Question about Gateway Computers & Internet
Gateway laptop hang issue
Purchased a Gateway laptop recently from the U.S. It has a Intel Core2 Duo Processor and 3GB memory.
Recently I have noticed ,the laptop hangs in the middle of an application .
Even when I rebbot the system,it remains hanged.I have to perform several reboots to restore the normal functioning.
The hang generally happens after 5-10 mins of system startup.
Regardless of the application ,the system hangs.
I am using a Windows Vista Premium home version.
Kindly help me with this issue.Also do let me know if any additional dettails are required.
  • troie Jan 14, 2012
    got same issue on the same laptop brand
  • ignacio_edma
    ignacio_edma Oct 30, 2012
    download and install tune-up utilites 2013 to check system error and clean all error to maintain overall performance and speed up pc and all pc problem resolved its 15 days trial version, enjoy
Download and install tune-up utilities 2013 new and resolved all kind of pc problems such as low performance,registry error and more. just fix all kind of problem its 15 days trial version,,,,,,
Posted on Oct 30, 2012
  • ignacio_edma
    i would also suggest start up repair.
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
Check the Windows Page File to determine whether it's system managed or manually set. The recommended settings is twice the amount of RAM installed in the machine. If set too low the system will hang often, especially when running memory hungry apps.
I would also suggest checking screensaver and power management options in the control panel.
If those don't work, close any unused applications which run at startup (Start, Run, MSCONFIG). Another possible solution could be updating your display driver.
Posted on Nov 06, 2008
My core 2 duo E6550 does not work on my foxconn g41mxe motherboard
Motherboard supports Processors with a Front Side Bus (FSB) of either 800Megahertz, or 1066MHz.
1333MHz FSB support is done with OVERCLOCKING.
Intel Core2 Duo E6550 processor has a 1333MHz FSB.
I reduced the view size to 120 percent. Go to Page 27.
Press DELete key to enter BIOS Setup.
Use Down Arrow key to highlight - Fox Central Control Unit
Press the Enter key
CPU Frequency Setting should be set to 333 (333MHz)
Intel processors are 'Quad Pumped'
333MHz x 4 = Approximately 1333MHz. (1332)
Note the version of the BIOS program also.
Sep 25, 2012 | Foxconn G41MXE Core 2 Quad Intel G41 DDR3...
My Wifi is not working. My laptop sound is scratchy. I want to upgrade my processor from celeron to core 2 duo which one i should select for cpu upgrade?
Two main things to know before you can attempt a Processor upgrade.
1) What Processor socket is on the motherboard?
2) What motherboard chipset is on the motherboard?
(Northbridge and Southbridge chip. Unless it's a motherboard that supports Intel Core 13, Core i5, Core i7, and Core i9 processors)
According to specifications I found online just now, the BenQ Joybook A53 comes with an,
Intel Core2 Duo T7250 processor,
Scroll down.
(Only 512MB's of DDR2 Sdram (SO-DIMM) ram memory that operates at 667Megahertz?
{ PC2-5300} Yecch! You need at LEAST 1GB of ram memory. (512MB + 512MB = 1GB.
2GB would be best)
Information on the Intel mobile Core2 Duo T7250 processor,
Scroll the page down until in the left column you see T7250. Then read across, and match the headings above.
Uses a Socket M processor socket,
Is your problem directed to a BenQ Joybook A53 Notebook PC, or is it another model?
Sep 16, 2011 | BenQ Joybook A53 Notebook
Should I buy this laptop?? Intel Core2 Duo Processor T7300 (2 GHz) 2GB PC2-5300 (1GB x 2) 160GB Hard Disk Drive SuperMulti (DVD+-R Double layer / DVD+-RW Drive) 14.1'' WXGA with Camera Mobile Intel®...
Most laptops you can buy for under 1500 and it will have most of the stuff that this sony has, your paying for the name honestly.
Keep in mind it is a intel core2 duo processor so thats the main reason why the price is up. Unless your running high end programs, stay away from this laptop.
May 07, 2010 | Sony Computers & Internet
What is dell l2 cache patern test failure?
cmos problem battry 3v change or bois chip change ok
Nov 11, 2009 | Dell Vostro 1310 Notebook
The Acer Aspire 6930-6771 does not support Blue-ray disks only dual layered DVD's,
Specifications for Aspire 6930-6771
  • Intel® Centrino® 2 Processor Technology
  • Intel® Core™ 2 Duo Processor T7350
(3GB L2 Cache | 2.0GHz | 1066MHz FSB)
  • 16" WXGA Acer CrystalBrite™ TFT LCD (1366 x 768)
  • 3GB DDR 667MHz Memory
  • Integrated Intel® Graphics Media Accelerator 4500HMHD
  • 320GB 5400RPM SATA Hard Drive
  • Super Multi Double-Layer Drive
  • 5-in-1 Digital Media Card Reader
  • WiMAX Forum Certified™ WAN/802.11a/b/g/n
  • Acer Crystal Eye Webcam
  • Dolby Home Theater®
  • Windows Vista® Premium
Jul 14, 2009 | Acer Aspire 6930-6771 Laptop
System hangs up frequently
Might be a loose RAM (memory stick). Try removing it and then connect it again properly and see if it solves the Problem.
Jul 12, 2009 | Intel Pentium Dual-core Processor E5200...
Lenovo touch pad not working properly
Please update the Touchpad driver from
May 25, 2009 | Lenovo IdeaPad Y510 Core-2 Duo: Y510...
Mac keeps shutting off by itself
Hello, this is called a "hard reboot" and can occur because of faulty RAM memory (have you added extra ram recently?).
It can also come form a dead hard drive, or a dead fan, causing overheat
Apr 06, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Computers & Internet Logo
185 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
