Question about Toshiba 42H81 42" Rear Projection Television
Flickering on black screen or dark areas of a screen
I have a toshiba 42H81 that is about 4 years old. We recently moved and since I have hooked it up, it now flickers. It is most noticable on any black screen. It is getting worse. I thought it might be an inuput or cable, but it does it on all of the inputs. It is still watchable, but especially on HD the flickering is getting more noticable. The flickering resembles a light flashing over the entire screen. I have adjusted the convergence and I have tried unplugging (which Toshiba suggested).
  • Larry Milchak Oct 24, 2006
    As an update, I had a repairman come and look at the TV and he said it needs a new blue CRT. He said it will cost about $700 to fix. I am obviously not happy with this and now I don't know what to do. Does it sound like that could be the problem?
    The set is 4 years old, should I pay to have it fixed or just buy a new TV? I need some advice please.
    Thanks
    Sergeant:
  • 337 Answers
The moving might have created a loose conection,the sets age tell me there are possible other overheated areas that need to be resoldered to prevent other symptoms,If you are familiar with tv service you can check the conections in the output transformer area,he is responsible for generating the high voltage that lights up the 3 picture tubes,before the Hight volatege gets to the pix tubes there is a High volage distribution box that separetes the voltage for each tube,check it and make sure is not degraded,you need to be very careful when dealing with these parts,there is a lot of volatge in that areas,If you are not familiar with tv service be safe and call for assistance froma servicer.
Posted on Oct 11, 2006
  • Omar Urrutia
    Omar Urrutia Oct 11, 2006
    The rating response is important to the person helping you
Screen has been flickering, does not go black but gets really dark. Sometimes if I tap it or move it is stops. Is my screen going bad?
sounds like a loose connection somewhere. find a local computer repair shop. Often those guys can diagnose a common problem just by glancing at the symptoms. GeekSquad is great but costs lots.
Jan 21, 2013 | HP Pavilion Computers & Internet
My hp CPTOH-0602 was flickering and then stopped and now the screen is dark with a big black area in the top left corner
it was a screen back light failure, the lamp get busted in the upper portion of the panel display. to access this part you will need to remove the back cover using a philip screw driver. the back light is covered with metal shielding.to replaced the back light, be careful in disassembling the cover not to damaged the lcd screen panel.
Nov 26, 2012 | Televison & Video
It's a little over a year old. The screen will randomly start flickering and gets really dark and I can't see very well and sometimes just goes black altogether. It is very frustrating and sometimes when i...
Sounds like a loose connection at the inverter board. Laptops use an inverter to step up voltage to drive fluorescent tube(s). The problem could be at the inverter or at the tubes.
Mar 12, 2010 | HP Pavilion dv5-1125nr Notebook
Toshiba Plasma 42
plasma42 color flickers in and out and now its just snow,now its black screen. still have sound.please help me.. what board should i replace??
Dec 29, 2008 | Toshiba Televison & Video
Laptop screen display
backlight, inverter or loose screen connector into system board
Nov 24, 2008 | Acer Aspire 9300 Notebook
Dark screen
this is due to malfunctioning of the cable sending signal to the display panel replace the cable this problem will be solved
Oct 01, 2008 | Toshiba Satellite A15-S157 Notebook
Photo screen problems
This definitely sounds like a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Dec 09, 2007 | Canon PowerShot S1 IS Digital Camera
Update to flickering screen on Toshiba 42H81
How did the repairman prove the blue CRT is bad ? Did he cover
the CRT leaving a good red & green video with no flickering or did
he cover the red & green and observe the flickering in blue...?
Did he discuss the hyper module with you ?.........T.
Oct 24, 2006 | Toshiba 42H81 42" Rear Projection...
Flickering Lines
I recommend you call a shop and ask them how much it will be to replace the Convergence amps STK-392-110(2are in the set) 99%shure thats your Problem Good Luck Walter Grzybowski
Sep 24, 2006 | Toshiba 50H82 50" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
140 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
