Question about Dell OptiPlex GX150 SF PC Desktop
FATAL ERROR MESSAGE/DELL OPTIPLEX GX150 DESKTOP/WINDOWS XP PRO
I HAVE BEEN TRYING TO RE-INSTALL WINDOWS XP PROFESSIONAL SP2 TO MY DELL OPTIPLEX 150. WINDOWS BOOT OKAY, I SEE THE WINDOWS XP SCREEN, THEN IT AUTOMATICALLY GOES, SET UP IS STARTED. THEN I GET THE XP INSTALL SCREEN SAYING I HAVE 39 MINUTES TO UNTIL ALL FILES ARE INSTALLED. THEN I GET A SCREEN THAT ASK FOR XP CD-ROM. WHEN I INSERT THE DISK THATS WHEN I GET THE FATAL ERROR WITH SET UP MISSING A SET UP FILE ON C DRIVE. CAN YOU HELP.
  • 2 more comments
  • R_MARNOLD Nov 06, 2008
    THANKS FOR YOUR RESPONSE,I DID CHANGE THE CD-ROM HAD THE SAME PROBLEM; HOWEVER I WILL CLEAN THE CD. I DID NOT SEE SCRATCHES ON, AND I'VE TRIED 2 OTHER DISKS.
  • R_MARNOLD Nov 07, 2008
    Thank you so much for helping me! I did install the new cd-rom but I got the same error message. I'm going to try re-install with a clean cd disk. I am never able to get to "Format HD before intallation" After starting up it goes to Windows XP Professional like it's starting up normally; then automatically goes to light-blue screen "setup is being restarted" and then asks for Windows XP CD-ROM disk to get "I386" files. When I insert the Windows XP CD-ROM and hit enter, is when I get the SYSTEM SETUP LOG ; FATAL ERROR, C:\WINDOWS\setuperr.log . FATAL ERROR : One of the components that Windows needs to continue setup could not be installed. Then it says; The operation was canceled by the user.
    What do you think!
  • duradex Jan 10, 2009
    I installed winxp pro sp2 in spanish but is slow i have 256 memory ram and I think that could be the cd-rom but any error showed me when I did the installation just run and do the installation correctly is just slow and i've a DELL OPTIPLEX GX150 please email me this link when you send me the answer thanks, my email is iamforallthing@hotmail.com
  • Anonymous Mar 31, 2014
    I just installed Windows 7 32bit on my pc (upgrade from XP). Now it freezes after 10-15 minutes of use and requires a hard reboot to start up again
    Problem Solver:
  • 17 Answers
It sounds like the system is not booting from the CD-ROM and therefore is repeatedly trying to use the same set of files it has already copied to the harddrive. Check the boot sequence in the BIOS and verify that it will boot from the CD-ROM before the harddrive. You'll know you have it right when you see the message "Press any key to boot from CD..." (this message appears only if there is an active partition on the harddrive)
Note: If the CD-ROM is after the harddrive in the boot sequence, and the harddrive is blank or does not have an active partition, it will then boot from the CD, which is probably what happened the first time)
Posted on Mar 26, 2009
Optiplex 150 I get a message error loading operating system
can somebody help out there?
Posted on Jan 06, 2009
  • 36 Answers
R Marnold - If you still have trouble with XP, I would suggest trying a Windows ME or something similar that boots with your System drivers and utilities via floppy drive. You can always load XP on top of this install and delete the recovery files for ME. I've used this method a few times with burro colored machines.
yamasa - These machines belong to the school and without permission, (I'd request it in writing with witnesses and notarized), this could turn into a very large headache!
Posted on Nov 13, 2008
I have two computer in my classroom that can not see the primary disk.
They are dell gx150 and gx 260 (optiplex) I would like help in stting the back the correct way.
Pedro
Posted on Nov 07, 2008
  • 153 Answers
I have experienced this problem as well, it is either the CD is scratch or the CD-rom lens needs cleaning, however it can read the content of the CD, I would susgest you try a another CD-rom , borrow it from a friend. It works for me.
Posted on Nov 06, 2008
  • Trevor Sauna
    Trevor Sauna Nov 06, 2008
    Did you re-install using the new CD-rom or continue with windows set
    up, some Operating System files must have not being copied to drive C
    during your first installation process, try reinstalling the Operating
    system using the new CD-rom. Format HD before installaton.
  • Trevor Sauna
    Trevor Sauna Nov 07, 2008
    You,ve mentioned you never able to get to "Format HD before
    intallation". I would recommend you try to format the HD using the XP
    pro installation process, and format using NTFS so new files are copied
    to the disk (Fresh Installation).And see what happens. cheers.
