will resolve the issue, if not the Camera may require service.
Aug 06, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
When i turn on my camera it appears "error formating memory stick"
I inserted adapter and memory stick in my sony cyber shoot camera and keep getting format error. How do I format the memory stick
Jun 28, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Getting an error code c:13:01 on my sony t900 camera
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
Jan 21, 2010 | Sony Cyber-shot DSC-T900 Digital Camera
Error C 13 01 when insert Memory Stick Pro Duo with adapter -- which does fit.
    This error code is for Memory Stick. the Countermeasure are :
Format the “Memory Stick” or internal
memory.
CAUSE :
“Memory Stick” or internal memory is
unformatted.
Thanks for using fixya.
May 24, 2009 | Sony Cyber-Shot DSC-S70 Digital Camera
Sony Cyber-Shot DSC-T5 "C:13:01 Format Error"
I had the same problem, you can solve this by:
1. Push the card multiple times in/out the slot or
2. Use a little bit of contact spray on a small piece of tissue, rap this in the length around the memory card just 1 time. Be carefull not to make it to thick that it get stuck in the slot. Then push the card multiple times in/out the slot or
3. Cut a small strip of waterproof sanding paper (grain: 400 or more - the surface feels just like paper, and is just a thin as paper) just as wide as the card or slot. Cut a strip of plastic (eg.old credit card) also just as wide as the card or slot. Rap the sanding paper in the length of the strip and insert this in and out the slot. But!! ... make sure you stay at the upper side of the contacts, don't worry just do it carefully, don't use force and sand the contacts a couple of times. This way work for me, finally!!
Oct 31, 2008 | Sony Cyber-Shot DSC-T5 Digital Camera
Sony memory stick pro duo format error
Use this memory stick in other Sony camera to confirm it. Problem still exist means memory stick is bad/ internal breakage.
Jun 12, 2008 | Sony Cyber-Shot DSC-S75 Digital Camera
Sony
there might be a problem with the file system you are using with with memory stick..insert it into card reader > format it with fat 32 file system..and insert it again to solve your problem.....if problem still persist .insert your memory card into mobile and goto your memory card > now select option > there you will see format memory card > so it will format your memory card with correct file system that your mobile wants.....
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 27, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Sony Cyber-shot DSC-W30 Digital Camera Logo
263 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
