Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA 52" Menu Keeps Popping Up and Down
We've had our RCA 52" HDTV for about 2 years and all of a sudden the Menu started popping up constantly. It will pop up over and over again. I have to hit ok and exit on the remote or the panel on the TV sometimes to get it to go away and other times it will go away on its on but pops back up again within a few seconds. Sometimes, it will do this atleast 30 times in a 5 minute period while other times I can watch the TV for an hour or more without it doing it at all. Ive tried everything I know~ unplugged the TV for a few minutes, changed batteries in the remote, and checked to make sure the buttons on the remote or the TV panel were not stuck. Any ideas at all? My warranty just happened to expire a month before this happened. Any help would be appreciated. Thanks!
  • Jay130 Feb 22, 2009
    I have same problem what is the solution. My channels keep popping as some thing is stuck.
  • Anonymous Mar 29, 2009
    I have this problem as well.. and I tried the fix and it worked only now I have no sound? is this because i took out the button board?
    Genius:
  • 1,030 Answers
I see this alot at the shop ... the front panel buttons have become damaged. THe best coarse of action is to replace the front button cuircit board assembly... **** there is a tempery fix untill you get the part... remove the front panel and take button cuicit board out...just use remote to control the tv. This is also a way to test to see if this is the problem.. if you romove the connector to the buttons and the problem goes away then the buttons are the problem. you get get this cuicit board at union electronics. You have to get the extended model number off the back ussally d52w20yx1 or yx2 or yxsomething...not to difficult a repair
Posted on Nov 07, 2008
It worked. We did it last night. What causes this kind of this to happen? Is it just a short or is it some kind of malfunction with this particular model? Again, Thank you so much for your help!!!
Posted on Nov 09, 2008
Thanks, I will try that and post back to let you know. I really appreciate the help!!
Posted on Nov 08, 2008
RCA HDTV Monitor; menu popping up and volume going down
The small signal board needs replacement. You can get replacement small signal boards from www.tvrepairworld.com
Jun 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
Menu screen pops on and off rca 52 wide screen hd
Dirty contact switches, clean all the contacts on front of TV with contact cleaner.
May 01, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The tv menu keeps popping up
need you to observe and trace if menu popping up causer by stuck up button, if so you can replace right away.
Apr 04, 2010 | RCA D52W23 52" HDTV CRT TV
My tv menu keeps popping up every few seconds.
MENU KEEPS POPPING UP WHILE WATCHING A PROGRAM. I REPLACED BATTERIES ON REMOTE CONTROL AND HAVE UN-PLUGGED THE TV SET. I OWN A 42INCH PHILIP PLASAM TV MODEL#42PF9630A-37
Oct 02, 2009 | RCA R61WH76 61" HDTV
My menu displays pops in and out on my screen. Sometimes it last
The menu button on the front of the set has to be replaced but this is not an easy job.
Jan 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Divergence not working on RCA HDTV monitor 52" D52W26
sound like the common fl231 fuse problem. consult the fl231 problem article under the tips and tricks section. this is probaly the simplest most inpensive repair on this set
Jan 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Menu pops up constantly
there is a problem with the front control buttons. i see this quite often at the shop. the best way to deternmine this is to remove the buttons and use the remote to turn it on if it goes away then i would suggest replace the button cuicit board assembly
Oct 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
1,747 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
