A clear strip of thin and narrow film fell off from the cartridge
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
If not the piece required to remove before printing, you will need to replace the cartridge
Posted on Nov 06, 2008
I have just placed my cartridges in the lexmark printer, turned the power on and then suddenly a thin plastic strip flew out, please how can i put this strip back and where. The printer is a X2550 lexmark
Did you remember to peel off the film strip that covers the area where ink exits the cartridge (toward the bottom)? If not, then that was probably what you saw.. I have done that before myself.. : )
Nov 29, 2010 | Lexmark X2550 All-In-One Printer
Printer wont print black ink and its a new cartilage
Cross check that you have removed the strip of film on the cartridge which stops the toner coming out? there should be a piece of plastic to pull on with a strip of clear film across wherever the toner comes out..
Aug 25, 2010 | Kodak   ESP5250 Es Printer
I have a black line showing up on my faxed documents. I have opened it up, changed the film and re- set it, but the problem persists. The machine is about 5 years old.
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 07, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
Where is the encoder strip on brother fax machines?
I am familiar wih some inkjet models. The encoder strip would usually be behind the ink cartridge carriage. It is a thin clear plastic strip across the length of the carriage. The ink cartridge housing glides back and forth along the encoder strip.
Aug 25, 2009 | Brother MFC-685cw InkJet Printer
Printers lines are squiggly
calibate the print cartridges
if not solved then clkean encoder strip ( a thin Clear Strip )
check Carriage movement Belt , If REquire Replace
Feb 04, 2009 | HP DesignJet 750c plus InkJet Printer
Plastic strip fell off
Hi, if you open the open the printer, unit to gain access to install ink cartridge, if you see the metallic end which has got a hook on both the ends left and right side. the ink cartridge runs between the strip from left to right which should be connected above the ink cartridge meta rod.
< ------------- >metal hooks on left and right above the cartridge rod
======= __ cartridge rod
Let me know for further info.
Feb 05, 2008 | Dell 810 All-In-One InkJet Printer
Carrier Jam
I loaded to new cartridges into the printer1.gif, switched it on, cartrigde went from one side to the other with a bang, error on printer reads, clear the carrier jam, cn you help?
Jan 11, 2008 | Lexmark OfficeCenter X3350 All-in-One...
Small thin film fell out
Try to cut off a thin plastic strip. just try to copy that. it basically guides the cartridge on where to print. also i remember that it should have a spring connected to the holes.
Oct 04, 2007 | Dell 924 All-in-One InkJet Printer
HP 1315
Sounds like you have a problem with the ribbon cable or the circuitry on the print head assmbly. The ribbon is usually a suspect if the cartridge lights are on. If that doesn't solve the problem check the circuitry.
Mar 05, 2007 | HP PSC 1315 All-In-One InkJet Printer
53 people viewed this question
