Question about Brother LS-1520 Mechanical Sewing Machine
Fabric pulls down into bobbin area
After a few stitches the upper thread wraps around down below and pulls the fabric down into the bobbin area! it only tends to happen on larger stitches, tiny stitches work just fine... I dont need those, though!
  • 110 Answers
Increase your top tension, from 2 to 4, or from 5 to 6. Also check if there is no fluff or cotton in the top tension blades, preventing them from closing properly. Do this by lifting the presser foot and decrease the top tension to zero. This open the blades and allows you to inspect them. Good luck!
Posted on Nov 06, 2008
  • Theo du Preez
    Theo du Preez Nov 13, 2008
    Also check your needle plate. If it is a old machine and the opening where the needle enters is to wide, it will pull the fabric into the bobbin area. By replacing the needle plate your machine should be fine.
Thread balls up885-v60-v61v63-v64- v65 ce1100prw sewing machine brother sewing machine modelCE1100prw
If it is creating a thread mess (thread nest) under the fabric, either the machine is not threaded correctly or you have forgotten to lower the presser foot before beginning to stitch.
Make sure you are starting with a brand new needle!
Remove all the thread from the machine.
Check that the bobbin thread is smoothly wound onto the bobbin and that the bobbin is inserted and thread properly in the machine.
ALWAYS RAISE the presser foot and rethread the upper thread. Check that the thread path is correct.
Set the upper tension to the midway point on the dial--this is usually the factory setting but may alter over time with use. Once you get your machine stitching without a mess, you can gently alter the upper tension until the two threads meet in the middle of the fabric.
Remember to lower the presser foot before beginning to stitch.
It also helps to pull the bobbin thread up to the top of the fabric and either wrapping both thread tails around a finger on the left hand or gently holding the thread tails between the left index finger and thumb. Then SLOWLY begin stitching.
How and Why to Bring up the Bobbin Thread
You can search the internet for:
YouTube + Make + Model
and hopefully you will find some helpful videos.
Sep 26, 2016 | Sewing Machines
Machine. Skips stitches and the thread breaks in the top tension.
First, install a brand new needle. Confirm that you are using the correct needle for the thread and fabric being stitched, ie the needle eye could be too small for the thread, the fabric is coarse or sticky causing the thread to wear/fray causing breakage, the needle is blunt or bent, a ball point needle is being used on woven fabric or vice versa...
All About Needles
Second, remove the thread from the machine. Always RAISE the presser foot and rethread from the beginning--make sure the correct thread pathway is followed (consult the manual).
Verify that the tension is not set too tight. The tension is correct when both upper and bobbin threads meet in the middle of the fabric without any puckering of the fabric.
Use good quality thread--avoid old or bargain bin variety. And, use the same thread for the upper and bobbin. Some thread brands may work better than others in your machine. You may need to experiment to find ones that work best.
What to Do If Your Sewing Machine Is Skipping Stitches
Basic Maintenance Tension Skipped Stitches
10 reasons for skipped stitches
There is also the possibility that there is a nick or burr somewhere that is catching the thread. You can wrap your index finger with old hosiery (or similar fine fabric) and rub around the thread path, in the bobbin/hook area, needle plate, etc. A small burr can be smoothed with a fine emery board. A big burr may require replacement of the part or service by a technician.
Apr 23, 2016 | Sewing Machines
How do I fix my sewing machine?
sounds like a tension problem . sew SLOW and see if it is bottom thread or top thread adjust the one that is causing the problem
Feb 18, 2016 | Sewing Machines
Why does the thread keep wrapping around the arm that goes up and down.
improper thread tension (knob on back) or its not being wound thru the tension device correctly ??
Jan 18, 2016 | Sewing Machines
Thread bunches under fabric for the first few stitches, then it sews fine.
hi, could you be threading it wrong ? or the material is slipping at first , how hard is the cotton to pull form the bobbin ? tension check as well.
Jul 15, 2015 | Sewing Machines
When sewing the bobber thread bunches up underneath, and breaks off. I have tried djusting the bobber tension screw, and upper needle tension to no avail. How often should I oil this machine?
1. Your bobbin should have one drop of oil on the race (little area that the bobbin rides on) around two bobbins that you have emptied.
2. The top tension is way too loose. When you put the pressure foot down pull the thread (top) to see if there is tension. Start at four is a rule of thumb.
3. I have included some rules to follow when you are setting tension.
May 08, 2015 | Sewing Machines
Hi I have threaded the needle but when I stitch the cotten comes out of the needle can you help please
When you thread and then start up your machine to sew, for instance, a seam, there's one more step you have to take. After you have threaded, placed your fabric under the foot, and put your presser foot down, pull a length of thread--enough so you can grab, maybe 3" or 4"--pull the thread to the back of the machine and then hold it down for the first stitch or two. You see, when it starts to take the first stitch the upper thread pulls towards the machine, and if there's not enough left over, it will pull it right back though the needle! All you have to do to get around that is to make sure the end of the upper thread is being held down with your hand long enough to take the first stitch or two--then you can let it go.
Apr 15, 2015 | Singer 1120 Mechanical Sewing Machine
My Husqvarna diamond top thread keeps breaking while doing loop embroidery. It sews a couple of stitches and then you can hear when the thread breaks. Ive tried changing the needle and bobbin, and cleaning...
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
Jul 11, 2011 | Husqvarna Designer I
Janome Sew Mini bobbin problem
Hi, Usually wrap-ups in the bobbin area are caused by the lack of tension on the top thread. The slack arm ( shinny lever that moves up and down while sewing) has to pull the loop around the bobbin case and it does so only if the tension on the top thread is sufficient to keep it from pulling more thread of the spool.
Try this: Thread the top of the machine all the way just short of the needle eye. When the presser foot is up the thread should pull through easily. Now drop the presser foot (this closes the tension discs) and pull the tread while adjusting the upper tension control.
If everything is working correctly you should feel the drag on the thread change if not something is keeping the discs from closing.
Most Janomes aren't too difficult to remove the nose cover, usually just one screw and you can get a look at the thread path. Look for thread wrapped around the mechanism.
Sorry, no easy answer but I hope this helps.
Mar 16, 2017 | Janome Sewing Machines
Brother LS-1520 Mechanical Sewing Machine Logo
99 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
