Question about Viking VGSC306-4B Gas Kitchen Range
Oven not working properly
Everthing about the range seems to be working properly, except the oven. When turned on, the burners do not produce a good flame, only one burner may be on, or it may be fluttering as if the gas is barely coming out. Both the igniters are glowing bright red. I can tap on the solenoid/valve from where the gas comes from at the bottom of the stove and affect the amount of gas for a moment. The effect resembles a plugged up gas line. Also the broiler does not get gas or starts every time, however the igniter is glowing bright red too. Sometimes it works and at times not.
  • 6 more comments
  • linnerd Nov 09, 2007
    Everything works great excpet oven. the burners are good and the broiler even works but oven will not light. any ideas
  • John Carruth
    John Carruth Dec 05, 2007
    The burners on right work fine, I have to light the ones on the left. Now my oven has stopped heating.
  • Lynn Wyatt Dec 14, 2007
    I have a double oven Viking Stove with an intermittent problem in which the igniter glow plugs glow orange and the gas valve is not activated. This happens in both ovens.
    Could someone tell me the acceptable resistance range for an isolated igniter glow plug that is cold? I thought this would be one way to test and find out for sure the condition of the glow plugs. Thanks- Lynn
    I have a double Viking oven with an intermittent problem in which the igniter glow plug is glowing orange and gas is not activated by the valve. This happens in both ovens at times.
    Can someone tell me the acceptable resistance range of an igniter glow plug isolated and cold? I figure this is one way I can determine the condition of the glow plugs. Thanks-
  • sickandtired Dec 15, 2007
    Oven won't heat to the desired temperature. On "bake" mode the oven often won't heat at all. On "convection bake" mode, oven often heats but only to 200 degrees or so, sometimes less and then the heat gradually decreases. Broiler doesn't work at all. Burners work fine.
  • Anonymous Dec 22, 2007
    Only one of the oven burners come on even though both ignitors are glowing bright red. If I disconect the burner that is working the faulty burner will come on at high temp setting but will tend to flutter.
  • Anonymous Feb 20, 2008
    Top oven does not produce any flames. Heat escaping from lower oven has melted the control knobs.
  • Anonymous Aug 06, 2008
    oven will not light most of the time.
I have the same problem with the oven not igniting but my broiler works fine. I switched the igniters and not my oven works but the broiler doesn't so I know it is the igniter. Thanks for the help.
Posted on Dec 18, 2007
A better question. If you set the self-clean oven then open the door as you press lock, what do you do when the lock locks and you have your oven door open?
Posted on Sep 06, 2007
Saw your posting as I had the EXACT same problem. Tried banging on the solenoid (dual safety valve) and saw the same thing--big puffs of gas came out temporarily. Was about to buy a new one, but found other posts that described this--the problem is the ignitors. They glow orange, but as they age they don't allow enough current to tell the valve to open, hence the problem--the valve has a safety that is doing its job correctly by not letting lots of gas out. Apparently very common with Viking's. I bought two new ignitors (often they fail around the same time, so save some time and shipping and just replace them both) and voila--the oven now works perfectly. I got the Electrolux 5303935066 ignitor kit off of Ebay (label on the wires is Norton model 501A 5303307577), but quite a few places will sell. Got each for ~$16, but it seemed an unusually good deal compared to other places. Much cheaper than a new dual safety valve anyway. Hope that helps!
Posted on Apr 12, 2007
Exact same problem, changed ignitors everything works great now
Posted on Apr 25, 2010
Jafro, find out what size orifices u need for your altitude. the orifices can be drilled out to the proper size, without replacing. It is not the other way though (NAT to LP), unless you plug the erifices then drill out to thr oroper I.D. Always check the manifold pressures when returning the unit to service, and adjust air shutters. Also the reg spring and adj. plate, as well as the cap must be replaced. The valve must be marked as converted and to what size orifices. Please find someone who knows the procedure to help you,as it is a very hard lesson to learn the wrong way! Be Safe
Gazman
Posted on Sep 26, 2008
This is gas instructions for an electric oven problem
Posted on Feb 17, 2007
  • 175 Answers
It sounds like you may have a bad regulator. One thing you can try is lighting each of the surface burners one by one, and see if they get weaker every time you turn another one on. Also, after you light the oven try turning on the burners one by one again and seeing if it weakens or puts out the oven altogether. If the more things you turn on the weaker the flames get, then you probably have a bad or clogged regulator. Sometimes these jusyt go bad, but usually I seee this on a new install where the construction crews or installers get sawdust, debris etc in the line before they hook up the range and it gets caught in the regulator. These are usually not expensive, but can be difficult to change on some ranges. Good luck!
