How can i get the original color of the li tag bullet ?
I have used the font html tag inside the li tag and the bullet come from that has the taken the color specified in the font tag How can iget the original color of the li tag bullet ?
  • deep_15 Nov 06, 2008
    it's very useful
    thnx
  • Daniel Bates May 11, 2010
    change the style attribute of UL or LI tags. Example:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
Sorry, meant to choose solution rather than clarification.
Posted on Nov 06, 2008
Set up margins for email
To edit the HTML source code of a message you are composing in Windows Mail
  • Select View | Source Edit from the message's menu.
  • Click on the Source tab at the bottom of the window.
  • Now, edit the HTML source as much as you like
If you have no clue of html coding here is a starting point
In the body tags to make 0px for default tags then play with the numbers to get what you want.
Put info inside your source body tags they look like these
<body>
</body>
Copy and paste this inside your body tags then play with the numbers to get what you want
style="PADDING: 0px; MARGIN: 0px"
style="PADDING-BOTTOM: 0px; MARGIN-BOTTOM: 0px"
style="PADDING-RIGHT: 0px; MARGIN-RIGHT: 0px"
style="PADDING-LEFT: 0px; MARGIN-LEFT: 0px"
To return to the default Windows Mail composition window, go to the Edit tab.
Nov 11, 2009 | Computers & Internet
Tip
Riding Mower No Start Troubleshooting
  • First check the air filter to see if it getting air and gas.
  • Check your gas cap. If your gas cap is clogged, your fuel tank can get a vapor lock, and you will have no gas flow. Loosen the gas cap to see if it will run longer.
  • Check the gas filter (if you have one on the mower) to be sure it is clean and has good gas flow.
  • Check to see if you are getting spark at the plug. Check out the video below.
If the engine clicks but will not start, the battery or solenoid is often to blame. To find the battery on a riding lawn mower:
  • The battery may be under the hood
  • The battery may be located under the seat
  • You may need to lift the hood to find the solenoid
  • Check the owner's manual for the battery or solenoid location
Check to see that all wires are securely connected and that the terminals are clean.
If the lawn mower still does not start, the problem may be with the fuel, if it was left in the mower over the winter months the fuel may have become stale or watered.. If the fuel appears dirty or contains water, you will need to drain the fuel tank and replace with fresh gasoline.
Other reasons for the mower not to starting also include:
  • Damaged or loose wiring
  • Problems in the carburetor
  • Maladjusted or damaged engine valves
  • A blown fuse
  • Ignition switch may be faulty
on Oct 18, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tip
How to add a tag / label cloud to your Google Weblog OR Blogspot Template
You can use several widgets that are available that require you to register and claim your like the leading website Technorati you will then be on their blogroll which you might as well do anyway. At the time of posting the widgets section is being revamped so if you just want a simple cloud just for your blog not linked to another site read on.
First you need to add Bloggers own Configure label widget through the dashboard., this may suffice for you needs but its not much of a cloud.
Next you need to add several lines of HTML code to your template in the editor I suggest you donwload it first for a backup copy should you make a mistake.
Next you need to do a search for this line of HTML code this the where you add the next two pieces of code
]]></b:skin>
Above this code add this code in place of the single line I suggest that you add a carriage return either side of it, you must not add it after the last </head> tag
/* Label Cloud Styles
#labelCloud {text-align:center;font-family:arial,sans-serif;}
#labelCloud .label-cloud li{display:inline;background-image:none !important;padding:0 5px;margin:0;vertical-align:baseline !important;border:0 !important;}
#labelCloud ul{list-style-type:none;margin:0 auto;padding:0;}
#labelCloud a img{border:0;display:inline;margin:0 0 0 3px;padding:0}
#labelCloud a{text-decoration:none}
#labelCloud a:hover{text-decoration:underline}
#labelCloud li a{}
#labelCloud .label-cloud {}
#labelCloud .label-count {padding-left:0.2em;font-size:9px;color:#000}
#labelCloud .label-cloud li:before{content:"" !important}
]]></b:skin>
<script type='text/javascript'>
// Label Cloud User Variables
var cloudMin = 1;
var maxFontSize = 20;
var maxColor = [0,0,255];
var minFontSize = 10;
var minColor = [0,0,0];
var lcShowCount = false;
</script>
NEXT : - Find this HTML code, best to leave Expand Widget unchecked, for the label widget and then replace it with the code in this download HERE
You need to then save your template and you will see your new label cloud.
You can change the details of the CSS section above to change the font typeface, size and colour if you want to for example to change the font to arial alter the line
change the font-family to one of your own choice like trebuchet.
#labelCloud {text-align:center;font-family: trebuchet.;}
If you do set the display to block you would probably want to change the sort frequency from alphabetical to frequency do this in the actual blogger label widget in the design dashboard. also change the display line from
display:inline to display:block to get the a flat listing.
on Jul 10, 2010 | Google Chrome
Computers & Internet Logo
160 people viewed this question
David Payne
David Payne
