Question about HP Compaq nc8000 Notebook
Fan noise problem
Fan runs on high most of the time when it does any kind of searching or game playing. Computer not getting warm at all.
Anything I can do to stop it or make it not so frequent?
I have tried disabling at startup but it doesn't make a difference.
Any help would be appreciated.
Thank you,
wwrafter
  • wwvideo Nov 08, 2008
    Ok, how do you get to the fan? I tried taking out all the screws on the back but something still seems to be holding it on. Is there a lever or switch I have to move or push?
    Thank you
    wwrafter
    Genius:
  • HP Master
  • 1,252 Answers
Remove the cpu fan clean the dust, then install it again, also put BIOS on default setting, then check
Posted on Nov 06, 2008
Dell d610 shuts down while playing games
Some games require more processor use, some less.
If the games that cause your computer to shut down feature high resolution graphics or fast 3D rendering, then the problem could be insufficient processor cooling. Once the processor gets overheated, it goes into thermal shut down.
If, while you play, the computer runs hot before it shuts down (check the cooling fan outlet), then these are some of the possible reasons:
-cooling fan blades could be obstructed by dust - cooling fan needs to be cleaned or replaced
-heatsink radiator and / or air outlet could be obstructed by dust - also need(s) to be cleaned
-thermally conductive grease on the microprocessor heatsink could be
partially or entirely dried up - old grease needs to be carefully removed and new grease applied (caution - do not use any kind of thermal grease that contains metallic particles like silver or aluminium - you might short out the processor - only use the kinds which are electrically nonconductive)
of course the problem could be elsewhere, but the above mentioned problems turn out to be a common issue with many laptop computers after a few years use, regardless of manufacturer brand and model, also it could be any of or the combination of any or all of the above problems (obstructed air outlet leads to more dust being deposited on the fan blades, more dust on the fan and outlet leads to processor overheating which leads to thermal grease drying which leads to even more overheating and so on...)
hope this helps somewhat
regards
triarcuate
Mar 31, 2012 | Dell Latitude D610 Laptop Computer -...
I've got a nVidia Zotac Geforce GT240..a few days later whenevr i played a game it start a buzzing noise...Now whener i play after 5 mins the monitor stops displaying anything and im forced to res
It sounds like the shutdown is due to the card overheating. Does your card have a fan on it? If so that is probably where the buzzing noise came from. The fan either broke or is disconnected and thus the card is overheating. Try blowing out the fan with compressed air and making sure it is properly connected. If it is broken or you have no fan you may need to order a replacement fan or heat sync to fix your problem or get a new video card.
Mar 28, 2012 | Computers & Internet
Ps3 loud fan noise
Don't do anything your fan is just fine it's just running faster to keep it cool when you hear a clicking sound at high speed then you should be worried about it cause your fan is failing and should be replaced
May 31, 2010 | Sony Playstation 3 (PS3) Console
PS3 Loud Fan Noise
It sounds like it needs to be cleaned, just blow some compressed air into the fan area, unless you can actually get it opened, then that would be better.
Hope this helps!
Aug 25, 2009 | Sony Playstation 3 (PS3) Console
I am a game fan. it has been a month that i have not played games bcoz my computer hangs up whenever i open the games. i play high volume games like nfs carbon. please kindly sugest a solution.
Hi !! Please send complete configiration of your computer along with graphic board details if you are using any.
General tips:
Increase virtual memory.
uninstall unnecessary programms.
Clean registry and drives.
Defrag computer.
Update and Run full Antivirus scan.
Hope that helps
Thanks
Jul 10, 2009 | Computers & Internet
Playstation3 turns on and then turns back off with a blinking red light and has a disc inside
O.K sounds like you could have alot of reasons:, one have you cleaned the intake fan grill, cause it will cause it to run "Hot", WHATEVER YOU DO DO NOT RUN IT NEAR A "VAC", that will create Static that will play all kinds of heck with it! use a can of compressed air with it, also check to make sure that your "eye" is O.K. one way you can do this is to run a regular "cd" cleaner disk through it, it will play sound,and (or) music, if this plays o.k. then chances are your "eye" is on track,if these two help, but the "problem still happens from time to time, invest in a small fan, (like the clip on kind), and point it towards the clean air intake, this should stop it from running "hot", make sure you keep your games "clean", a good way is to just squirt some dawn on the bottom of the disk, (and Gently) rub it around with your finger, then under cold to WARM water ONLY, no HOT, rinse the game and "pat" it dry with a towel again don't rub, let me know if this helps, happy 4th, and god bless
Jul 05, 2009 | Sony Playstation 3 (PS3) Console
Wii makes strange noise when trying to play games
it does that main is brand new and it does the same it noting
Jun 28, 2009 | Nintendo Wii Console
Cpu makes noise when play game
blown any dust out of the back of the pc?
hope i was helpfull
good luck
Mar 18, 2009 | HP Compaq d530 SFF PC Desktop
GE XL 1800 quit heating
I don't like to pass on your problem but it sounds very much like either the high voltage supply ot the magnetron has bit the dust.
Either one would make the repair marginal at best.
This is apparently not a very good unit, many microwaves jsut kind of fade away as their magnetron emissions decay.
This one seems to have a bad rep. look at this link:
http://www.fixya.com/search/p489218-ge_xl1800_1100_watts_microwave_oven/not_heat
Sorry, have owned a lemon or two myself.
Aug 27, 2008 | GE XL1800 1100 Watts Microwave Oven
Loud Dell desktop
Any fan that is making noise you would need to replace. There is also never a need to use alcohol to clean a fan. Some computer air or a light wipe down will do just fine.
If you have any other questions let me know.
Thanks,
Lee
Jun 26, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
HP Compaq nc8000 Notebook Logo
132 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