Posted on Oct 13, 2006
4 Suggested Answers
SOURCE: Viking Range
I'm having a similar problem. I don't know the exact fix yet, I'm just starting to research. Check this link: http://www.applianceguru.com/forum1/1916.html
It sounds like the ignitors are suspect. This may be a weak component for Vikings. This link recommends a Maytag replacement part.
Posted on Dec 26, 2007
SOURCE: viking oven won't heat
Igniters need to be replaced
Posted on Aug 26, 2008
  • 23 Answers
SOURCE: Viking 30" Range - Igniter works - but NO FLAME in oven or ranges
No pilot light need to be ignited. You may need a new ignitor. It might not be catching. If you pull the bottom oven plate off you can see the ignitor on the side of the burner and see if it is in its place or broken or just plain old. It is a simple fix. You can buy a universal ignitor or contact Viking and they will sell it to you. Its only two wires and can do it yourself if you are somewhat technical. Good luck.
Posted on Sep 18, 2009
I have converted my new frigidaire gas range to propane with the proper kit and all works well except the oven burner. The flame comes into the oven through the baffle holes about to the level of the...
What you do is tighten down the spud on the oven safety valve. themobilian_221.jpg
Get a good wrench and in the case of propane or LP you tighten down clockwise on that spud. Then open the air shutter all the way.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 21, 2010 | Frigidaire Kitchen Ranges
The burners are not lighting Frigidaire Gas Range only 8 months
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
KESA907P Electric Kitchen Range: Oven comes on but the off button will not work. H...
It sounds like it could be a stuck off/cancel button on the touch panel. When you push the off/cancel button does it feel like the other buttons or different. Usually when these buttons get stuck the proper repair is to replace the touch pad. Some of the newer ranges will produce an error code on the display when a touch panel button is stuck but not always. Unplugging the power to the range might work for turning off the oven but is not recommended. If everything else is functioning properly except for the off/cancel button then it sounds like the touch panel may need to be replaced.
May 03, 2010 | Kitchen Ranges
I have a tappan gas range all the burners but one works when i turn it on. You can hear the flow of gas, and the oven doesnt work. what could that possible be
Mar 25, 2010 | Tappan 24 in. Freestanding Gas Range...
Have 4 burner epicure range. Oven won't turn on. Burners work
turn breaker off and on control may reset and work if not
you need control witch is not available
option 1 we can do upgrade to covert control to newer dacor system
cost is around $1400 can if you are in our service area
option 2 other than that you can have control sent out for rebuild they can not always repair
option 3 call dacor they may offer you a discount on new range as parts are no longer available
good luck hope breaker reset works
Oct 09, 2017 | Dacor Epicure® ER30DSR Stainless Steel...
Oven not working Maytag MGR6875ADS
IF THE RANGE IS DOING EVERTHING BUT HEATING THE OVEN IT IS MOST OFTEN THE IGNITOR
Jul 19, 2009 | Maytag MGR6772 Gemini Gas Kitchen Range
Maytag MGR6775 Gas stove. One igniter not working.
Clean the burner with a wire brush around where the ignitor is. it needs a proper ground to ignite. When you turn the burner on do you hear a click click click? If so this should solve the problem.
Jan 04, 2009 | Maytag MGR6775 Stainless Steel Kitchen...
Problem with conversion of used Whirlpool Range from NAT to LP
Take a 1/2 inch open end wrench and adjust the orifice on top of the oven gas valve.
Tighten it down until the flame is normal. Blue with white tips.
Nov 14, 2008 | Whirlpool SF325 Gas Kitchen Range
Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Jul 20, 2007 | Tappan TGF320 Gas Kitchen Range
Viking VGSC306-4B Gas Kitchen Range Logo
4,498 people viewed this question
Top Viking Kitchen Ranges Experts
Steve Allison
Steve Allison
Paul Carew
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
