Back to:
Tags:
ASUS A7N8X-E Deluxe Motherboard
NO Power up at all, Nothing! (by 7 users)
posted by Jreed on Oct 11, 2006
Im not getting any Power signs at At, its not even attempting to boot, I took the memory out and still the same problem, Its completely DEAD!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
6 Other Users Have The Same Problem
Comment by Guest, posted on Apr 27, 2008
the mobo wont power on, ive even had another person try
Comment by mike54, posted on Jan 05, 2008
checked power supply ok when i plug it in nothing goes on except the small
green motherboard led unplug from board and fan starts to spin replug in board fan stops press power button same thing pc won't start tried shorting start button still nothing i'm thinking motherboard is shot i'm using a 20pin atx power supply 350 w
Comment by Theog, posted on Jan 01, 2008
Switched system on. Loud spark sound and smoke came from near power supply. Replaced power supply, absolutely no response from mother board. Fan does not come on, power supply does not start. Removed PB sw from header on mother board and closed switch circuit, nothing happened. Disconnected PS and took pin 14 (green line) to ground, Power supply kicked in. Look like mother board is dead. Are there any on board SMT fuses that can be checked? Mikeyfoxtrot@yahoo.com
Comment by speedcom, posted on Dec 05, 2007
Comment by outlaw26456, posted on Nov 24, 2007
i have a lvmm2 mother board,,something burned in it,,,,what is the likaley culprit?....it won't even light up the screen,,,just dos nothing at all,,,
Best Solution
posted on Oct 11, 2006
Thanks for Trying (70)
habib_101
Rank:Wiz Wiz
Rating: 81%, 422 votes
Do you have a LAN connection on the machine that you use? That would be an area to start to make sure that (when a LAN cable is plugged in, the incoming and outgoing lights will blink) the power supply still works. If the power supply does still work, it could be the motherboard or CPU which isn't working. It could be something simple like thermal compound needs to be reaplied to the CPU, or there may be faulty hardware. Let me know if the power supply is still working.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on NO Power up at all, Nothing!:
I don't want to Accept this solution
Solution #2
posted on Mar 13, 2008
rifth
Rank:Master Master
Rating: 87%, 42 votes
If you can smell anything burnt in there it's toasted.
Comment by rifth, posted on Mar 14, 2008
I have had the same problem and I don't remember how I fixed it now. Basically my computer was dead, if I unhooked the plug from the motherboard and replugged it the light would flash green and fan would spin. My computers working fine now. It's something really stupid OH okay there were two power plugs coming out of my power supply one 16 pin or whatever and one 4 pin and I had them both plugged into the motherboard.
Thank You!
Solution #3
posted on Mar 04, 2008
Not Rated (0)
wa2bxy
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
electrolytic filter caps on the mother board have failed, and shorted. A dead short will sound like a gun firing inside the cabinet. A gradual short will make the can expand and split or work its way off the innards of the component
Thank You!
Solution #4
posted on Jan 19, 2008
Not Rated (0)
ahmdrgb
Rank:Guide Guide
Rating: 87%, 8 votes
1- try to clear comos in the motherboard pcb behind the battery
2- take off your pcb from your case and put it on any thing metal and try again to open it
Thank You!
Solution #5
posted on Dec 11, 2007
Not Rated (0)
crissy1983
Rating: 0%, 0 votes
i have the same problem and yes the power supply is still working.
Thank You!
Solution #6
posted on Oct 24, 2006
Not Rated (0)
tmont
Rating: 70%, 1 votes
I was looking for a solution to my problem and ran across your post.
Here's what I found to get it working:
I put the RESET jumper on the PWR on/off posts.
Some reason the RESET button will turn my unit on, but the POWER button will not.
Another finding when hooked up "normal"... if I remove the power cable and plugit back in the PC boots up. The POWER button will turn the unit OFF... but will still not turn the PC ON.
So for now I am using my RESET button as my power switch. What I'm trying to find out now is "WHY?"
-Hope this helps!
Thank You!
Can you Help with these Motherboards problems?
Motherboards
I have a MARS Foxconn motherboard ,i have a problem with...
Motherboards
Motherboards
i have msi p45 platinum MB,two graphics cards xfx 9600GT...
Motherboards
I took apart my sister's computer an XP and I'm having a...
Motherboards
hey i need help with my problem that im haveing with my...
6 Other Users Have The Same Problem - Continued
Comment by protius, posted on Nov 21, 2007
i cant get this motherboard to do anything,does this motherboard need a specific compaq power supply
Loading problems.
Repair Service
Find Motherboard Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
