Question about Gateway 310S (2900621) PC Desktop
Turns on, then shuts down before anything shows on monitor
The computer shuts down almost as soon as it starts up. Then it will not start up again until I unplug it and start over. Each time, it will just shut down again. I took the side panel off and watched the LEDs on the Mother board. A green light stays on near the CPU. When I turn it on, a red light flashes for an instant at the bottom of the board, near the board slots. I tried a different power supply with no change. I tried unplugging all the power cables to the drives with no change. I unplugged and reseated the memory chip and the CPU with no change. I don't have another CPU or memory chip of the correct type to try in it. Any suggestions?
  • 10 more comments
  • Rex James Oct 21, 2006
    Thanks for the tips. I tried a new CMOS battery and new thermal grease on the CPU heat sink. Still no change. Since I don't have another CPU to try, I guess I'll have to send it to a local repair shop. It doesn't even make it far enough for a beep to sound.
  • bbutcher Nov 05, 2007
    My computer requires many presses of the power on button to start, then may shut down in 2 seconds or after booting up. I got it into safe mode once but it still shut down by itself. I re-seated all connectors and plug-in boards, and tried another power cord. My spare power supply has different connectors at the mother board end, so will not work.
  • Anonymous Nov 14, 2007
    I have the same problem with my 8311. The fans come on high as it freezes. I get F1, F8 and F12 but freeze before I can do anything. All kinds of error codes 7, 162 , configure problem, beeps 1-3-3-1, 1, 1-3 to many.
    Blue screen, black screen managed to get to the recovery and Windows screen once before fans came on. Replaced motherboard but may have been DOA from eBay. Used 6 flopplies from Microsoft but only get to No.3 before is shuts down. Tried another hard drive that had 95 on it. Got to the Logo. Still trying as my bill information was on Lotus 97 and I need it. Of course not backed up.
  • Rex James Nov 20, 2007
    Thanks for all the possible solutions that have been submitted. The computer went back to the owner and I don't know if he sent it elsewhere for repair. I tried the suggestions but none of them helped in this case. I'm hoping the suggestions will help others who are having this problem.
  • pj24 Nov 27, 2007
    I turned off my Gateway Media Center PC yesterday but turning it off using the Start icon. This morning, I tried to power up but am not getting anything. No light, no beep , nothing. I check the connections and power bar and evrything is ok there. Printer can power up but not the computer. Any suggestions before i ship the computer off for repair?
    PW
  • lvin70 Dec 02, 2007
    Mine does the same thing.
  • samm41 Dec 06, 2007
    The computer shuts down almost as soon as it starts up. Then it will not start up again until I unplug it and start over. Each time, it will just shut down again. I have replaced the power supply and put a new cpu cooler in. Still doing it. Merle
  • stripee Mar 26, 2008
    Hi
    I have a spookily similar problem. PC can run for hours with no problems at all. Sometimes it will shut down after 30 minutes. I thought it was the powerpack overheating, as the only way to switch on again is to unplug from the wall. Interestingly when plugged back in, the pc starts up again immediately without touching the power switch. I can't work out what might be causing and it's not helping the smooth running of the machine.
  • ulccso May 08, 2008
    I have a similar problem. PC can run for hours with no problems at all. Sometimes it will shut down after 30 minutes. I thought it was the powerpack overheating, as the only way to switch on again is to unplug from the wall. Interestingly when plugged back in, the pc starts up again immediately without touching the power switch. I can't work out what might be causing and it's not helping the smooth running of the machine.
  • Rio de Jul 21, 2008
    My daughter's computer (Gateway 310 tower) is doing abut the same. I turn it on and it starts but then shuts off. It then tres to start by it self and shuts down. I don't think it's the pwr supply as th elights lite up and it is tring to start. Any suggestions?
  • ramcharan46 Aug 13, 2008
  • Anonymous Nov 27, 2008
    HELP!
    Have sent my Gateway T1621 back to Gateway 4 times. It runs flat just fine, but when I put it on a stand at a 45 degree angle, it shuts off. They've replaced the motherboard and the heat sink (two times...) and now they're telling me tnat they need to replace the surface area. Sounds like they after August, they can't fix it, and don't want to honor the warranty, but I'm not techie enough to argue with them.
