Question about Sylvania 6427TE 27" TV
I have a Universal Remote but can't get the tv into Video Mode.
I got this tv from my brother and the antenna port in the back is broken so I was trying to hook my digital convertor box up through the video ports in the front. I have a universal remote and now I can't get my tv onto the video channel so I can use it. What can I do? Thanks !Kristen
  • jkjemildner Nov 06, 2008
    I tried that. but for some reason the tv/VCR button isn't working. And there are no ports in the back because they broke. Thanks! Kristen
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
Try TV/Video button on your universal remote or some similar button that'll change the input, also try connecting to back ports of TV.
Posted on Nov 06, 2008
  • Ken Kichi
    Ken Kichi Nov 07, 2008
    You might have to try a different code for the TV since some may seem to work but not have full functionality. Good luck and I hope the next code will fully control your TV and allow for the tv/video or video setting input buttons to work!
We do not have the original remote, it was broken last year. We replaced it with a Phillips Universal remote which has worked fine until recently. The tv was in video mode when the batteries were knocked...
It shouldn't make any difference what mode the TV is in when programming the remote control. After you replace the batteries, just reprogram the control with whatever code you used before. If you didn't make a note of the code, use the remote's code search feature. That only needs the TV to be on, so that it shuts off when you find the right code. Once the remote has the right code back in it, you'll be able to switch the TV out of video mode.
Apr 23, 2011 | Sanyo DS31520 31" TV
I can't switch back to video mode on my tv pretty simple
www.symphonic.us/pdf/spec/2004/ST419E.pdf
Simply buy a RCA universal remote at your nearest dollar store and press the button that reads antenna.
Jun 20, 2010 | Symphonic ST419E TV
Broken remote How do i switch between Aloge and digital Channles
I called FUNAI CORPORATION
Customer Service
Tel :1-800-605-8453
http://www.funai-corp.com
I was told the only way to get it back to digital was to order a replacement remote. They told me there is no universal remote that will put the tv back to digital. If you want to order a new remote call the number above and choose option 4.
Aug 20, 2009 | iLO IWT3206 TV
Broken remote, can't access video mode
800-256-2487 customer service number for your manufacturer
Jun 14, 2008 | Symphonic ST427FF TV
Video channel disappeared
i just got mine to work i had the same problem, i bought a universal remote, make sure your dvd player or whatever his hooked in, and hit the input button on the remote, it worked for me. I couldnt get anywhere by looking through menu, but i just hit the input button and it magically appeard :)
Feb 23, 2008 | Symphonic ST420FF 20" TV
Video on tv
go to"remote controls .com " You should be able to locate your original there.
Feb 18, 2008 | Emerson EWF2004 20" TV
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
I don/t have remote control
If there is no button on the TV to go to the video channel or channel 3/4, you'll have to buy a universal remote.
Dec 27, 2007 | Emerson EWF2004 20" TV
Emerson Spongbob tv broken remote...cant change input?
Then the only way to reach your tv is through coaxial antenna port. So you can buy an rf modulator ( very cheap) and connect your red yellow and white cables (rca cables from a dvd, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me.
Apr 17, 2007 | Emerson SpongeBob SquarePants TV
TV screen on video 2 and remote died
The only way your going to change the video mode is with the original remote. If you need another remote go to http://remotes.com or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
Aug 20, 2006 | Sanyo DS27800 27" TV
Sylvania 6427TE 27" TV Logo
136 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
