Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Clearing the password
I need to clear the password for the parental lock forgot the old one can anyone help?
    Scholar:
  • 93 Answers
Http://www2.panasonic.com/consumer-electronics/support/Televisions/VIERA-Plasma-HDTVs.list.75403
The above is the link from panasonic support.There is phone number and email contact information.
You need to call them to reset your password.
solutiondoct
Posted on Nov 06, 2008
Password forgotten kidzstar tablet
If you're connected to WiFi, you can tap the link for 'forgot password' and then an email will be sent to your email address. If you're not connected to WiFi: There are three options when selecting the option to enter Parent Mode: Select Age Group; Parent Controls; Device Settings, select Device Settings Enter the password 1orEnt= The password is case sensitive. Once in the settings, you can turn on the WiFi. Return to Kidz Mode and try to enter Parent mode, tap Forgot Password. If you don't receive the email, again enter Device Settings, from the left select Apps, on the right select ALL from the top bar. Scroll down the right hand pane and select Kidzstar Mode, from the right hand pane select Clear Data. Return to the idle screen and switch off the unit. When you turn it on, you will need to set up a new account with a different email address.
Dec 30, 2012 | Tablets & eReaders
Tip
Lock and Unlock most TV's
http://www.ecoustics.com/tl/17973/
Polaroid:
Having trouble with setting your Parental Controls (V-Chip)?
The factory preset password is 0000. This password must be used first before setting your own personal password. It is recommended that you keep your personal password in a safe place and away from children. In the event you loose your personal password the master password is 8202. The master password overrides all passwords. The master password can't be changed and should be kept in a safe place away from children.
0000, 1078, 1111, 3808, 5050, 8202.
Mitsubishi LCD TV:
Bypassing the V-Chip Lock After you set the lock, you need your passcode to view
a V-Chip locked program, view the locked TV, cancel
the lock, or enter the V-Chip lock menus.
If you forget your passcode, you can view the locked
TV without entering your passcode. When your
password is requested, press the number 9 and QV
buttons on the remote TV control at the same time.
This process temporarily unlocks the TV.
When entering the V-Chip Lock menu, this process
deletes your old passcode and prompts you to enter a
new passcode.
AOC: 0,0,0,0
LG: 7,7,7,7
PHILIPS: 0,7,1,1
SONY: 4,3,5,7
VIZIO: 0000, 2489, 5351, 8202, 8205, 8206
Emerson/Sylvania/Funia: 0000
NOTES from Emerson/Sylvania/Funai:
1.Make sure to enter the exact same new password in the
"Confirm Password" space as one in the space. If they are
different, the space is cleared for reentering.
2. Your password will be erased and return to the default(0000) when a power failure occurs or this TV has been
unplugged for more than 10 seconds. If you forget the password,
unplug the power cord for more than 10 seconds to
restore the password to 0000.
Sharp TV:
Sharp LCD TV Clearing the secret number using the remote buttons and the TV's buttons.
If you forgot the secret number, clear the secret number using the following procedure:
1) Press MENU, and the MENU screen displays.
2) Press Left/Right arrow buttons to select 'SETUP'
3) Press UP/DOWN arrow buttons to select 'EZ setup', 'CH setup', 'Parental CTRL' or RESET, and the SECRETNUMBER INPUTSCREEN DISPLAYS.
Press and Hold both CH UP and VOL+ ON THE TV SIMULTANEOUSLY until the message appears on the screen. The SCECRET NUMBER IS ****.
on Aug 17, 2010 | Televison & Video
I need the code for rca xl100
Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you forget your password, press the following buttons on the remote,
one by one: MUTE, DISPLAY, CLEAR, and RESET (you must be in the
password entry screen). Parental controls will then unlock and you can
re-enter a password via Lock Parental Controls.
If you need the manual please let me know.
Feb 06, 2011 | Televison & Video
Parental code lock sony kp51w5500 reset /or clear it?
If you lost password of parental code then put 4357 and press Ok
This will clear old pass word and type new password.
Jan 30, 2009 | Sony KV-32FS13 TV
Parental Control Code?
if you forgot your password you can reset it ,turn tv off press and hold vol< on tv and clear on the remote for 5 sec.,enter a new password next time you access the parental control menu.
Apr 16, 2008 | RCA F19436 19" TV
Clear Parental Lock on Aiwa A2010
hi,
try 0711
good luck,
joe
Mar 31, 2008 | Televison & Video
32 inch R.C.A T.V
FPA lock stands for Front Panel Access lock similar to Parental Control/Child lock - it indicates that the buttons on the front of the TV are locked so that it cannot be operated accidentally by young children.
You would need to use the remote to deactivate this security feature. Normally, you would go into the Parental Controls menu and turn off the FPA lock.
If for some reason a password was used, then you would have to enter that password since without it you can't get into the Parental Controls menu.
On some versions, you can press "Menu" on the front panel and "Vol -" on the remote simultaneously for 3 seconds to clear the password. in others, it would require that you press and hold at the same time the Vol < button on the front panel and CLEAR button of the remote control for about 5sec. You would need to enter a new password the next time you access the Parental Control Menu.
Usually, steps involve are explained better in the user's manual which is available at the RCA (Support) website. You would need to enter the exact model number of your RCA TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 25, 2008 | Televison & Video
Parental Code
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
Bill
Jan 30, 2008 | RCA TruFlat 27F520T 27" TV
I dont know the parental code and my color is messed up how do i fix it.
OR TRY THIS..
Bill
Unlock TV
OR TRY THIS..
Bill
Jan 24, 2008 | RCA TruFlat 27F520T 27" TV
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
719 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
