Question about Daewoo L700C 17" Flat Panel LCD Monitor
Daewoo L700C 17 in. Flat Panel LCD Monitor
I need schematics for a Daewoo L700C 17 in. Flat Panel LCD Monitor. i need a step by step diagram if possable. thank you for your time please email me at setdatass247@yahoo.com
  • 4 Answers
Www.dtforum.net search here
Posted on Feb 10, 2009
Dsl-173d How much would it cost for a new t-con board
This monitor is from about 2002, and would cost more to fix than to replace.
Jul 16, 2014 | Daewoo L700C 17" Flat Panel LCD Monitor
L950SC Monitor screen has only a white screen?
Plz check the brightness and contrast from the menu on the monitor.
Jan 13, 2011 | Daewoo L700C 17" Flat Panel LCD Monitor
Monitor goes black
Ok the issue with that is your hard drive has crashed so you need to get a new one for your laptop.
Jun 18, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Monitor keep going to black screen while viewing.
Disable the Screen Saver in the Display Properties from Control Panel of your Computer.
A Black ScreenSaver is active in your Display Settings. Change it to "NONE" and your problem will be solved.
Apr 22, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
It dosenĀ“t turn on
You mention that a switch is broken? I am assuming that you mean the power switch for the monitor? If so, then you can probably get the manufacturer and model, look it up on the web and order a new knob or switch from manufacturer. If this is not an option, then you will probably have to take the monitor apart to see what part of your substitute button is not touching, b/c what a button does it activate a special area on a circuit board that connects or disconnects power to its specificed area (where the button is sitting)
Nov 09, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Computer Monitor
hmmm chek the power board in the back chek resistors and ic's in ocilloscope good luck
Oct 12, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Lcd computer monitor
Have you checked out the Comnputer on another Monitor? Are you sure it is the monitor.? Check the data cable some times pins can get bent through rough insertion.
Apr 11, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Screen turns black
problem with the inverter chek it
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Daewoo L700C 17" Flat Panel LCD Monitor Logo
341 people viewed this question
Top Daewoo Computers & Internet Experts
John Anderson
John Anderson
Michael Galve
Michael Galve
Saleem Baig
Saleem Baig
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
