Question about Cycling
Wiring 4 centrafugal motor bikes
Changing manual bike to an auto need wiring help 4 wires on manual but 5 on auto
  • 55 Answers
Need more info...
Posted on Nov 08, 2008
Why does my 2009 Bajaj Pulsar 200f headlight only come on after 5 sec of the engine starting? Is there any solution to turning on the light without starting the bike?
Hi, Em you may have a battery issue make sure connections are clean and tight if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Pulsar 220 DTSi 17 Known Problems and Its Resolutions
how to fix electric start and power of bajaj motor bike
http://nexgenbikes.com/site/wp-content/uploads/2013/05/Bajaj-Pulsar-200-NS-Owners-Users-Manual.pdf?2fb5c5
Download Bajaj Pulsar 200 NS Spare Parts Catalog Manual
Pulsar Do It Yourself Engine Oil Change
Nov 30, 2016 | 2008 Bajaj Pulsar 200 DTSi
Hi my battery is not getting any charge from bike on a 1900 road liner 2006
Hi, Lee and the usual suspects are:
1. Voltage regulator/rectifier not grounded.
2. Engine ground wire loose or broken.
3. Faulty voltage regulator/rectifier module.
4. Loose or broken wires in charging circuit.
5. Faulty stator and/or rotor.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
Dumbest mistake made HELP Page 4 Road Star Warrior Forum Yamaha Star...
http://mazko.net/docs/bikers/XV1900-RoadlinerStratoliner06-09REPAIR-MANUAL.pdf
http://www.gearhead.com/oem-parts/yamaha/sport-bike.html?aribrand=YAM&s2=motorcycle
http://www.starmotorcycles.com/assets/service/manuals/2007/LIT-11626-20-41_stratoliner_all_1554.pdf
Mar 15, 2015 | Road Motorcycles
How your 5 wire CDI unit color code should look like on a honda CRF 50 cc 4 stroke automatic 2002 dirt bike
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
5 wire CDI bike wiring diagram
Wire Diagrams or Schematics for 4 and 5 pin CDI system
http://www.jr-richscooterdoc.com/Help_electrical_explained.pdf
How to wire CDI
2010 CR DUU specifications and pictures
May 10, 2014 | 2010 CRS DUU
Qw atv-02 I bought a quad bike off a guy on a
You may check the dealer for a wire schematic or purchase a repair manual for the bike. Sounds like a manual would be a better resource depending on what you said about getting screwed over.
Oct 14, 2013 | ATVs
Need to know how to install a regulator and estator in cavalcade ,1986 model? Also, need to know where they are located.
The Regulator/Rectifier is located ontop of the headlight. You can see it through the grill there. To change it requires the removal of the fairing, false tank, seat, instrument cluster cover. The Stator is located on the left side(sitting on the bike) of the motor. You can change it by lying the bike over on something soft, old mattress or the grass, on the motor - remove the left rear (secondary) cover and the stator cover. NOTE the lay of the wires and the wire guard. Remove the stator and follow the wires up to where they connect to the Reg/Rect behind the right indicator light. If you were only doing the Stator, then some people splice the wires in behind the left sidecover with heavy duty splices and solder combined. For more info on these bikes, join the worldwide email group via Suzuki Cavalcade.com Hope this helps.
Oct 31, 2010 | 1986 Suzuki GV 1400 Cavalcade LX
Restoring and need to find out the wiring harness suppose to be reversed ground and missing some wires need to find out what's supposed to be there its a sx 175 1975 amf harley davidson
This bike is NOT a reversed ground. It's a standard 12 volt negative ground system. If you need a wiring harness, there are very few places that carry the parts for those bikes. Matter of fact, there isn't but about four. For your wiring harness try http://www.motomacchi.com/ There is also a very helpful Yahoo Group that specializes in those little bikes. http://autos.groups.yahoo.com/group/Aermacchi/
Most Harley dealers and most Harley sites don't even recognize these little bikes as Harleys. They are the "red headed step children" of the H-D bikes. If you need to know anything about these bikes, contact me directly at wd4ity@bellsouth.net
Good Luck
Steve
Aug 31, 2010 | Harley Davidson XLH 1000 Sportster...
WIREING A 1P52FMH ENGINE TO A HONDA 1973 CT-70 trail bike..
Hi, Harroknec the answer to this question is way above my pay grade and for this situation, I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1P52FMH ENGINE wiring diagram Google Search
1973 honda ct70 wiring diagram Google Search
Honda Motorcycle Wiring Diagrams
Honda ST50 Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda ST50 Owner Manual
May 01, 2017 | 1973 Honda CB 100
Need to know how to wire up a pit bike from only wires off the motor to 5 wires , i have swaped motors an the new motor has 5 wires comin from it the old motor had only 2 so im not sure how to wire it up...
it is the same as the other motor on any pit bike the red goes to red and some times the spartplug comes from the motors so you knever know the other three wires are for you light horn and rev counters if you really want to but the pit bikes are made for off orad so you will be spoiling the bike with lights and just remember you need road legal tyres aswell
Mar 28, 2009 | RTO Pit Bikes
Cycling Logo
103 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
