Question about Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05M0A
Frigidaire cf-5f-lx2 1989 modle
Just got freezer from fathers house, worked good, Kept inside and looks new, got it home 10 miles away, plugged in and worked 1 day then quit. Plug in and humms 15 sec. then clicks and shuts off. Overload tests good. Any thing else I should check before throwing away?
  • 189 Answers
Greetings!
Since the overload was good when tested, check also the electric current if the current is in the right voltage.
If the problem still a raise, it is now the motor compressor that have problem. The motor it self cannot start or hard starting.
Thanks.
Posted on Nov 06, 2008
The upright frigdiare freezer displays -10 degrees and runs continusly i couldnt set it to 0
Good Afternoon Friend,
I understand your Frigidaire freezer, model# LFFH21F7HWJ, is displaying -10 degrees and runs continuously. I also see that you were unable to set it to 0 degrees. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and try the temperature to 0 degrees. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a Frigidaire upright freezer. Power coming into freezer. Light inside works, and the temp setting on the door works. Not getting any power through the system to the compressor.
Contact a professional. The power supply source needs to be testing to the compressor and see if the power is fine, or if the compressor is faulty and not drawing needed power.
Aug 15, 2012 | Frigidaire Freezers
We accidentally left our upright 20 cf frigidaire freezer door open for 24 hrs, all the food spoiled and now the freezer is not freezing and only cooling. Any ideas of what is wrong? thanks
THE UINT IS FROZE UP, YOU WILL NEED TO DEFROST IT. USE A FAN TO BLOW INTO THE FREEZER PORTION , AND HAVE LOTS OF BIG THIRSTY TOWELS HANDY .. THIS WILL TAKE ABOUT 2 HOURS TO DEFROST, WIPE EVERY THING INSIDE THE UNIT DRY !... JAY THE POOL PUMP MOTOR REPAIR GUY FLORIDA
Jul 28, 2011 | Frigidaire 20 cu. ft. / 566 liter Upright...
Got home from vacation to a freezer full of food that seemed to be 'soft'....power did go out while away but was up when we got home. I can hear the freezer working but the food is not doing so good!
you dont say how long the power was off but if food went soft, chuck it,or cook the meat and then refreeze it,everything else is spoilt and will last no more than a month tops....from startup the freezer will take about 24hours to get cold(-18C)
Aug 12, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
I have a Frigidaire model GLFU206FWA upright freezer. The temperature control won't go above 10 degree F. This causes freezer burn on some foods after a period of time. Is there a way to regulate the...
Good day,
Manufacturers of freezers do not give the option of running the machine much above that temperature. Normal operating temperature for a freezer is about -2 to about 8 above F.
Otherwise people could accidentally set the temp too warm and cause a loss of food.
Some appliance parts houses carry universal thermostats that could possibly cover the temperature range your looking for, but 30 degrees is far to warm to preserve frozen food safely.
Jun 21, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
My wife and I bought a Kenmore chest freezer (14.8 cubic foot) about 6 weeks ago. It is made by Frigidaire for Sears, and the model number is #253.165.42105, serial # WB94341279. It has been working OK. ...
This is well with in factory specifications. Hot air rises and cold air drops. Because a chest freezer does not have a fan to circulate the air it is normal for the basket to be warmer than the bottom of the freezer. The bottom of the freezer is used for food you want to keep for a longer period of time.What you store in the basket is food you will freeze for a short period of time. Ice cream should not be kept in the basket. As you fill your freezer with food you will find that the temperature will equal out because the frozen food will take up the place of the frozen air which will give you a more stable freezer temperature.
Try your test when you have it full of food.
Dec 29, 2009 | Frigidaire 14.8 Cu. Ft. Chest Freezer -...
Frigidaire modle ffu21f5hwb door handle loose how
Pop out the screw hole covers and tighten the screws.
Sep 16, 2009 | Frigidaire Freezers
Upright frigidaire freezer not running properly
Sounds like your defrost timer has packed it in you need to fit another timer to it and everything will be as good as new.
by turning the timer you have forced it to run nothing to worry about. It has just stopped in the defrost position. What you have done is the first diagnostic test a tech would have performed. I hope this has helped you out.
Jun 30, 2009 | Frigidaire 14 cu. ft. / 396 liter Upright...
Freezer and fridge stop working when home temp is cold
ketner1 what you are looking for is an old style freezer. They ran so hot that they didn't care what the temps in the garage was. Here is a suggestion. I am not sure what kind of freezer you have had, but look for one that doesn't have a coil on the back of it. Freezers with the condenser in the cabinet work well at the temps you are looking for, however they don't work well in garages at 90 degrees, then they just transfere the heat to the inside of the freezer. This is the style my parents use and theirs is in a storage shed with no heat.
Feb 02, 2008 | Freezers
Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05M0A Logo
157 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
