Question about Sony Handycam DCR-HC30 Mini DV Digital Camcorder
Sony DCR-TRV7E PAL - LCD screen failure
The picture on the side screen of my camera recently failed showing only red. Playing with the position of the screen by turning and twisting it I can sometimes get the picture back. I returned the camera to Sony to have it repaired as I find this a very good camera but they sent it back saying it is too old to bother with. Remind me not to buy Sony again! Do you have any ideas as to what is wrong and do you know if I can get spare parts to repair this? How does one open the side screen unit without breaking it open?
   Your advice would be miost appreciated.
George
SOURCE: Sony Mini camcorder DCR-HC21 problem with LCD and viewfinder. need help ASAP!!
i have the same problem,i opened the camera, i have taken out the flexible cable, its broken at the hinge...it looks like a bad design of the cable is the reason.
the cable is 1cm in width and at one point when it passes through the
hinge the cable is split into two with .5cm width each. one cable is cut at the pt where it enters the hinge, this cable is stretched to fit into the hinge, guess thats why it broke so soon...
It would be great if some1 can guide on from where and how to get this cable..
Anand
Posted on Mar 11, 2008
SOURCE: Sony Handycam issue - repair/replace?
I just got off the phone with sony. They have extended the free repair and shipping until sept 30, 2008.
Posted on Aug 02, 2008
SOURCE: Sony DCR-SR42 LCD problem
fp-610 or 1-871-457-21 or old part number 1-871-457-11 is a flexible connector, runs for about $40 with shipping on ebay or web
Posted on Aug 23, 2008
SOURCE: Sony DCR-SR200 screen slowly "scrolls" vertically like the V-Hold on an old television
After researching various flexible cable numbers from different posts, I found that the SR-200 uses a unique cable, FP-610, part number 187145711. This has been discontinued and replace with part number 187145721 (same cable also used in DCR-SR300).
If you are in doubt with your camera, just take it apart up to the point of seeing the ribbon cable. The part number is printed on the side.
I found two sources for this so far, www.nexttronics.com and https://servicesplus.us.sony.biz/sony-parts.aspx. Price ranged from $30 to $40 plus shipping.
Posted on Sep 14, 2008
SOURCE: DCR-SR32 screen problems
Screen problem with sony DCR SR 42
Posted on Nov 11, 2009
How to troubleshoot a video camera when the LCD screen is dark or has no display, in a Sony handycam DCR TRV22E mini
If you see correct picture in Eye Piece view finder but dark picture in LCD that shows problem with connecting flexible wire between LCD board and Camcorder main board. It got cracked/ damaged or broken after some time due to open/ close of LCD in its position.
Replace that flexible wire and problem will be solved.
Post back further question if you have any.
Thanks.
Dec 08, 2009 | Sony Handycam DCR-TRV22E Mini DV Digital...
Everthing seems to work, except the camera will not record.
Assume you have Sony DCR-HC20 camcorder and it does not show you live view to record, I hope camcorder is playing back old recorded tapes perfectly with good quality picture on its LCD.
If it is true then your camcorder has ccd imager chip failure and ccd imager needs to be replace to get live view in LCD monitor.
Qualified camera tech will replace ccd imager chip.
Thanks.
Oct 01, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
I have a sony dcr-sr82 camcorder and the lcd upside down
It might be the flex wire connecting LCD with camcorder responsable. What happens when you turn the LCD on the other side?
Sep 23, 2009 | Video Cameras
I have sony digital8 steadyshot camera...every time when i open the lcd i found it white...and no respnse
When you close the LCD into its folded position and use the viewfinder instead do you see a clear picture. if you see a clear picture then the multi strand cable than runs between the LCD and the motherboard has some of the strands broken. take it to a repairman to sloder the broken strands.
rgds
Luwangula
Feb 21, 2009 | Sony DCR-TRV-428E Hi8 Easy Handycam Pal...
No image on the LCD screen - handycam SONY DCR-HC19E PAL
I have a Sony Handycam DCR HC21. The LCD stopped showing after I put a new tape. I then put the old tape in and nothing change. May I have it a button
Jan 10, 2009 | E.Digital DCR-PC106E DIGITAL CAMCORDER
This camera may have a lens problem??
Let me know bit detail of problem...
You can not see live view on LCD and view finder in camera mode and can playback old recordings and picture result is OK,
If yes, then its bad ccd imager problem and ccd imager will be replaced.
DCR-TRV265E is PAL camera and I assume that you are in UK.
Here I provide you information to save 400 or some thing.
Sony will repair ccd imager problem free of cost. You can have details on Sony CCD Support.
Dec 12, 2008 | E.Digital Sony DCR-TRV265E camcorder Pal
No picture displayed on lcd (blank)
Does your camera playback old recordings fine? and just can't show live view to record?
If yes, then camera has problem of bad ccd imager and this part will be replaced.
Sony announced free of cost repair scheme for subject problem. DCR-HC20E is PAL system camera so Sony Support UK can be visited for free of cost repair details as your camera model is listed there.
If you live in different country, let me know to guide you further.
Thank you.
Oct 26, 2008 | Sony DCR-HC20E Mini DV Digital Camcorder
Hi,My Sony digital8 dcr-trv140e is playing back in black & white this has only just happened other wise the camcorder is fine
If you are playing NTSC signal format cassette in your camera (model number shows it is PAL camera) picture result might be in B/W. go to camera player menu and select NTSC playback on PAL tv. Color will be there.
Jun 07, 2008 | Cameras
VideoHead of Digital Sony DCR-TRV265E Digital 8 camcorder Pal
Sony DVD92 Blank Screen
http://esupport.sony.com/US/perl/news-item.pl?mdl=DCRTRV19&news_id=161
Dec 17, 2007 | E.Digital Sony DCR-TRV265E camcorder Pal
No playback
your pal tapes played - in a separate pal player - shows whether your camera ' s tape guides are still in alignment ( your monitor must also be capable of playing pal ) ;
Apr 20, 2007 | E.Digital Sony DCR-TRV265E camcorder Pal
Open Questions:
See all Sony Handycam DCR-HC30 Mini DV Digital Camcorder Questions
Sony Handycam DCR-HC30 Mini DV Digital Camcorder Logo
205 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