    Need to run it at an angle for mechanical engineering and design work, and I've been without it since August.
    Any suggestions as to what to say to the Service reps?
I am an IT Tech of 11 years, I have found this problem and have solved this problem on the Gateway machines. Also works on the Gigabyte, ECS and Biostar motherboards in the same machine/s. It is not the memory, video, hard drive, or processor so rest assured. This is relatively an easy fix for those that are tech friendly. Remove the retarded one plug front panel power plug, remove the pins for the reset button and that does it. How you fix it from this point is up to you totally, but that does fix the problem. It is a common and frequent problem that mass producers have when developing wiring for them.
Posted on May 28, 2009
Hey there, I have encountered this problem on a few PC's... I have done fresh installs of windows xp pro on two machines, they install fine and I got to turn the machine off and restart and now both PC's turn on then before anything displays on the monitor it shuts right down...Is there a problem with the BIOS this problem seems all too common for it to be hardware on two different machines, they are both relatively old so would the CMOS battery have anything to do with it??? Please help this is getting old!!!
Posted on Sep 07, 2012
My computer (eMachine T3092) would startup and shutdown. I replaced the power supply but this didn't resolve the problem. I mistakenly removed the Power Switch connection from the system board and the computer would not bootup. I replaced the connection, powered up the system, and quickly removed the power switch connection. The computer booted up and stayed up with no problem. Try replacing the power switch. Can any one tell me where I can find a power switch for the above model computer? If so, please email me at holloway@netscape.com
Posted on Jun 01, 2008
    Problem Solver:
  • 9 Answers
Has anyone thought about blowing out the CPU heat sink and fan?? I have encountered this problem many times and it always has been blocked fan and heat sink
Posted on Nov 18, 2007
    Scholar:
  • 161 Answers
You probably have a hard ware problem. Like a bad modem ,ethernet, or video card, sound card or something like that. You can pull them out one at a time until you find the one that is bad.you will have to crack the case with the computer unplugged pull one out at a time and leave it out until you have tried all of them. If after you pull one out your computer starts working then don't put that one back in. Get a new one. you will have to turn your computer on and off unplugging it each time you check one.
Posted on Aug 07, 2007
ITS PROBABLY A VIRUS.. THAT MAKES YOUR COMPUTER SHUT DOWN/RESTART...
Posted on Sep 27, 2007
Try a new memory stick. I have same problem and replacement with new memory stick solve it.
William
Posted on Oct 28, 2007
    New Friend:
The same happened to my CPU. ON checking the motherboard, found it to be burnt. Must be because of power fluctuations.
Posted on Dec 09, 2013
    Welcome Back:
    Visited the website for 2 consecutive days.
Check for popped capacitors on your motherboard a capacitor is cylindrical and soldered on the board will have a X or K indent on the top. If they have expanded from the top then you need to replace the capacitors. check this link : http://www.flickr.com/photos/whyamikeenan/3993856676/
Posted on Aug 18, 2010
Cpu is overheating ! look at that tiny fan.
bios does this , roll backs cpu clocks until temerature drops.
normal overheat situation.
fix the problem not the symptoms.
solution.
add a case for pci slot fan.
my server this box ran for 5 years under linux with this box and a nice 80mm fan added.
cheers
Posted on Jul 22, 2008
Hi: I have a W4682 that uses the FIC Motherboard model number VG33. Mine doesn't have the LEDs you wrote about. However, your description of events sounds like what I had with an ASUS P4B Motherboard using LEDs that change colors from green to red upon powering up. The LED color change to RED is a signal that the AGP Video Card draws too much voltage, such as 3.3 volts when the m/b specs call for using only a 1.5 volt graphics card. The RED lights up and quickly shuts down the power supply so that the m/b will not fry. If you switched video graphics cards back to your original, it may be solve your problem. The 1.5 volt cards have an extra notch to permit entry to 1.5 volt restricted use AGP slots. In any case, check-up on each of your PCI devices to see if any of them may be the cause of the pre-post shut-downs. Empty all of them if you feel the Graphics Card is Okay. And don't forget that your memory frequency needs to match-up or exceed the Processor's FSB setting for the VG33 M/B. I always found that PC3200 (LOW density chips, non-ECC & non-Reg) will always work - going backwards to match the processor needs if necessary. Good luck! -Gregg
Posted on Oct 15, 2007
    Problem Solver:
  • 18 Answers
Sounds like it is grounding out and the power supply is going to a safe mode and shutting down. Check the motherboard, if you have take it out and start it outside the case with no other connections to it(Hdd, memory,ect.)
