Question about Konica Cameras
Slight play or looseness with focusing ring on a Konica 50/1.2 M-Hexanon lens.
  • alweyedoc Nov 06, 2008
    The response was unsatisfactory. The item is an interchangeable lens for a Konica Hexar RF, a 35 mm rangefinder film camera. The focusing ring on the lens barrel is slightly loose by about 1/10 mm but the is no play in the optical unit within the focusing mount. There are no external screws to tighten the focusing ring and removal of the rear lens flange reveals no apparent means of internal adjustment. Obviously, a Konica repair tech familiar with the item could fix it but I was looking for advice from your techs to see if it's something I could attempt since Konica is now out of the camera business.
  • 849 Answers
This a precious work it is better to contact a qualified technician or services personal.
Posted on Nov 06, 2008
    Brigadier General:
  • 6,966 Answers
I was made to understand that the focusing ring has to be firm that actually seems to give a heavier/tighter damped feel. Anything out of the ordinary indicates a mechanical problem and must be attended to professionally. It might be to your advantage to seek the services of an authorized service center rather than a DIY (do-it-yourself).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
    Brigadier General:
  • 3,614 Answers
Remove the camera battery for a while to reset the system..
if you had a problem on the lens, this would be a hardware problem and you need to bring to authorized center.
let us know more info regarding this problem. an additional input is greatly appreciated...
thanks
How can I adjust focus?
Turn the grey ring around the lens (where the light comes from) until the image is sharp.
Apr 11, 2016 | NEC VT595 Projector
Film release button is stuck
Hi,try putting a bit more tension on the film using the winding crank & it may enable the button to depress,regards,dave
Apr 16, 2014 | Vivitar Konica Autoreflex T W/hexanon F1.8...
How to reassemble 50 mm pentax slr lens
The problem usually comes about when the focussing ring comes loose. Step 1 remove the 1.front round name ring 2. filter ring. this will expose three screws that hole the focus ring in place. reset the focussing to infinity on your viewfinder then set the ring to the infinity mark and retighten. If the helicoid has come apart then take the mount ring out, aperture ring out, and remove the two focus guides. turn the core out, set the fine thread back until it is almost against the ring directly behind it. make sure that it has at least one and one half turns. then engage the helicoid back. refit the focussing core into the lens and refit the two guides.reassemble the lens and revert to step one to reset the lens.
Oct 05, 2013 | Pentax K1000 35mm SLR Camera
Nikon 50mm 1.4d does not focus. I can hear the motor make a noise and if I Help it, it will turn. Also it seems stiff when off the camera and you rotate the focus ring.
Sorry to hear about your nifty 50 lens problems. The auto focus motor might have given out and needs repair. You should be able to focus manually with the lens.
Apr 26, 2010 | Nikon Normal AF Nikkor 50mm f/1.4D...
75-250mm F3.8-4.5 tamron lens compatible to a
As long as you can get the correct Tamron Adaptall 2 mounting for it, then it will fit. They're no longer made and not always easy to obtain at reasonable prices.
Adaptall 2 mounts for Minolta autofocus were never made, but the earlier MD mounts were, and they will fit any Minolta or Sony SLR. Obviously, there will be no autofocus but you will also find that you have to focus with the aperture ring wide open and then manually meter and take the shot after you have selected the aperture which you require.
Feb 16, 2010 | Konica Minolta Maxxum 50 QD with 28-100...
IS THE KONICA HEXANON 400MM F 4.5 ARM, FITTABLE TO SONY-AND WHAT IS HIS RATING--NO INFO ON THE NET
once i have recieved the lens i will have a good look at it,and will keep you informed if there was any prolem and, maby how to overcome it
Jan 20, 2010 | Cameras
I have a Maxxum 7000i 35mm camera and in the display there is the word Help flashing what does this mean This happend after i tried a differnt lens, the lens opened than closed The lens that i tried was a...
Konica lenses do not fit Minolta cameras. I think you messed something up.
Minolta MC and MD lenses worked on the older manual focus Minolta bodies. They will also work on the Phoenix and Seagull clones of the old Minolta bodies.
The Konica lens should only ever be mounted on a Konica camera.
Your 7000i is now a Minolta paperweight. You need to send your 7000i for repair or replace it.
You could also look on Ebay for another Maxxum body to use your lenses designed for the Minolta A mount. As a rule, camera lenses are not interchangeable. You can use any Maxxum lens on any Maxxum body as a rule, but Minolta changed their flash shoe after the original 7000 series. Flashes that work with your 7000i will work with any subsequent Maxxum.
lightspiritphotography.com
Oct 25, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Focusing ring looseness on 50/1.2 M-Hexanon
did you see any rubber gasket on the ring.. this could be the one turn out to be loosen,
did you dropped or any kind of incident happened on the lens.
Nov 06, 2008 | Cameras
Minolta digital camera,s
Simple answer...Take your best working lens to a camera store,and ask to test a sony a100 digital camera. ALL Minolta Maxuum auto focus lenses work with the a100. This includes Konica/minolta type also. If you don't have an auto focus lens, it still might work-but you would loose some features, by swaping camera bodies. In the least it would cost you nothing to find out what camera they would work on, and save you enough money to partly pay for the new camera body you want anyway. Shoot a few stills with your lens on the different bodies-after all your not waisting film-until you find one that is good for you. The camera shop might even have an adapter ring for your lens to the camera body of your choice.
Jun 11, 2008 | Konica Minolta Cameras
Dropped the lens, nothing broke but focus ring came undone
This will need technical service eventually. Try temporary solution with Sellotape or similar
May 07, 2007 | Canon EF 50mm f/1.8 II Lens
Cameras Logo
21 people viewed this question
Top Konica Cameras Experts
myxelpyxel
Level 1 Expert
Are you a Konica Camera Expert? Answer questions, earn points and help others