Installing driver CD for dell Optiplex 755. Error code 150
have you chaned your microsoft windows ??? if yes.the problem is compatibility.
bestsof4u-2.tk
Mar 28, 2011 | Dell OptiPlex GX150 SF PC Desktop
I have Dell Optiplex GX150 with Windows 2000 Professional. It worked fine untill I changed to XP. Then no sound at all. Now I changed back winsows 2000 and still no sound at all. The sound hardware tell me...
download and install the xp soundcard drivers for the gx150 here-
http://support.euro.dell.com/support/downloads/devices.aspx?c=uk&cs=ukdhs1&l=en&s=dhs&SystemID=PLX_PNT_P3C_GX150&os=WW1&osl=EN
Aug 01, 2010 | Dell OptiPlex GX150 PC Desktop
My xp pro on Dell gx150 not saving settings
if i was you i would reistall the windows and update to windows xp pp3 or try going online and updating to pp3 (pro pack 3) if this answer helps please rate it
May 13, 2010 | Dell OptiPlex GX150 PC Desktop
I have a Dell Optiplex GX1 desktop. I have been unable to start Windows and receive the error message: Windows root system32/ntoskrnl.450L exe failure. How do I correct this problem?
You will have to boot in to repair console from XP cd and run it so it can try to repair the Operating system. Put in cd and restart and if it does not ask to boot to cd u have to change boot order in bios to boot to CD rom first. If all this fails you have to reinstall windows. Hope this helps.
Apr 05, 2010 | Dell OptiPlex GX150 PC Desktop
Try to use the System Restore, this process will fix all system errors in your computer.
In your desktop screen, go to:
  1. Start Menu
  2. All Programs
  3. Accessories
  4. System Tools
  5. System Restore
  6. In the System Restore Window, choose Restore my computer to an earlier time.
For example: Today is March 22, try to locate the date were your computer is in perfect condition.
7. Click Next
8. Then you'll see some marked dates
which means those are the dates to use
the system restore
9. Choose a date, then click Next
button
10. Your computer will automatically
restart then wait for the process to
finish
11. A message will appear that states
your computer is successfully restored
12. Then observed the changes in
your computer system
Mar 22, 2010 | Dell OptiPlex GX150 PC Desktop
When laptop switched on dell logo appears then windows logo fails to appear and a blue screen with fatal system error appears and have to switch off
restore your computer using the restore partition or restore cds, you can try to do a repair install of windows but sometimes that can hurt rather than help. if you want to f ind out the reason why hit f8 at boot and scroll down to 'do not restart computer after system failure' and hit enter, when it fails again it will give you a stop code looking similar to 0x00000000 that will give us a little better idea of what the issue is.
Nov 21, 2009 | Dell OptiPlex GX150 SF PC Desktop
Blue screen when i install xp
Thats the blue dump error .so format the drives and reinstall the os
Mar 30, 2009 | Dell Optiplex GX60 PC Desktop
Dell Optiplex GX150 Factory Settings Restore Partition...
This is from the Dell support site. You were correct in pressing ctrl+f11 but perhaps you did not press at the correct time. If in following these first two steps you do not get the recovery console, it may not have been installed on your computer.
1 Turn on the computer.
2 When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time.
3 In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlight Restore, and then press <Enter>.
4 When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.
The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.
When the restore process is complete, the following message will appear:
The system recovery process was successful.
5 Click Finish or press <Tab> to highlight Finish and then press <Enter> to restart the computer.
The software is now installed as it was when the computer was first received.
Dec 10, 2008 | Dell OptiPlex GX150 PC Desktop
Blue Screen error
Try to boot the PC without the XP Home CD in the CD drive, and keep pressing the F8 key until it comes up with a boot menu that includes a Safe Mode option.
If you had the XP Pro CD I'd suggest doing a recovery, but XP Home doesn't have that option I don't think.
You may have to try a few times until the boot menu appears. Don't hold the F8 key down - keep pressing it!
When you get into Safe Mode, right click on My Computer and choose Properties. Then go to Hardware tab (i think - not in winXP right now) and choose device manager. Just remove the Video Card from the list altogether, and then restart. Should force it to use generic video card drivers.
then check your video card model and look for the updated driver
Nov 17, 2008 | Dell OptiPlex GX150 SF PC Desktop
Computers & Internet Logo
966 people viewed this question
Alun Cox