Posted on Apr 02, 2007
  • 55 Answers
Adding on to Sandrew's answer, try reapplying thermal compound to the CPU and resetting the fan on top of it.
Posted on Oct 11, 2006
    President:
  • 2,961 Answers
Try changing the cmos battery first as sometimes this stops boot up in some cases when flat, if no change it may well be suspect processor or mobo problem. If it doesnt even get as far as first beep more than likely processor
2 Suggested Answers
  • 263 Answers
SOURCE: Turns on, then shuts down before anything shows on monitor
you have to change prossesor is overheating
Posted on Jan 03, 2008
E machine model T3626 turns on display doesnt work and doesnt power off???
Sounds like either the Monitor is bad or the Video Card is bad. Try plugging another monitor on the computer and if it can't show a display then more than likely the Video Card is bad. If it shows on the monitor you just plugged in, then the original monitor is bad.
May 01, 2012 | Computers & Internet
Computer required restarting due to problems with mouse. Once computer was restarted gateway monitor would not work
Not enough information. Please describe any monitor activity when
you turn it on, do this while the computer is still off, unplug monitor, then
plug back in. It should start automatically, then show the gateway logo, then
go blank for several seconds, then show no input signal box, then shut down on its
own. If it fails to do this it is probably that the power printed circuit board
is failing, not delivering the proper power to the main board and/or the back
lamps. One can have this board repaired inexpensively by a qualified electronic
technician.
Email me at Sprint6@zoominternet.net
and we may be able to get your unit working properly again.
Have it repaired soon to avoid additional component failures
Dec 17, 2010 | Gateway FPD1975W 19" LCD Monitor
I hooked my monitor to my computer but it shows a monitor with a ? on it. its because the resolution is to high but i cant change it now.
shut down the computer and start it again. just press and hold the start buuton for few second and the pc will turn off. then start it again
Sep 12, 2010 | Computers & Internet
I have an Acer AL2017 Moniter. Upon turning on the tower the moniter turns on briefly makes this watery sound shuts down and continues this for sometime eventually until no picture shows at all.If I play...
Had the same problem took it apart and found 5 capacitors on the power/inverter board swelled i replaced those with new ones then it worked perfect.. there were 2 1000uf 25v and 3 330uf 25v swelled.
Nov 26, 2009 | Acer AL2017 20" LCD Monitor
Acer Aspire 5520
Sounds like a fried battery. Try a brand new one.
Jul 14, 2009 | Acer Aspire 5520-5579 Notebook
Takes to long for the monitor to start
This is a power supply problem in the monitor. There is an unstable component or components that are failing or you have some cold solder joints in the connections.The reason it turns on is that some components are self healing and will sometimes stabilize after warm-up periods.Cold solder joints sometime close after heating up in the circuit You should return to dealer for repair or replacement. Hope this helps you.
Feb 04, 2009 | Envision EN-7100e 17" Flat Panel LCD...
LCD Shuts down
The monitor screen may be OK, but the monitor electronics are not. YOu state that the comuter works fine with a different monitor. That leaves out the video card. If you reall ywant confirmation of a bad  monitor, Try it on another computer ansdI am willing to bet that it  will again shut off.  Take it to a shop for repair or replace it.
Feb 01, 2009 | X2Gen MG19MY 19" LCD Monitor
Is there more than one fan inside the computer? Did you double-check the connection from the fan to the motherboard? Sometimes a computer will shut down if it doesn't sense that the fan is turning on, to prevent the computer from overheating.
Jul 25, 2008 | Compaq Presario S5100NX (E120866) PC...
Hi ,
u check almost all ....
also check with u r power buton of front panel of pc if this button is get short then it is possible .....please disconnect switch from board & just short with any metal ....if u r pc is not geting shut down please replace rower switch ...
if this information is useful for u please Rate me........
Jun 14, 2008 | Computers & Internet
Gateway 310S (2900621) PC Desktop Logo
10,693 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
