Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Profile Refrigerator - Small Leak & Loud Noise
My GE profile side by side refrigerator started making a loud fan noise this evening. This seems to be coming from the bottom right hand side of the appliance (when I'm looking at it). I shone a flashlight underneath the appliance and also noticed some water dripping out towards the back right - underneath.
After some troubleshooting, I removed the water filter and the noise and dripping stopped.
Do you think I have a clogged water line?
With thanks.
Does water come out of the water dispenser?
I is more likely that the tube that drains the water down from the self defrost mechanism is clogged. Look in the very back of the reefer cabinet, you will see a trough back there, if it is full of ice and water the drain tube is clogged up. If so, a little blast of air from a can of air (like the ones you use to blow off computer key boards will blow it out. Then the water can drain down to the evaporator pan and you will no longer get water on the floor.
Posted on Nov 10, 2008
Motor Noise?
it may be the compressor turning off and on
May 31, 2013 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Refrigerator Noise
Most likely the fan is hitting some frost inside. Defrost the fridge by unplugging it for 24 hours and see if it helps.
GE refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | GE Profile Bottom-Freezer Refrigerator...
Ice build up in bottom of refridgerator, loud fan noise
check gaskets for air leaks or blocked drain in freezer section
Jun 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My GE Profile makes a loud noise occationally like an electric moter trying to ingage, then straining, then stoping. It does this quite often.
UNPLUG YOUR UNIT.THEN MOVE FRIDGE AWAY FROM WALL OUT IN THE OPEN SO U CAN SEE THE MOTOR.
YOU MAY HAVE TO REMOVE A CARD-BOARD COVER TO GET A GOOD LOOK.
THEN USE A VACUM TO CLEAN OUT ALL THE DUST.
YOU WILL SEE A SMALL FAN CLEAN WELL.
THEN USE AN EXTENSION CORD TO PLUG UNIT IN SO U CAN LOOK AT FAN WHEH FRIDGE TURNS ON .
THE FAN NEXT TO THE COMPRESOR SHOULD TURN ON.OR U WILL HEAR A NOISE.
IF IT DONT TURN TRY GIVING IT A PUSH. IF IT STARTS YOUR FAN IS GOING BAD.
AND NEEDS TO BE REPLACED.
HOPE THIS HELPS. OR WE WILL HAVE TO TRY SOMTHING ELSE.
May 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Knocking
Unplug and closely examine the area for a loose fan blade or anything that may be causing the noise. Better now than to get damage that could be prevented. Let me know what you find, Thanks, Sea Breeze
Mar 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge eterna refrigerator loud humming
suspect you have a problem with the defrost system and hence the noise with the fan. take back panel off inside the freezer and if i'm right, melt ice off with a hairdryer. get back to me to say the results if you want
Aug 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
May 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
In this Video Im Replacing Evaporator Fan Motor.
Sep 03, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
286 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
