I have had this all-in-one for several years with no issues. The other day I tried to scan something to print and an error message on the display says "Add Right Cart." It just beeps and will not scan. Both cartridges are new, I cleaned the contacts and replaced them, I printed a test page, printed a "clean the heads" page, and everything seems fine. I also printed a picture I had saved on the computer and it prints just fine. I tried restarting the computer and restarting the printer. I have checked all the connections. Everything seems fine. I then decided to try and just scan the image to the PC and then print it off. But, the scanner started scanning and then just stopped about a 1/8th of the way across. I went and looked at the saved image and it was fine except that it was only an 1/8th of the page. I then tried to rescan it but an error message came up saying that the scanner was locked and needed to be unlocked. There isnt even a utility to do that! I restarted the printer, the scanner bar reset, and I tried it again. Same result.
So, those are my two issues, both were discovered at the same time, and I havent had either of those problems before. I just wanted to know if anyone had any ideas before I go out and buy a new all-in-one. Thank-you in advance
2 Other Users Have The Same Problem
Comment by Yoishi, posted on May 18, 2008
When i try to scan by hitting the scan button it says scan not set. When i try to scan from the printers menu the lcd screen says scan motor stall. Now the printer does not print at all.
Yoishi
Comment by Guest, posted on Apr 13, 2008
Unlock Scanner then hit C button... ? No idea what this means...
Was this solution helpful? Show your Appreciation by rating it:
Post a New problem for Compaq A3000 All-In-One InkJet
Email this problem
Can you Help with these Printers problems?
printing adobe files
compaqa3000 cant install
scanner/copier problem
