Question about Ariston Technologies LL64WNA Built-in Dishwasher
Ariston L64 - wont start
Hi . i have an L64 that when set to start the 3 hour led is lit (normal) but nothing happens ,, after a couple of minutes the 3 hour and the 6 hour led's start to contineously blink. no normal pump out first then fill ... nothing else happens... any clues appreciated.
    Master:
  • 763 Answers
If your Machine is covered with warranty then send it to repair service and use it. Better to be safe than risky.
CHARCOIS
Posted on Nov 06, 2008
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to check the fuse
if it is ok
Ariston dishwasher flashing code a13
http://salvationarmynaples.net/readpdf/ariston-dishwasher-manual-l64.pdf
http://manualslibrary.net/ARISTON-DISHWASHER-MANUAL-OPERATION.html
These are the sites for two manuals on your machine. They are free downloads that can be read by any computer. I'm sure there is a code list in there somewhere.
Dec 10, 2016 | Dishwashers
Machine won't work.
Robert. You have a bad water valve OR completely clogged up filter screens on the valve. My past experience with this machine with this type of problem is to replace the valve assembly. part Number W10364988
Apr 09, 2014 | Maytag Bravos Series MVWB300WQ Washer
Ariston ar6f105 washin machine not working
Machine start normally but after some time it display H20 and stop. When i switch off the power it restart but again after few minutes it is same. Kindly help.
Aug 18, 2012 | Ariston Technologies Washing Machines
Instruction manual for ariston L64 dishwasher
Try Googling (ariston)(L64)(manual) without parens.
Jan 16, 2012 | Dishwashers
Ariston L64 dishwasher first 2 lights flashing what does this mean please!
Ariston LI6401-Washed a load. Last light on R control panel (Eco Wash) is blinking rapidly and didn't dry the dished.Turned pwer off then on. Did same type of wash. New maching-This is about the 6th wash
Mar 16, 2011 | Ariston Technologies LI640S Dishwasher
Power is on but nothing is happening when i push start. the dial wont let me change the time/dry setting. everything is lit up just nothing happening.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 17, 2010 | Samsung DV218AEW Electric Dryer
Ariston LS 2020 taking more than two hours to go through cycle.
Ariston and on and on...lol
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Apr 26, 2010 | Ariston Technologies Dishwashers
DIshwasher wont start, flashes pre-wash and was lights
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position).
Apr 19, 2009 | Ariston Technologies L63SNA Stainless...
Fault with Ariston Washer/Dryer
Make sure the filter is clean, its behind the front bottom panel which just pull off, then unscrew the filter thumb wheel until it comes out. Check it is clean and replace, Now unplug the machine and set the programme to your normal start setting leaving the door open. Remove the screws retaining the back panel and unplug all the connectors to the circuit board found in the bottom left hand corner. Turn the power back on ensuring the red LED illuminates and leave for 2 or 3 minutes before unplugging the power again and reconnecting the circuit boards and replacing the back panel. Reconnect the power and turn the machine on, close the door and with luck it will work. If this does not clear the fault repeat the process again or look on ebay for a new machine!
Oct 13, 2007 | Washing Machines
Ariston Technologies LL64WNA Built-in Dishwasher Logo
251 people viewed this question
Top Ariston Technologies Dishwashers Experts
Electro Med Services...
Renee Knafel-Bullock
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
