Question about Spectroniq PDV-808
Broken disk lid
I have a spectroniq PDV-808 portable dvd player. the disc lid is broken and the disc will not spin around to play dvd. can i find a replacement disc lid?
Not sure if you can find a replacement lid but you may be able to play DVD's if you manually depress the small switch that the lid would engage if it were closed. The switch is located where the lid hinges at the right side, you should see a small rectangular hole. The switch can be depressed through that hole. Of cousre, your DVD will be spinning with no lid to protect it but just don't touch it while the disc is playing. When done playing, you can just turn the unit off or remove whatever you used to engage the small lid switch.
Posted on Jan 14, 2009
The portable dvd player isn't spinning the disc and it isn't reading the disk it comes up with saying no disc even when there is a disc in the player
it could be that when you close the lid it does not press the switch that start the motor. <br /> if you see the disc spining maybe the laser head is not clean <br /> or the main board is broken <br /> If you want to fix the portable DVD write to me , <a href=""></a>
Aug 26, 2010 | Sony DVP-FX810 Portable DVD Player
You will have to purchase a replacement battery from the manufacture or their authorized parts distributor. Don't waste time looking in electronics stores, because you won't find it there.
Jul 04, 2009 | Spectroniq PDV-808
Polaroid Portable DVD won't work
First try a couple more discs. If it still doesn't work. Take a little bit of alcohol on a qtip and clean off the little clear circle under the lid. Make sure the dics you are using a not scraped and not foreign. If that doesn't work, order a new one and put the old one in the new box and send it back as broken.
Jun 28, 2009 | Polaroid PDV-0701A Portable DVD Player
Spectroniq PDV-768
uk dvds are formatted in PAL
us dvds are NTSC
find your settings screen (usually has a wrench to identify it)
Nov 02, 2008 | Spectroniq Protron 7'' TFT LCD Portable...
DVD portable player - protron DVD player model PDV-288
The 4:3 is an aspect ratio the ratio of horizontal to vertical size and the non-HDTV standard; the latter is 16:9.
The PAL and NTSC abbreviations refer to the picture and synchronization standards whereby NTSC is the American standard and the PALs are European. The setting "sp-raw" refers to an unprocessed video format that requires further processing before it can be viewed.
If the disk you have was made for the American market, you should be set to NTSC and the aspect ratio to whatever the disk is specified, most recent disks will be made to conform to HD specifications, but may also  be viewed in "letterbox" form which is a shrunken 16:9 box with pronounced edges around it.
Oct 06, 2008 | Protron PDV-288 7" LCD Portable DVD Player
Spectroniq pdv 768 region code
  1. Open Device Manager.
  2. Double-click DVD/CD-ROM drives, right-click the DVD drive for which you want to change region settings, and then click Properties.
  3. On the DVD Region tab, make the appropriate changes
Sep 17, 2008 | Spectroniq Protron 7'' TFT LCD Portable...
Will not play dvd
Jul 02, 2008 | Protron PDV-288 7" LCD Portable DVD Player
PDV-808 Disc Not Spinning
can you see on the optical lens if the lights goes on.. if the red lights on.., problem is int he flex cable/cable wire/ or what so ever term use by the manufacturer.. posible also defective optical lens. or try to re adjust the trimmer on thier circuit.. tnx
if problem persist desame you may contact to the qualified technician.
Dec 30, 2007 | Spectroniq PDV-808
ribbon cable issue found with this device. look inside at the white ribbon cable. The cable likes to bunch in bewtween the spinning hub and the eye assembly, after time it may even develope a rub spot that will shut you down for good. If the cable is bunched up, try pushing it back into the bottom of the device and try again.
Nov 15, 2007 | Durabrand PDV-705 Portable DVD Player
Disc not spinning
It could depend on the type of media you're using. I noticed that certain types of self made dvd's don't play in this player.
Apr 01, 2007 | Polaroid PDV-0823A Portable DVD Player
Spectroniq PDV-808 Logo
203 people viewed this question
Top Spectroniq Televison & Video Experts
Jayesh Panchal
Jayesh Panchal
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
